Question about Watches
How do i understand my china module fmd watch?
Plastic bezel 1312 fmdaw016 v398 battery cr2025 china module fmd
3 Suggested Answers
  • 155 Answers
SOURCE: Broken watch band. Where can I get replacement?
Hi
You could browse throgh the internet maybe you can find your replacement,or you could check it on ebay.
You could also get to any wristwatch store around you to look for it in order to get the right one.
BEST OF LUCK
Posted on Aug 06, 2010
SOURCE: I have an Alarm Chrono
Press and hold the mode button which is the bottom left button. You can then use the reset button (bottom Right) to cycle through the min, hour, date, year, day and so on and use the start/stop button (top right) to change the corresponding number. :) Hope that helps!
Posted on May 01, 2011
What size battery for a FMD PU003 watch?
Can you open it to replace battery?
If you can open, you can take note about the battery it has
May 31, 2015 | Watches
Hour, minute and second hands don't work, why?
Yes, there are two batteries in the 19093 (Compendium Hybrid). The first battery (CR2025) is visible as soon as you remove the back cover plate. The CR2025 controls the digital half of the watch and the back light. The second battery is underneath the circuit board that the CR2025 is connected to. There are 6 small screws that will need to be removed to lift the circuit board and gain access to the second battery. The second battery is an SR626SW.
Aug 22, 2014 | Watches
I have an Alarm Chrono stopwatch and I can't rememeber how to set the time and alarm. I'm not sure what the serial number is so here is everything on the back: FMDAW523 107 BATTERY CR2025 CHINA...
Mar 22, 2011 | Watches
Need to change battery in EH23sa
The battery is actually accessed from the front of the watch.
You should have a "Case Knife" to remove the front bezel.
Remove the band first.
Set the watch in its side. Set the case knife at the groove where the watch band holder meets the front bezel, and give the back of the knife a sharp rap with a small hammer. The front bezel should pop off.
Some watches have a small circular plastic piece that will also come out. Gently remove the movement from the front. The battery (CR 2025) can then be removed from the back of the movement using a small, thin blade. Install the new battery. The inside back of the case should have restart instructions. (Push A -left button once. then push and hold A until hands move to 12:00. Push B once to start reception.
The back of the watch is plastic. Don't try to remove it.
Gently re-assemble movemengt. A watch case press tool is best for finishing assembly. I would suggest taking the watch to a jeweler if you are uncomfortable taking this watch apart. Good luck
Mar 21, 2011 | Watches
How do you change battery on E Howard wrist watch, how does bach come off?
The back does not come off (case is in one piece); it's the bezel -- the metal rim that holds the front glass crystal.
There is a small notch in the rim of the bezel (on mine, this aligned with the 'lower left' lug on the case around 7:00 on the face). Be careful as there is an O-ring to waterproof the watch, and this notch goes right into the groove where that O-ring is located. Use a case knife or similar stiff but fairly thin-edge blade to pop the bezel off (it snaps off). Then gently remove the outer plastic ring, noting carefully how the notches are aligned.
The inner module now can be lifted carefully out - the two 'pushers' will not fall out of the case when you do this. The battery is a 3V lithium CR2025, and you will need a fairly small straight-blade jeweler's or optician's style screwdriver to remove the one screw that holds down the battery bracket - it may be tempting to bend this out of the way to change the battery, but please resist that temptation...
Put the module back in the base, put the ring back over the dial plate, and carefully snap the bezel back in place with its notch aligned as you found it. You might want to check and/or lubricate the O-ring as you do this.
Instructions for initializing the movement are printed inside the case: they list the switch for the 'recessed' button as A, and the pusher as B. In case you didn't note them before closing the case: to reset:
1) push A once. (Display will read "SET"
2) Push A until hands are exactly on 12:00 (and display reads "12"
3) Push B once to start reception
You then follow the standard procedure of putting the watch in a window facing Fort Collins, Colorado, until it picks up the time signal and synchronizes itself.
If you need more assistance with the physical module, there is contact information on it from its manufacturer:
artcoadm@pacific.net.hk
Model number on my module is AR600 WWVB (37.5mm)
Nov 18, 2010 | La Crosse Technology E. Howard Ambassador...
Can't set the watch china module fmd fmdaw015
http://forums.watchnet.com/index.php?t=tree&goto=110449&rid=0
I know isint the same watch number but it worked for me no problem!
Nov 10, 2010 | Watches
Watches Logo
656 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
