Question about Poulan Garden
Poulin 3400 chainsaw will it start on 90 lbs compresion
Have replaced the rings and crankshaft case seals and I can only get 90 pounds compression it will not start has gas and spark
    Master:
  • 706 Answers
No likely and if it does it won't have any power.
Posted on Oct 21, 2014
steve_lima
  • 181 Answers
SOURCE: compression Poulan chainsaw
you can not set the compression on two cycle motors,the compression new is at about 90 to 95 pounds after six to nine pulls of the recoil
Posted on Jan 07, 2009
  • 97 Answers
SOURCE: Chainsaw will not start
Remove muffler and check for carbon blockage.
If that is ok check crankshaft seals for leakage.
Posted on Mar 14, 2009
  • 15 Answers
SOURCE: poulan wood shark 1950 wont start spark plug has
Try to squirt a little gas in the carb and see if it pops or tries to run for a short time. The diaphram in the carb is probably old and hard. That would be the first place I would look.
Posted on Nov 08, 2009
dontbother10
  • 2220 Answers
SOURCE: poulan 34cc chainsaw. wont start. replaced
Set the gap as Drallim suggests then follow this to test the ignition system, the entire system.
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode. HTH
Lou
Posted on Feb 24, 2010
  • 221 Answers
SOURCE: gas leaks from the gas cap past the rubber o-ring
Ethanol fuel is causing many problems with 2 stroke engines. I would recommend purchasing another fuel cap and rotating them. Let one dry out while using the other. Usually they will work fine for a day and then rotate the dry one in. Ethanol is causing the cap to warp.
Posted on May 17, 2010
How many foot pounds of torque should I use to tighten the bolts that holds the crankshaft and the bolts of the pistonshaft on to the crankshaft?????
Ok, the main cap bolts (crankshaft) vary depending on 6 or 12 pt. head. 6 pt. head is just 14 ft. lbs. 12 pt head on the bolt requires it to be tightened in 4 stages, 16 ft. lbs., then 32 ft. lbs., then turn additional 90 degrees, then another additional 90 degrees. The connecting rod cap bolts (pistons) get 2 stages, 15 ft. lbs. then additional 90 degrees.
Jul 25, 2015 | 1998 Toyota Corolla Sedan
Not starting
It sounds like you have low/no compression. To be sure use a compression gauge by screwing it into the spark plug hole, holding the throttle wide open and pulling 6-5 times. If it is reading less that 90 lbs on the gauge then you have a problem. Technically the saw should have 120-150 lbs, but it will run at 90 lbs. In the event that you have a low reading you will need to replace the jug, piston, and rings.
Apr 12, 2013 | Husqvarna Garden
45 lbs. of compression...........good or bad?
If it is still under warrenty then return it for a new one...
Compression should be around 90-110 lb. per sq inch.
Sounds like ring problems, valves, etc.
If it is not under warrenty, time to trash it...because the engine is shot.
Please take time to rate me
Bud
Oct 26, 2012 | Craftsman 18" 2.4 C.i. 40cc Chainsaw...
I have a craftman chainsaw with a 42 cc engine has compression of 90 lbs does it need rebuilt it wont start
90lbs is not enough compression, so yes rebuild, or more fiscal idea is get a new one, unless you can do the labor yourself.
Sep 25, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Aligning the valve timing mareks except twincam engine
Timing Chain, Sprockets, Front Cover and Seal REMOVAL AND INSTALLATION Crankshaft Damper and Front Oil Seal
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Accessory drive belt
    • Cooling fans
    • Crankshaft pulley and damper, using a holding fixture as shown
    • Front crankshaft seal Fig. 1: Crankshaft pulley removal tool - V8 9301jg12.gif
    To install:
  3. Install oil seal replacer tool JD-235 to the oil seal. Use the nut and bolt provided with the tool to fully seat the seal to the timing cover.
  4. For dampers which DO NOT utilize a spit locking ring:
    1. Apply a thin, even coating of Loctite® 648 to the damper bore. Do not apply it to the end faces or to the crankshaft.
    2. Install the crankshaft damper onto the crankshaft. Wipe off any Loctite that has squeezed out from the front of the damper.
