Question about Midland Radio Communications
79-290 midland change channels when you key up
    Genius:
  • Midland Master
  • 1,795 Answers
Time to invest in a newer radio.
Posted on Sep 01, 2015
Midland 75-822 frozen on channel 19.
radio is out of lock .Replace the I C and it should unlock or you could try to do it your self but you would still have to replace the I C .
Oct 12, 2016 | Midland Radio Midland 75-822 Handheld...
Why wont my midland cb change channels
make sure the channel 9/19 switch is off / set to normal
Jun 09, 2014 | Midland 4001 40-Channels Base CB Radio
One radio clicks when the other is mic
Scanning is interrupted when you key the other unit's mike. For example, if the non-scanning unit is set to channel 13 and keyed scanning will stop at channel 13 on the other unit to establish communication between the two.
Nov 07, 2013 | Midland LXT310 2-Way Radio
When driving over rough ground my midland alan 48 plus multi cb will sometmes change channel on its own i wondered if this could be a mike problem as you can change channel from the mike
Check for loose buttons, could be something loose inside, if its changing on its own when its moving around could be from vibration that something has come loose.
When parked just try shaking the mic first if that doesnt do it shake the cb itself and see if the problem persists
May 18, 2010 | Midland Radio Communications
I can't get the 2 way radios on the same channel
Press the Menu button. The channel number will flash. Press the adjust keys to select the channel number. Press the menu key again and the Subchannel number will flash. Set to desired number. Then press the push-to-talk key to get out of menu mode. Repeat with second radio and be sure to choose the same channel and subchannel. Then adjust volumne as needed.
have fun!
Nov 19, 2009 | Midland LXT310 2-Way Radio
Wont change channels...stuck on channel 8
on this radio you have to put the norm and channel 9 switch to normal or up if it is on ch 9 positon it will not change channels.
Apr 16, 2009 | Midland 1001Z 40-Channels Base CB Radio
Can't figure out how to get a "channel" to lock on the handset
Here is a link to the owners manual for the LXT-330 420 Series radio:
http://www.hitechwireless.com/pdf/Midland/LXT-330-420 Owners Manual.pdf
I hope this helps.
HiTechWireless.com
Mar 27, 2009 | Midland LXT410 (14 Channels) 2-Way Radio
Midland squealing when talking
soundwas keying up at the same time.s like it could be one of two problems. a loose wire in the mic or some one near you keyed up the same time as you. if the wire in the mic is loose sodder it. If some one keyed up near you you might have blown the reciever chip.
Sep 15, 2008 | Midland 1001Z 40-Channels Base CB Radio
How do you unlock the channel?
Press and hold the Lock key for 5 or 10 seconds until a beep sound is heard.
Good luck
Oct 23, 2007 | Midland M222P (22 Channels) 2-Way Radio
Radio Communications Logo
Top Midland Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
