Question about JVC Televison & Video
How to degauss a jvc c-1918
Circular banding of green in the center,surrounded by red and then blue.
tvman
  • 4 Answers
SOURCE: red tube is projecting wide (convergence)
You need to replace the convergence IC's
Posted on Jun 08, 2006
  • 1694 Answers
SOURCE: JVC AV-56WP30 56 in. Green Convergence off
Remove front grill cover---look just inside--If your model has the
convergence board up front,then you might change the board
instead of re-building it.Depends on price and availibilty.....
If you want to pursue repair,let me know......T.
Posted on Oct 28, 2007
  • 8457 Answers
SOURCE: picture fuzzy and brighter in center
Ur convergence is dead,must be placed.U know how to solders?Tries these wesites for convergence kit.Tv repair World.com,Tv Repair Kits.
Posted on Oct 23, 2009
  • 3 Answers
SOURCE: tv works , red color band is good the green and blue are stagard
Sounds like the convergence IC's are bad. You'll need to contact a local tv repair center and ask about it. They usually run about 25 bucks a piece (give or take a few) and you'll probably need both of them replaced. If your semi-technically inclined you might be able to repair your self with the right equipment and service manual for that specific tv.
Posted on Oct 26, 2009
  • 8457 Answers
SOURCE: JVC AV48WP30 Projection TV..Half picture distorted and flickering
Ur convergence is dead.Must replaced the 2 convergence ICS and all it resistors.The shop will cost U $300 for parts and parts.
Posted on Feb 10, 2010
We have a JVC LT-32JM30 and recently for no reason at all, the picture color has messed up, we have tried resetting and adjusting the tinit, etc but nothing works. Everything is a varying shade of green or...
an internal degaussing coil circuit is already installed in the unit to neutralized color pattern...a loose solder connection may have caused this because as it operates temperature increases between the thermistor..
Jul 15, 2011 | JVC AV-27530 27" TV
Need to know the coluar codes of the wires
Front Right speaker: Red
Front Left speaker: White
Center Channel: Green
Left Surround (side): Blue
Right Surround (side): Gray
Left Back Surround: Brown
Right Back Surround: Tan
Subwoofer Line-Level Output (RCA): Purple
hope this helps you goodluck
Mar 18, 2011 | Car Audio & Video
Hook up sony blu ray
You should be able to hook it up with a component video cable. A component video cable is a cable that has 5 color coded RCA style ends that are Green/Blue/Red/White/Red. The Green, Blue and one of the Reds is for the video and delivers the signals needed to produce the HD picture and the White and the other Red is for the audio to provide you with stereo sound.
The Video cords will plug into the section labeled component video facing up and down and the audio will plug into the side by side section. So if you plug into Component input 2 then you would plug in the audio into the audio section of input 2.
If you have a separate surround sound system you can connect one of two ways.
1. Plug a separate Audio (red/white) cable from the Blu Ray to an available input on the surround sound.
or
2. Plug all inputs into the TV (as noted above) and then plug a separate Audio (red/white) cable from the tv labeled "Audio Out" to an available input on the surround sound system.
Jan 03, 2010 | JVC AV-48WP30 48" Rear Projection...
Jvc av48wp34 with green tint and center of screen sags down
hello take the a aerial out to see if the green tint is still there if it is the then you've got a degausser problem you
shaun
Jul 31, 2009 | JVC Televison & Video
Rings of Color
You will need a degausser. Check out Wikipedia for the definition. Look on ebay or your local TV repair shop. Cost should be $20-$100.
Dec 13, 2007 | Panasonic CT-27SX12 27" TV
Colour distortion
Your screen mask may have become magnetized. This will require that you have the CRT degaussed. This is done with the use of a degaussing coil. you have to stand about 10 feet from the TV with the coil held vertically and moving it in a circular pattern as you walk towards the tv. Once you are about 1-2 inches from the TV stop and continue the circular pattern for about a three count then backup from the tv still using the circular motion once you are about 10 feet from the tv turn the coil to a horizontal plane and move it away quickly and turn it off. This should degauss the TV and remove the color distortion.
You will need a degaussing coil to perform this task.
Thank you,
Shuttle83
Nov 27, 2007 | Televison & Video
Color problem
Replace D805 (?) Thermistor for permanent fix, manually
degauss with coil is temporary........T.
Oct 29, 2007 | Panasonic CT-36SF37 36" TV
Televison & Video Logo
18 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