    3. Install the locking tool to the damper. Tighten the bolt to 59 ft. lbs. (80 Nm), plus an 80 degree turn.
  5. For dampers which utilize a spit locking ring:
    1. Install a new O-ring seal to the damper.
    2. Install the crankshaft damper.
    3. Apply petroleum jelly to the damper bore and O-ring seal.
    4. Install the damper onto the crankshaft.
    5. Install the split locking ring onto the crankshaft, inside the center bore of the damper.
    6. Install the locking tool to the damper.
    7. Tighten the damper bolt to 266-285 ft. lbs. (364-386 Nm).
    8. Remove the locking tool from the damper.
  6. Install or connect the following:
    • Cooling fans
  7. Start the engine and check for leaks.
Timing Cover
  2. Drain the cooling system.
  3. Remove or disconnect the following:
    • Upper radiator hose
    • Water pump pulley
    • Accessory drive belt tensioner
    • Idler pulley
    • Crankshaft damper
    • Engine appearance covers
    • Mass Air Flow (MAF) meter
    • Air intake assembly
    • Ignition coils
    • Canister purge valve
    • Valve covers
    • Variable Valve Timing (VVT) solenoids
    • Engine harness retaining clips
    • Timing cover
    To install: Fig. 2: Sealant application points - V8 9301jg23.gif
    Fig. 3: Timing cover torque sequence-V8 9307jg01.gif
  4. Apply sealant to the 8 joints on the engine face as shown.
  5. Install or connect the following:
    • Timing cover with new seals. Tighten the bolts in sequence to 96-120 inch lbs. (11-13 Nm).
    • VVT solenoids
    • Valve covers
    • Ignition coils
    • MAF meter
    • Crankshaft damper
    • Idler pulley
    • Water pump pulley
  6. Fill the cooling system.
Timing Chain 6 CYLINDER
    • Valve cover
    • Timing chain cover
    • Variable Valve Timing (VVT) sensor
    • Crankshaft Position (CKP) sensor
  3. Rotate the crankshaft until the triangular arrow indent on the driveplate is visible through the access hole.
  4. Install the Crankshaft Setting Peg JD 216 into the CKP sensor location.
  5. Install the Camshaft Locking tool JD 215 on the camshafts.
  6. Remove or disconnect the following:
    • Camshaft sprocket mounting bolt by loosening it
    • VVT mounting bolt by loosening it
    • Camshaft Locking tool JD 215
    • Primary timing chain tensioner and backing plate
    • Primary timing chain guide
    • VVT unit and exhaust camshaft sprocket
    • Secondary timing chain tensioner and guide
    NOTE: Keep all valvetrain components in order for assembly. To install:
  7. Prepare the timing chain tensioners for installation by using a paperclip or other wire to unseat the check valves and compressing the pistons into their bores.
  8. Install or connect the following:
    • Secondary timing chain guide. Tighten the bolt to 89-124 inch lbs. (10-14 Nm).
    • Secondary timing chain tensioner. Tighten the bolt to 89-124 inch lbs. (10-14 Nm).
    • VVT, secondary timing chain and exhaust cam sprocket
    • Primary timing chain guide. Tighten the bolt to 10-12 ft. lbs. (13-16 Nm).
    • Primary timing chain tensioner and backing plate. Tighten the bolts to 89-124 inch lbs. (10-14 Nm).
    • Primary timing chain slack, eliminate it by placing a wedge between the primary timing chain tensioner and the guide shoe
    • Secondary timing chain by applying counterclockwise force to the exhaust camshaft sprocket. Fig. 4: Apply force in a counterclockwise direction when tightening the sprocket mounting bolts - 6 cylinder 9301jg03.gif
    • Exhaust and intake VVT sprocket bolts. Tighten them to 85-92 ft. lbs. (115-125 Nm).
  9. Remove the tools and wedges.
  10. Install or connect the following:
    • CKP sensor
    • VVT sensor
    • Coolant outlet pipe
    • ECT sensor connector
    • Radiator and heater hoses
    • Valve cover
  11. Fill the cooling system.
  12. Start the engine and check for leaks.
Jan 28, 2011 | 1999 Jaguar XK8
My 2001 jeep grand Cherokee will not start don?t know why no codes are coming up put new cam sen, crank sen, coil pack, new ecu, new coolant temp sen, it turns over but will not run has injector pulse and...
