Question about Rowenta DG-980 Iron
What to do when My rowenta steamer spews out steam when I am not using it
jaylex
  • 417 Answers
SOURCE: Rowenta DA75 - Won't Steam
Can you remove the steam button if you can fill with water heat to maximum and holding over sink remove steam button rod this will clean the steam traks but be careful this gets very hot.
Thanks J
Posted on Feb 11, 2008
SOURCE: rowenta commercial steamer
got this off the manual for the IS 7800
CLEANING
Remove water container and clean the main unit with a damp
cloth. To maintain maximum performance, your steamer must
be descaled occasionally. The descaling intervals will depend
on the water quality and the frequency of use. The unit should
be descaled at least once a year or every 100 hours of use.
For descaling proceed as follows:
1. Unplug the unit and remove water container from main unit
by releasing container lock and pulling up.
2. Fill it with fresh water and shake vigorously to remove any
scale. Pour out the water and repeat if necessary.
3. Purchase a quality decalcifier agent and follow the instructions
of the manufacturer for the proper ratio of the mixture
to water and use.
4. After filling the water container turn it up and down to
descale.
5. Attach reservoir to unit, plug in and switch on.
6. Let the appliance run until the water container is almost
empty and do not steam any clothing with this mixture.
7. Unplug and detach the water container. Rinse it with fresh
water.
8. Fill water container with fresh water and repeat steps 5 and 6.
Note: If after descaling you believe that there is still buildup in
the boiler, repeat steps 1-8.
Posted on Oct 31, 2008
SOURCE: My Rowenta Garment Steamer will not steam up.
Ok. This thing is caused by scaling. If the steam generator runs out of water the sensor thinks the tank is empty and causes the machine to go to standby (basically switch off -- orange light comes on). The solution: Open the machine and clean it.
MAKE SURE THE POWER CABLE IS UNPLUGGED BEFORE ATTEMPTING TO DO THE FOLLOWING:
1. There are six screws ( phillips - you will need a long screwdriver). Two of them are hidden under the wheels (just pop off the rollers and you will see the screws)
2. Open the steam generator (there are four screws) and be very careful with the 'O' ring -- you damage it and you can say good bye to the machine. Clean it if you see scaling. The amount of scaling present would indicate how hard your water was. This itself may not be cause of the problem but now that you openend the machine, you might as well as clean it for better efficiency.
3. Disconnect the hose to the steam generator (it has two circlips) and clean it. Mine had hard deposit of scales preventing the water reaching the steam generator.
Re assemble it.
Good Luck
Alex0714
Posted on Apr 10, 2009
  • 258 Answers
SOURCE: I have the IS7500 verticle steamer by Rowenta.It
sounds like the level of the water is below pick up tube u should be able to re adjust the pick up tube
Posted on Feb 12, 2010
  • 23 Answers
SOURCE: Cleaning a Rowenta steam iron
According to the manual, you should use regular tap water as long as it is not above 12 grains of hardness. Never use 100% pure distilled water, Rowenta recommends using inexpensive bottled spring water.
Posted on Jul 19, 2010
Rowenta garment steamer is 9100 lights up but no steam
Look at the manual again maybe theres a button that you have to turn on. Or call the nearest repair man maybe he knows or can tell you.
Dec 26, 2012 | Rowenta Commercial Garment Steamer - White
ROWENTA STAM IRON - NO STEAM !!!!
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
May 22, 2010 | Rowenta Commercial Garment Steamer - White
Need replacement water tank due to a crack that leaks for the Rowenta 8050 steamer
krups bought out Rowenta. contact them at http://www.krupsusa.com/ to see if they have the parts or know where to get them
please take a moment to rate this solution. thanks
robert
Nov 23, 2009 | Rowenta Commercial Garment Steamer - White
How to use a steamer.
  1. Plug in the steamer.
    • The steamer usually comes with a smallish padded square with a strap that slips over your hand. (If you so not have one of these, cut out a square from some stiff cardboard, pad it using cotton batting, and cover it with a heavy, smooth, waterproof or water-resistant material.)
  2. Make sure it is steaming nicely before you use it. You check by pulling the little trigger on the handle, and seeing how much steam issues when you release it. You actually want to use this while steaming as well, in order to release more steam when needed.
  3. Hang the garment, and slip the padded square over one hand.
  4. Place the hand with the square on the underside of the garment, and use it to keep the fabric smooth while you steam it.
  5. Use the steamer by holding the nozzle close to the garment, and pulling both it and the padded square in downwards strokes.
Sep 18, 2009 | Rowenta Commercial Garment Steamer - White
Is there a product to run through a rowenta pro garment steamer to eliminate build-up?
To start with, use distilled water for steaming. This will prevent calcium build-up. I buy bottles of distilled water for ironing/steaming only. I have never had calcium build-up from using distilled water for ironing/steaming. Do not use tap water!!!
You can buy some CLR (stands for Cacium, Lime & Rust) (can be found at Walgreens, CVS, Target, Walmart, etc.). You can run this product through your steamer to eliminate build-up.
May 14, 2009 | Rowenta Commercial Garment Steamer - White
Rowenta Steamer
Same thing with my daughter's..any solution out there?
Jun 22, 2008 | Rowenta DZ9080 Iron with Auto Shut-off
Rowenta DG-980 Iron Logo
90 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
