Question about Kenmore 76129 Air Conditioner
Replacing fan motor friedrich window air conditioner
How to replace fan motor friedrich window air conditioner
2 Suggested Answers
roniecon
  • 6927 Answers
SOURCE: WINDOW AIR CONDITIONER DOES NOT WANT TO START UP
Most likely ,and I am just guessing ,with out being there,that the start capacitor is bad.On these newer models, the run and start capacitor for the compressor and the fan are all in one,really a better design,cause no guess work,just replace one capacitor,and that takes care of both problems in one.Hope this helps.
Posted on Aug 20, 2009
Show drain hole on bottom of Friedrich window unit
it gets rid of condensate by a slinger ring on fan motor throws it up on condensor and evaporates it.
Oct 09, 2013 | Friedrich QuietMaster KM24L30 Wall/Window...
Fan motor squeels
sounds like bearings, open it up and make sure fan turns free and smooth, if not replace motor
Apr 10, 2013 | Friedrich QuietMaster RS12J10A Air...
How to replace coolant in air conditioner...
fan motor is bad stuck or relay or capictor if fan dont pull air thru condensor it does not turn to liquid and then wont evaporate or cool in evaporator
Aug 28, 2012 | Friedrich QuietMaster SM24L30...
Fan not working on friedrich yl24
try to open and check or test the fan motor with tester and check the wire to the fan motor if power is working.
Jul 01, 2012 | Friedrich Heating & Cooling
After turning the unit off, there is a hum for a few minutes, no fan noise, just a hum, and then it turns itself off eventually. The unit is about three years old and is otherwise cooling the room.
From what you have described, it sounds like the fan motor may be seized. In which case, it should be replaced. Depending on the age of the unit, it may be better to replace it than repair it. As parts and labor to repair it, can be almost as much as purchasing a new unit. As the motor assembly alone, runs about $150.00 + Labor.
I hope this has helped you and thanks for choosing FixYa.
Aug 10, 2011 | Friedrich CP10C10 Wall/Window Air...
Fan will not work.
Hello, if the fan does not work it is most likely a bad capacitor or bad fan motor. Replace the capaitor first since it is inexpensive
May 25, 2011 | Friedrich QuietMaster Electric SS10J10AR...
Just installed a new Friedrich CP06C10 window air conditioner that I purchased from J&R. Turned it on and it makes a loud rattling sound. I installed a Friedrich CP08C10 window air conditioner in...
its the fan hitting the shroud, look inside for the fan hitting anything and check for the copper lines vibrating against each other, also, it could be the plastic front vibrating, put your hand on the front to see if you can stop it,
Apr 17, 2011 | Friedrich CP06C10 Wall/Window Air...
Fan not working
some fan motors have a start capasitor, some have a run capasitor and some have both. if you take out the capasitors (normally in the junction box) take note of which wires go where and head to a refrigeration spare parts wholesalers they should be able to give you the right ones then replace them. this shouldnt cost any more than $20 if that doesnt work you will need to replace the motor.
Aug 06, 2007 | Friedrich SL24J30 Air Conditioner
Kenmore 76129 Air Conditioner Logo
21 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
