Question about Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus 7-Cycle Gas Dryer - White
What does the f25 error code mean - Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus 7-Cycle Gas Dryer - White
2 Suggested Answers
SOURCE: F25 error code
this is scary. I got a brand new whirlpool duet sport I ordered from Costco.com. After 19 days of waiting for delivery it finally arrived and was installed by the whirlpool dlvy people. I read the instructions and started my 1st load within an hour of being installed. It never worked. Ok it work 6 mins and stopped on every cycle I put it on and then I got the error code 25. I called their customer svc number and they could not even tell me via the phone what that meant. I am suppose to have another delivered here HOPEFULLY next week but after seeing others having repeated problems I do not know if I should just say no take it all back.
Posted on Jul 26, 2008
Code F25 on my whirlpool washer
F25 is a MOTOR CONTROL error . check for past posts in Search as there were some in 2007 shown on Fixya . or check throgh Google / Internet explorer by stating F25 Washing Machine error
Jan 09, 2018 | Whirlpool Washing Machines
Whirlpool Duet Washer error f25
have whirlpool duet washer showing f25 code checked all connectionshave bare wires showing on rpm sensor on end of motor separated them and still showing code what else can i do
Oct 28, 2017 | Whirlpool Washing Machines
Error code f25 replaced inlet thermador
call a repairman we do not know what you have .
Mar 16, 2016 | Washing Machines
What the F25 code
Please, head over to this link, it explains by a regular user on what F25 means and it have pictures.
http://neighboursappliance.com/f25-on-a-duet-washer/
Sep 22, 2015 | Whirlpool Dryers
F25 error code
The "F25" error code means the control board senses the inlet thermistor shorted. The inlet thermistor is a part of the hi-limit thermostat which is located on the heating element box.
- The hi-limit thermostat kit Part number: AP3094323
Read more: http://forum.appliancepartspros.com/dryer-repair/54078-whirpool-duet-dryer-error-code-f25.html#ixzz2n2Rmgm7a
Dec 10, 2013 | Whirlpool WED9400S Electric Dryer
Front loader maytag stop in middle cycle give error F25
Remove your service panel and look for your tech sheet inside a jacket in the inside of the service panel. An F-25 is usually a broken wire between the main control and the motor control.
Oct 09, 2011 | Washing Machines
I have a Kenmore H2 Plus washing machine. I get an error message that says "F25". What does this mean?
F25 indicates a possible drive motor tachometer error.
Remove
front lower panel-2-3 screws at the very bottom the tech sheet is located in a plastic pouch.
The f25 error code is a motor tachometer error. To determine the problem you will have to remove the top cover and the front access panel. On some models, the rear panel will have to be taken off for easier access to the motor control. Now with the washer-unplugged remove the each plug one at a time and make sure the pins in the connector are not bent then reseat them on the board. Now retest the washer. If the washer still fails, you will need a meter to ohm the motor.
Jun 07, 2011 | Washing Machines
Fault code F25
If you remove three screws along the bottom front the bottom panel comes off.
On the inside, on the right wall, is a plastic bag with a paper labeled "FOR SERVICE TECHNICIAN ONLY".
This has a section titled "FAILURE/ERROR DISPLAY CODES" with all the error codes along with an explanation and recommended procedure. For F25, this is:
DRIVE MOTOR TACHOMETER ERROR
If the control is unable to properly detect motor speed, the machine shuts down.
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
Possible Causes/Procedure
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
2. Unplug washer or disconnect power.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
I got this working for many on this site :)
Thanks
Fame !
Apr 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F25 error code
Hello twelsh2
Welcome,
You said, you started my washer and after a few minutes I'm getting this F25 code. Water starts to go in but it never starts washing. Any thoughts?
This is what F25 is telling you.
Condition
If the control is unable to properly detect motor speed, the machine shuts down. If a failure occurs during high-speed spin, the door unlocks after 3 minutes.
Check and Repair
1. Verify the shipping system including shipping bolts, spacers and cables are removed.
2. Unplug washer or disconnect power for 5 minutes (Rests the system)
3. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations
If you can not find the fault , Please call service.
We have service sponsors available in your area here in our web site if you need one!
Let me know what you find!
Huuum
Please remember to leave a rating!
Sep 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus 7-Cycle Gas Dryer - White Logo
204 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
