Question about Maytag MER5751A Electric Kitchen Range
Maytag Gemini electric double oven model mer6770aaw error code f1-3
Code won't clear can't open upper oven
2 Suggested Answers
  • 11 Answers
SOURCE: Getting error code 9-6 on MER6770AAW maytag gemini
That code is for obstruction in the lower door lock mechanism. You need to check for a obstruction in the lower door lock. The next step would be to disconnect the power for a few minutes then turn it back on and see if the code reappears.
Posted on Feb 23, 2010
Maytag gemini electric double oven, f1-f2 codes both ovens, tested both temperature sensor probes, both at 1100 ohms, called Maytag, said might be control board. Anything else to test before spending $$$...
make this test and fix it. God bless you
F1:-1 Runaway Cook Upper oven Test the temperature oven sensor replace if necessary F1:-2 Runaway Cook Lower oven Check the temperature oven sensor replace if necessary
Nov 04, 2013 | Maytag MER6772 Gemini Electric Kitchen...
Mer6772bas ovens won't work, bottom oven won't open
F1-4 is a lower oven runaway clean error F9-3 is a lower oven door latch failure. Must be a bad door latch causing the errors.
GEMINI FAULT CODES
Aug 30, 2012 | Maytag MER6772BAS Gemini Electric Kitchen...
Getting a F1-4 error code on my Maytag Gemini model # 6772. Came home to the upper oven at full heat with the control panel beeping. Extremely dangerous situation where the oven would not shut off at the...
Hi greg_shanoia,
The F1:-4 error code means "Runaway Clean Lower oven". You need to check the oven temperature sensor, replace if necessary.
Hope it helps.
Thank you for using FixYa.
Sep 21, 2011 | Maytag MER6772 Gemini Electric Kitchen...
My Maytag Gemini oven is displaying an F9-2 error code...I believe this has to do with the upper oven door lock mechanism...anything I can do, or does this require a service call?
F9-2 error code indicates:
  1. Door latch motor failure/jammed. Latch motor switch failure.
  2. Oven control software failure, or component failure(stuck relay).
  3. Wiring problem.
  • Press the clear key.
  • If the Clear key does not eliminate the problem, turn off the power to the range for 30 seconds, then turn the power back on.
  • It is most likely to have a failed or misaligned door lock switch.
Feb 06, 2011 | Maytag Gemini 30" Self-Cleaning...
Getting error code 9-6 on MER6770AAW maytag gemini double oven range...what and how to fix?
Feb 23, 2010 | Maytag MER6772 Gemini Electric Kitchen...
MAYTAG GEMINI model MER6770AAW Fault code F1-L -same code for upper and lower. After reading other comments, it appears that the temp sensor(s) are bad. I need to find part #'s and cost. Thank you Pete
Here's a late response, hopefully helpful to someone... I had the same issue with same model Maytag range. I pressed the CLEAN option on the touchpad (bottom oven) and that option seemed to work. I pressed Auto Set and I let it go through "remove oven racks" until the display panel read 100 degrees and then pressed CANCEL. About 30 seconds later, when the oven was out of "clean mode," I pressed BAKE, then Auto Set, and it's been working fine ever since...
I'm sure the sensor needs replaced and will go permanently sooner or later, but if anyone out there gets the F1-L code but hopes to at least temporarily revive your oven maybe this will do the trick.
Feb 15, 2010 | Maytag MER6772 Gemini Electric Kitchen...
I have a Mytag Gemini i had it for 10 yrs. It gave a code that says F3-1 what is it mean.
This is a Common Error Message on this Model. This Refers to :-
Oven Temperature Sensor, Upper Oven.
You need to replace the Oven Temperature Sensor. On Most Models, it is inside the Oven in the Upper Corner.Once Replaced, this would fix the problem.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 30, 2009 | Maytag MER6772 Gemini Electric Kitchen...
The Maytag Gemini is didplaying an f9-3 code, what does this mean?
somthing wrong with upper door lock, bent, door misaligned, problem with lock itself
Dec 25, 2009 | Maytag Gemini 30" Self-Cleaning...
Range displays error code f9-5
HI. This indicates that there are serious issues that concern the operational value of the main control abord(ERC/Clock).
This will require you to replace the ERC, asap.
ERC_(Electronic Range Control Board)
F9-5_Hardware conflict(watchdog)
Nov 08, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER5751A Electric Kitchen Range Logo
22 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
