Question about Polaris 9300 Sport Automatic Pool Cleaner F9300
How do I tell if fuse is bad - Polaris 9300 Sport Automatic Pool Cleaner F9300
Dyson ball dc25, were is the fuse on vacuum
It is most likely the switch that needs replaced
Jul 22, 2017 | Dyson Vacuums
How do you change a fuse on a dyson dc25
You don't ! There is no fuse. Has it stopped running ? Could be a bad plug or a bad switch. Take it to your local vac shop for assessment.
Jun 07, 2017 | Dyson Vacuums
Where is the fuse on hoover free space evo ?
The fuse should be inside the vac attached to the motherboard that the plug attaches to or it will have its own little motherboard. I cant tell but it seems that the European vacs have a fuse in the plug so im not to sure, id check out both
Oct 01, 2016 | Hoover Vacuums
Shop vac fuse
Very rarely do vacuums have a fuse in them. You probably have a bad switch or possibly a bad motor.
Mar 29, 2014 | Shop-Vac Corporation Bulldog 8 Gallon...
No spark,no power to ignition module
Do you have power to the fuse? Sometimes fuses look good, but are actually bad. Check with volt-ohm meter. otherwise bad connections and or wire, corrosion causes a lot of bad behaviors, clean to bright metal for all connections and contacts. Again check with volt-ohm meter, or "indicator" light method.
Nov 03, 2012 | Clymer Harley-Davidson Dyna FXD Evolution...
I put the flashlight on the charging area and the thing went nuts. I unplugged it and plugged it back in and it went dead.
I think I have bad news for you. It sounds to me like you put the flashlight made out of metal, that conducts electricity across the pins of your cordless vacuum cleaner charger and accidentally short circuited the charger and it went poof. Poof is not a good thing. It may be possible, though I doubt it,
that there is a fuse inside the charger that can be replaced. I would check a small appliance repair company as to the cost of fixing this before I gave it to them. I think it would be more expensive than it costs to purchase it. That is, if there is a replaceable fuse. If you can tell me the name and company, I could do a little research myself. I hope this is helpful to you. Let me know if I guessed right about what happened. Thanks.
Best Regards,
Mark
Dec 29, 2010 | Vacuums
Shopvac 90L400 quit working (4 years old). Thought the switch was bad but not the problem. I read that there is a fuse link in the motor that frequently burns up. I tried to take motor apart but not sure...
by pass the switch and take power right to the motor leads.. that should tell you if the motor is ok.. have not seen fuse link on a vac motor.. graingers has new motors, but not inexpensive
Nov 30, 2009 | Vacuums
Electrolux oxygen 3 fuse
The fuse on my ELECTROLUX Oxygen3's sumo board did have clear markings: F5AL250V - this is a 5A/250V 20mm fuse made by BEL FUSE, however, any other such fuse should work. The fuse on my board was blown (luckily, what caused it seems to be a glitch as replacing the fuse was all that I had to do). I got 5A/250V 20mm fuse from RadioShack and, expecting that this could happen again, I also installed a simple (5A/250V-rated) automotive fuse holder (also from RadioShack) (the only fuse holder that was available at a local store) and it works wonderfully now. Should the fuse blow on me again, I should be able to replace it in less than 3 minutes.
Feb 03, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Motor just stopped.
Some of the Sharp's have a fuse in by the switch. Could be blown fuse, bad switch or bad cord. The worst would be an open in the motor.
May 14, 2008 | Sharp Vacuums
Polaris 9300 Sport Automatic Pool Cleaner F9300 Logo
Top Polaris Vacuums Experts
JoeVacs
Are you a Polaris Vacuum Expert? Answer questions, earn points and help others
