Question about GE 40 Channel Cb Transceiver
Transceiver GE 3-5979 service manual - GE 40 Channel Cb Transceiver
What's the range on GE3-5980A
The GE 3-5980 40-Channel CB Transceiver has a range of 3 miles. (That's the maximum range. Buildings, hills, etc would decrease this unless you use a different antenna plugged into the antenna jack on the side.) Manuals Lib has the manual here: http://www.manualslib.com/manual/382665/Ge-Citizens-Band-Transceiver-3-5980.html .
I hope this helps.
Jun 30, 2016 | Kitchen Ranges
How do I program this unit? I recently got one and found a charger for it and now i would like to use it to listen to the county fire calls so i was wondering if anyone knew how to program this unit.W
What you really have is a transceiver, not a scanner. It is made to transmit on 2 channels an receive on same at about 2-4 watts. I dont know any one that can program it, because these are long gone from service.
Jan 13, 2015 | Radio Communications
GLC-SX-MMD and GLC-SX-MM, are they compatible with each other?
Yes, the GLC-SX-MMD and GLC-SX-MM are compatible with each other, and the difference between the two is that the GLC-SX-MMD transceiver has additional support for Digital Optical Monitoring (DOM) capability. For more tech support, you can consult with our CCIE expert - Bill, and his e-mail address is as below:
bill@3Anetwork.com GLC SX MMD Price Cisco SFP Modules GLC SX MMD 3Anetwork com
Jan 09, 2015 | Cisco GLC-SX-MM= 4 in 1 GE SFP, LC...
What is this? my Icom IC-F4029SDR displays 'sorry'
It appears that the radio has been locked out from service. Return it to whom you got it from.
From pg 35 of the manual:
D D Stun and Revive
The dispatcher can send MDC 1200 signals that will stun or
revive your transceiver. If a Stun command is received that
matches your station ID, the transceiver will display "SORRY"
and you can not receive or transmit. When a Revive com-
mand is received that matches your station ID, normal operation is restored.
Jun 17, 2014 | Radio Communications
The radio has been locked out of service by the owner. Return it to get it unlocked:
Pg 35 of the manual:
D D Stun and Revive
mand is received that matches your station ID, normal opera-
tion is restored.
Estoy en mexico y solo me contestan de chicago, why??
Hi, Augusto,
I hope you can read or have a friend translate this to your language.
What you require is the user manual for your GE 3-597a CB radio.
I have the answer for you here:
Join yahoo group SPECIFIC to your radio Make/Model, these people know these rare and excellent radios, and will help you in any way possible.
You can download manuals, schematics and other goodie for your radio, and all is free of charge.
I certainly hope I have helped you here.
Kind regards,
Peter
Dec 21, 2012 | GE VintaGeneral Electric Cb Transceiver:...
Manual for GE CB Transceiver 3-5809B
what do i use this mobile cb for
Jan 08, 2012 | Radio Communications
GE 40 Channel Cb Transceiver Logo
212 people viewed this question
Top GE Radio Communications Experts
Greg Cann
Greg Cann
eradiostore
eradiostore
J.D. Browning
J.D. Browning
Are you a GE Radio Communication Expert? Answer questions, earn points and help others
