Question about Brother CS-80
How do I open the machine to replace the bobbin ring on a Brother CS-80?
    New Friend:
  • 26 Answers
Here's MY answer.
  • The case halves are held together by 5 larger screws, one under the carry handle, obvious from the holes in the casing, plus one smaller screw up by the foot-raising lever.
  • There is also the final screw, which is a devil to find. You have to remove the plastic tray to which the spool carrier is attached, up by the spool winder. You do not need to remover the spool winder stop but the small screw on the left, in the bottom of the tray-shape.
Next, WITH CARE , lever round the tray with a thin blade and use a small screwdriver to ease it out of the case; there are 2 bits that stick out more than the rest.
  • Once this tray is out you can see a small bar with a screw. Remove this screw and the 2 halves of the case will separate.
TAKE CARE NOT TO DROP THE SCREW INTO THE WORKS!. A piece of sticky-tack on the end of the screwdriver helps here if the screwdriver is not magnetized.
  • Now you can carefully ease the ribbon-strip cable from the circuit board and move the case round to be able to access the screws that hold the circuit board. You do not need to pull out the other cables; just take a tad of care as you work.
The bobbin winder mechanism is held in by 1 screw - take this out and you can then easily replace the rubber drive ring -(which you have providently ordered)
  • Take the opportunity to clear out any fluff and dust while you have the cases apart. Put ONE drop of oil in the center of the bobbin carrier rotating mechanism and one drop on any moving joints.
  • Replace the components/ ribbon cable in the reverse order, taking care not to drop the small screw! It is necessary to carefully line-up the hole into which it fits. It is surprising how easily the tray clips back into place, compared with the hassle you had getting it out.
I took both my CS 8080s apart last week to replace the drive rubbers. The first took nearly 1.5 hours, the next 1 hour as I knew what I was about.
Posted on Feb 09, 2015
SOURCE: Can't wind the bobbin
Hi again,
Well we finally downloaded a service manual that cost a few bucks, then finished getting the machine apart, then found a small rubber O-ring that had obviously gotten hot when spinning after the tangling of the thread on the bobbin stem. You could see where the heat had melted tiny teeth marks in the ring and it was stretched out of shape. It and yours too will need to be replaced.
If you or someone you know is mechanically inclined, you will need to take five screws out of the back including a hard to find one under the foot raising lever (lower the foot), then one form the front that is under the thread cartridge, and you will have to remove the bobbin winding plate cover which is held by one small screw, and then remove a small screw from the support bar.
Posted on Nov 10, 2008
  • 16 Answers
SOURCE: Unable to wind bobbin on Brother Css-8150 stopped suddenly
Checking to see if in fact that the bobbin shaft is turning. Run it without any bobbin on the bobbin shaft. Make sure that it is push over in the correct position and run it. I checked on mine and it does make the whirring sound and the the shaft does spin. Also check underneath the shaft to see if there is any thread wrapped around it. ( I had problems with that in the past). I hope this helps,
Posted on Sep 27, 2008
  • 41 Answers
SOURCE: I NEED BOBBINS FOR THE BROTHER CS - 8072.
http://www.sewforless.com/item/Brother_96_Class_Bobbins_10_pack_SA155/7788
Posted on Mar 11, 2009
  • 78 Answers
SOURCE: brother cs 6000 bobbin moves
Try this for me clean out the hook area under the bobbin case some times dust from thread and cloth build up under the bobbin case and it can push up the bobbin case and cause the same thing to happin.
Posted on May 31, 2010
Bobbin will not lock on bobbin spindle, what can I do?
Posted on Oct 19, 2011
How to Remove front cover of Brother CS-80 sewing machine
Have you tried Alans Alterations at the MID WALES SEWING CENTRE they have a huge presence on ebay.They should be able to help you,or point you in the right direction.
Feb 27, 2014 | Brother CS-80
Bobbin winder shaft wont spin
If you take it apart, you'll void the remaining warranty. The usual cause is not getting the door open completely and/or thread wrapped around the spindle.
You'll also want to take a look at: http://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=CS8150
Feb 11, 2014 | Brother CS-8150 Computerized Sewing...
Getting the cover off my brother cs 80. all screws have been removed and the cover comes off partially. I seems to be stuck at the turn wheel, like something is holding it fixed.
I had the same problem when opening my machine. The problem is a screw underneath the bobbin winder area. Pull the bobbin base off and then gently pull up the bobbin winder assembly from under the front cover. You will see a screw in the corner to remove so that you can complete the task. I had to purchase a service manual and then I had great success with replacing the bobbin winder "tire" (Bobbin Winder Tire, Babylock, Brother #X55238051 at sewingpartsonline.com - $3.99!!)
My bobbin winder works like a charm now. Sewing Parts Online Search
Sep 09, 2013 | Brother CS-80
Bobbin doesn't wind on my cs-8080 innovis
On my one the rubber ring had degraded into a sticky mess and come off the pulley-shaped wheel on the bottom end of the winder shaft. It had stuck itself to the casing by the shaft bearing. Using Q Tips and nail varnish remover I managed to clean it all off.
To access the screw that holds the bobbin winder mechanism in the case; you first need to remove the screws that hold the circuit board in place and ease it out of the way.
Aug 08, 2013 | Brother CS-80
The bobbin winder will not work
My bobbin winder worked great for a while. The last time I used it it worked fine. Today I got it out and it would not spin the bobbin to wind it. I got on a forum and they talked about the O Ring deteriorating. I took the machine apart and found no evidence. No melted rubber, shavings NOTHING. In fact that there was no evidence the O Ring had EVER been there. I looked in my husband;s stash and found several sizes until I found one that fit. I put it in the groove where it should had been and it is working great now.
Jul 06, 2012 | Brother CS-80
Bobbin winder
then there is something wrong with the bobbin winder & it needs to be repaired
Feb 29, 2012 | Brother CS-80
Part for bobbin winder cs-100
http://www.sewingpartsonline.com/ has the part you need. It's called a bobbin winder "tire"
Nov 27, 2011 | Brother CS-100-T Computerized Sewing...
Brother CS80 ..... bobbin winder not working. power not being transfered to the shaft that turns the bobbin. how can i fix it?
check the power cord to see if it plugged in to the machine correctly
& if it is then something could be loose or broken inside, it needs to be serviced
Aug 03, 2011 | Brother CS-80
Exterior Bobbin winder does not turn or wind a bobin? Model CS-8072
you will need to turn the speed to maxium then press the start button. I attached a site that has your manual and shows great pictures of how to wind a bobbin.
brother model CS-8072
Mar 15, 2011 | Brother Sewing Machines
Cannot wind the bobbin
Check to make sure that the bobbin is locked onto the winder. If is not locked on then nothing will move. I know I had this problem as well and found that the bobbin must be locked on the winder.
Aug 24, 2008 | Brother CS-8150 Computerized Sewing...
Brother CS-80 Logo
318 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
