Question about Asko D3122XLSS Stainless Steel Dishwasher
D3122 the drain work all the time even when i shut down
Jetta 2.0 2002 battery drained
well if you have a short that would blow a fuse a battery drain is caused by something not shutting off. now the test light theroy dont work on a vw because it takes about 30 minutes for the convience control module to shut down . after shuting car off lock doors with remote and watch dash to see if it shuts down if it does check your radio front to see if its warm if it is you could have a radio thats not shuttinr down your amp
Mar 28, 2013 | 2002 Volkswagen Jetta TDI
It will wash but when its time for the first draining out the water to spin it stops
Three things to inspect are:
  1. Clogged drain hose - cause water to back up to the pump and shut down
  2. Clogged drain tube - usually occurs when the drain hose is attached to a drain tube that empties out into the homes sewer system. Just like a clogged drain, water will back up all the way through the drain hose into the pump and shut down.
  3. Clogged or bad drain pump - Many times, debris left in pockets will work it's way into the drain pump. Over time, enough debris (paper, coins etc) could lodge itself into the pump. When the machine tries to empty or spin out, the pump becomes overwhelmed and shuts down. Sometimes, you may even see a puddle of water appear under the washer due to a clogged pump. This can also happen if the pump itself is worn out and no longer working up to specifications.
Best of luck with your repair.
Greg
Jul 20, 2011 | Kenmore Washing Machines
Water will not drain, makes a noise when filling, pump does not seem to be froze up.
Luckily, your drain pump is easily accessible. Placing a towel or blanket down, unplug the machine, disconnect the fill and drain hoses and gently turn the washer forward onto the towel or blanket. Only tools needed are a pair of pliers and a phillip head screwdriver. After removing the drain hose and the screw holding the pump in place, it should easily be removed so you can inspect for debris (a very common problem with F&P washers.
Greg
Jul 20, 2011 | Fisher and Paykel GWL11 Top Load Washer
ASKO D3122 PUMP STAYS ON AND MACHINE WILL NOT SWITCH ON
The machine has activated a safty seq. There is most likely water on the lower buttom. Leakage or drain pipe blocked. The power will get to the drain pump, when this happends. To prevent overflow on your kitchen floor. Dry out the water. Then it will start as usual.
Jul 25, 2009 | Asko D3122XLSS Stainless Steel Dishwasher
Asko D3122 dishwasher will not fill with water and will not turn off
you may have water under the dishwaher ... have any plumbing work done lately?
if the dishwaher overflows or leaks it will trip a float switch under the dishwasher... as long as it is triped it will run the drain pump.. and not let any water into the tub...
the water will have to be removed and the leak stopped before it will run a cycle....
Hope this helps if not let me know more about your problem..
Mar 20, 2009 | Asko D1876 Dishwasher
Asko d/w d3122 Hi gang the overfilling protection has been activated, what can I do to remedy the sitution. regards banger35
Have a look to make sure that the pump and drain hose are unblocked. If they are, you might have to call Asko and arrange a service call.
Oct 08, 2008 | Asko Dishwashers
Kenmore 44092500 Won't complete spin cycle
AllExperts.com gave me the answer I needed at no cost.
Jul 29, 2008 | Kenmore Energy Star 44092 Front Load...
My Zune is Not responding
after much research on this matter in the past few hours. To resolve this situation don't shut the zune down by holding play/pause button it does not shut down properly that way.
Hold down the down & back button down until shuts off....zune recommends as the best way to turn off your zune. Also if you are having problems holding charge, a lot of people replaced the original charge plug and found that it worked again. these cables usually become faulty from previous models and 30gigs. So buy a new cable & shut it down correctly.
Still no worky??? Call zune, within 1 year they will accept it for repairs. They may even send you a new refurbished zune...since they no longer are making the 30 gig...probably for those reasons.
I hope this advice not only helps you but myself. Who wants an expensive paperweight...not I!
Dec 11, 2007 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Dishwashers Logo
19 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
