Question about Brother CS-80
How do I replace the the washer in the bobbin winder?
4 Suggested Answers
SOURCE: Bobbin winder
then there is something wrong with the bobbin winder & it needs to be repaired
Posted on Mar 01, 2012
ju222dy
  • 8 Answers
SOURCE: Bobbin winder belt melted
Mine stopped working too. Gave up and wound bobbins by hand for a while until I broke down and took the machine apart -- an ordeal to figure out. I found that a pliable ring on the winder was completely disintegrated (gummy plastic-like stuff). An online search found this -- a bobbin "tire" which I THINK is the part I need: http://www.sewingpartsonline.com/bobbin-winder-tire-brother-x55238051.aspx. Hope this helps. --Also cleaned all the lint out when I had the machine opened up. They don't make it EASY!
Posted on Aug 09, 2012
mountain_cra
  • 86 Answers
SOURCE: Broken bobbin winder
For $29 at Hancock, Jo Ann's or Wal Mart you can get a thing called a Side Winder that will wind your bobbins without using the winder on your sewing machine. It has the additional advantage that you can wind while sewing. I use it even with machines that will wind bobbins.
Posted on Sep 07, 2012
Bobbin winder not working
For ~$30, you can purchase a stand-alone bobbin winder (Sidewinder) that you can use to wind your bobbins. Saves wear-n-tear on your machine and you can wind bobbins without unthreading your machine. Just be sure to verify your bobbins are compatible with the Sidewinder.
Amazon com Simplicity SideWinder Portable Bobbin Winder
Simplicity Sidewinder Portable Bobbin Winder
Simplicity SideWinder Bobbin Winder Walmart com
Simplicity Sidewinder Bobbin Winder
Jul 18, 2017 | Sewing Machines
I need replacement "bobbin winder complete" for the one I broke on my Thompson Mini-Walker PW 201. Does anyone know of a source for it? Also I need a manual for this machine.
If you are unable to replace the bobbin winder for your machine, you might check the local fabric stores for a stand-alone bobbin winder. Last time I checked, they cost around $20-25. They are nice to have because it saves wear and tear on your machine.
Apr 13, 2015 | Sewing Machines
How do I fix my bobbin winder?
1. Take the top off.
2. Check to see if the bobbin winder has pressure as you move it back and forth. There should be. If not then check for a spring connected to the bobbin and reset it. There will be some kind of post to hook it to.
3. Place the bobbin winder in the "off" position and put the top lid back on.
4. Without putting the screws back in move the bobbin winder to the "on" position and to the "off" position.
5. There should be pressure either way you move the winder.
6. Loosen the hand wheel handle.
7 With the bobbin winder in the "go" position use your foot pedal to make sure it revolves.
8. Replace the top.
Dec 01, 2014 | Sewing Machines
Brotherxl2230 can i safly replace washer on my bobbin winder , i have bought the washer from brother for 27 pence but need to know can i take the back off the machine to replace it without lots of sp
A screwdriver or two is typically all you need - look at the screw heads to see what shape they are. If you don't have the right screwdriver, often you can get them with multiple styles of bits without it costing a great deal.
I don't have one of these machines specifically, but if the washer can't simply be lifted off, and you need to remove the back, there ought to be just a few screws to deal with.
Oct 12, 2014 | Brother XL-2230 Mechanical Sewing Machine
Bobbin winder screw broken, how to replace?
Until you can get your bobbin winder repaired, I'd suggest picking up a bobbin winder at your local fabric store. The last time I noticed, they cost about $30. Many sewists prefer to use this little accessory inside of wearing out the bobbin winder on their sewing machine. Also, if you more than one thread cone, you can rewind bobbins without unthreading your sewing machine.
Jun 19, 2014 | White Sewing 1418 Mechanical Sewing...
Bobbin problems winding
Does the bobbin winder have a rubber o ring on it so that when the winder is in the winder position are the two making contact to wind
Mar 14, 2014 | Sewing Machines
Jan 18, 2012 | Brother CS6000i Computerized Sewing...
Bobbin winder "washer"
It's called the
"bobbin winder friction ring"
You can find one on the site below for $1.50 or so.
https://www.vintagesingersewing.com/catalog/index.php?cPath=42&osCsid=7697cebcf0714ac3da8b2c1101c98365
It's the last listing for machine parts.
Hope this helps, please rate this if helpful
thanks
moni
Sep 15, 2009 | Singer 5050 Mechanical Sewing Machine
Can't wind the bobbin
Bobbin will not lock on bobbin spindle, what can I do?
Mar 20, 2008 | Brother CS-8150 Computerized Sewing...
Brother CS-80 Logo
62 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