Timing Chain, Sprockets, Front Cover and Seal REMOVAL & INSTALLATION 2.5L and 4.0L Engines
    • Cooling fan and shroud
    • Crankshaft damper
    • Accessory brackets
    • Front cover
    • Oil slinger
  3. Rotate the crankshaft so that the timing marks are aligned. Fig. 1: Timing chain alignment marks — 2.5L and 4.0L engines 7924pg20.gif
  4. Remove the timing chain and sprockets. To install:
  5. For 2.5L engines, turn the timing chain tensioner lever to the unlock (down) position. Pull the tensioner block toward the tensioner lever to compress the spring. Hold the block and turn the tensioner lever to the lock (up) position. Fig. 2: Timing chain tensioner — 2.5L engines 7924pg19.gif
  6. Install the timing chain and sprockets with the timing marks aligned. Tighten the camshaft sprocket bolt to 80 ft. lbs. (108 Nm) for 2.5L engines or to 50 ft. lbs. (68 Nm) for 4.0L engines.
  7. For 2.5L engines, release the timing chain tensioner.
    • Oil slinger
    • New front crankshaft seal to the front cover
    • Front cover, using a new gasket
    • Timing Case Cover Alignment and Seal Installation Tool 6139 in the crankshaft opening to center the front cover Fig. 3: Timing Case Cover Alignment and Seal Installation Tool 6139 — 2.5L and 4.0L engines 7924pg21.gif
  9. Tighten the front cover bolts as follows:
    1. Step 1: Cover-to-block 1⁄4 inch bolts to 60 inch lbs. (7 Nm)
    2. Step 2: Cover-to-block 5⁄16 inch bolts to 16 ft. lbs. (22 Nm)
    3. Step 3: Oil pan-to-cover 1⁄4 inch bolts to 85 inch lbs. (9.5 Nm)
    4. Step 4: Oil pan-to-cover 5⁄16 inch bolts to 11 ft. lbs. (15 Nm)
    • Crankshaft damper. Tighten the bolt to 80 ft. lbs. (108 Nm).
  11. Start the engine and check for leaks.
Jul 30, 2010 | 2001 Jeep Grand Cherokee
Bolt on crankshaft to remove clockwise or counterclockwise?
prev.gif next.gif Crankshaft Damper/Pulley counterclockwise to remove pulley:
  1. Remove the drive belts from the crankshaft damper.
  2. Remove the crankshaft damper-to-crankshaft bolt. Hold the crankshaft stationary by placing a suitable tool in the ring gear teeth on the flywheel. Fig. 1: Use a breaker bar to remove the crankshaft damper bolt 89613g41.gif
    Fig. 2: The crankshaft can be held stationary by using a suitable tool to place between the flywheel teeth 89613g42.gif
    Fig. 3: Be sure to lubricate the threads of the crankshaft damper bolt to obtain a proper torque reading 89613pi9.jpg
  3. Remove the crankshaft damper from the crankshaft by pulling it straight off the shaft. A puller may be required to remove the damper from the shaft. Be careful not to lose the woodruff key when removing the crankshaft damper. Fig. 4: The crankshaft damper can sometimes be pulled from the shaft by hand 89613pj1.jpg
    Fig. 5: A puller may be required to remove the crankshaft damper 89613g40.gif
    NOTE: If working on a VE30DE or VQ30DE engine, it would be a good idea to replace the crankshaft oil seal when the crankshaft damper is removed. Fig. 6: The timing chain cover oil seal should be replaced whenever the crankshaft damper is removed; this seal is leaking severely 89613pj2.jpg
    Fig. 7: This crankshaft damper may have a problem sealing properly due to the groove that was worn into it from the seal 89613pj4.jpg
    To install:
  4. Install the crankshaft damper onto the shaft, making sure the woodruff key is in place. Dip the damper bolt in fresh oil and torque the crankshaft damper-to-crankshaft bolt to the following specifications:
    • VG30E engine — 90–98 ft.lbs. (123–132 Nm.)
    • VE30DE engine — 123–130 ft.lbs. (167–177 Nm.)
    • VQ30DE engine — 29–36 ft.lbs. (39–49 Nm.) followed by 60–66°clockwise angle torque
  5. Install the drive belts to the crankshaft damper; be sure to properly set belt tension.
Jul 08, 2010 | 1996 Nissan Maxima
Mar 14, 2009 | Poulan Garden
Compression Poulan chainsaw
Jan 05, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I just replaced the piston ring on my poulan chainsaw it now has good compression but im not getting any gas to the piston area and if i shoot starting fluid to it. it dont even hit and try to start. i...
the engine is not sealed properly
check the gasket(seal glue)at crankshaft and other gaskets
check the carburator,clean it,inside there is a fine gas filter,check the needle,the diafragm,the fuel pump,the gas tube from the gas tank and the gas filter from inside the tank.
regards Mihai71
Nov 26, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
48 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
