Question about Refrigerators
GC5SHEXNQ02 Whirlpool 2door ref - Panel gets hot
GC5SHEXNQ02 Whirlpool 2 door ref - Panel between refrigerator and freezer gets hot. How can I fix this?
  • Refrigerators Master
  • 4,655 Answers
I am not going to say the problem is normal. Normal operation those strips are placed behind the metal and inside the walls around the door seals to prevent moisture or sweating around the doors. They are usually noticed to become hot when there is a change in the control boards operation. Some brands have the hot gas from the condenser circulating around the doors. If your model has an economy switch, switch it on. I would look for any abnormal operation of the refrigerator like compressor or condenser fan stopping or ice buildup or abnormal temperatures in the fresh food compartment. If this continues I would unplug the refrigerator and open the control panel inside the fresh food section and examine both sides of the control board for signs of heat or burn marks on both sides. May not be anything to be concerned about also because this may be the first time you noticed this. But it should not be too hot to touch. Sea Breeze
Posted on Jun 23, 2009
  • John Tripp
    John Tripp Jun 23, 2009
    Thank you for your vote and support! If you should have any questions feel free to ask. Sea Breeze
  • 351 Answers
This is normal, its too keep the gasket a good seal and stop condensation
SOURCE:
Water accumulates beneath freezer basket and drips outonto kitchen floor. cannot get into area to cleanout welland see no type of removable tray.what can I do ? this is a whirlpool model # GX2FHDXVY04...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 03, 2011 | Whirlpool Refrigerators
Whirlpool refrigerator 166007 EBXVQ9SHK Frequent leaks. This is my third repair and every time, the repair dept said it is fixed but then it starts leaking again. The refrigerator was purchased from...
Leo Ponder
imufo2
Aug 11, 2011 | Whirlpool Refrigerators
Why is water leaking inside the refrigerator. found water in back on all levels.
You probably have a frozen drain if its a top freezer. The water from the defrost cycle will drip down into the ref section. The easiest fix would be to shut the unit down for 24 hrs with the doors open. The other option would be removing the back panel and using a turkey baster shooting hot water down the drain line until it thaws. Good luck _MJ_
Mar 09, 2010 | Whirlpool Refrigerators
General Elec. refrig. about 12 yrs. old. water in bottom of frig., cleaned up, found water a second time.
drain is cloged. at some point the ref section was set too cold. the defrost water from freezer drains through the ref back wall. becaust it was set too cold the drain froze. two ways to fix .... empty unit and unplug for 24 hrs. OR remove back panel, defrost drainrail, remove bottom panel ,remove ice, insert 1/4 inch tube down drain, and squirt very hot water down drain till it is clear of ice..... when defrosted set ref on "3"
Aug 26, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water accumulating in bottom of kenmore
It's likely the condensate drain is plugged. You can access it from the back of the refrigerator. You can disconnect from the inside of the fridge and blow it out to ensure it is not blocked, then reconnect.
Aug 15, 2009 | Refrigerators
Have a Whirlpool frig. gets very hot around the door????
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 29, 2009 | Whirlpool GD2SHGX Refrigerator
Fridge part not working on Whirlpool Arc 7050 Fridge Freezer
If this is correct:
1. No ice build up on back of freezer wall.
2. Fan in freezer is working.
3. Items in freezer are frozen, ice cream is a good test.
Then:
Why is the cold air in the freezer not getting over to the Ref. side?
1. There is a channel (tunnel) from the freezer to the Ref, side and there is a door which regulates how much cold air from the freezer goes through to the Ref. side.
2. The control panel may have it labeled as "Freezer" setting, from cold to coldest. The coldest setting means the door is almost closed and will keep most of the cold air in the freezer.
3. Since your control panel is not working then this door must be almost closed keeping all or most of the cold air in the freezer.
Any service tech should be able to check the control panel and find the problem.
Jan 25, 2009 | Refrigerators
Freezer and Ref. are warm
i assume this is a frost free type. the fault may well cure itself.
to hasten the process, remove the back panel inside the freezer and you will probably find the pipework frozen up. melt of the ice carefully with a hairdryer making sure you don't heat any stats that are clipped on the pipework
Sep 04, 2008 | Whirlpool GD2SHGX Refrigerator
Front metal piece that the seal goes against - between freezer and fridge
ED5VHGXMQ10 Whirlpool Fridge
I have the same problem. Too hot to touch between the freezer and refrigerator door. Is
this normal?
Jul 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
281 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
