Question about Fujitsu ScanSnap S500 Pass-Through Scanner
A vertical line appears on my fujitsu scanner
There is a red vertical line appearing on the right side of my scanned document. i cleaned it so many times but the line is still there
SOURCE: how to scanning double sided document in fujitsu 5120c scanner
You may want to try using Laser Fiche. This scanning software allows you to select "Duplex" which allows you to scan double sided document
Posted on Nov 29, 2007
shaggyrat
  • 1224 Answers
SOURCE: scanning document
i had the same thing happen to me i went threw every thing and cleaned and still was there i came to realize that it wasnt the scanner but the software pdf that was being used the seriously took me by surprise so i went out and installed a fresh copy of pdf writer this resolved my problem with the pink markings
i hope this was of some use
Posted on May 26, 2008
SOURCE: scanning a black vertical line down the left side of the document
funny thing. I cleaned it. I had looked before, but didn't see the line on the surface of the glass so i thought it was internal. A closer 2nd look revieled a distinct line on the surface of the glass, probably from pen or marker ink that wasnt dry.
Scanner repaired, pride slightly damaged. thanks for the response
Posted on Jul 23, 2008
  • 3278 Answers
SOURCE: I have a Fujitsu fi-5110C
Hello, Jim.
The most common cause is from a particle of ink or dust that is attached to the lamp or the glass covering the lamp. As the page runs over the lamp, it registers that spot as black and causes a line to run the length of the page.
To fix this, simply remove the particle from the glass or lamp. The location of the particle will correspond to the location of the line on the page. So note which side of the page this occurs.
Here's an article from eHow regarding cleaning the scanner glass: http://www.ehow.com/how_14267_clean-scanner.html
Pay attention to that black particle.
Hope this helps.
Posted on Sep 07, 2010
  • 610 Answers
SOURCE: I have a solid line
You need to open up the unit and clean all pieces of glass. There is something on the glass causing the line.
Posted on Aug 04, 2011
Testimonial: "Solution bang on - I did already wipe glass but obviously not very well. Brilliant feed back with lightening speed."
Vertical line appears on scanned item
Clean the glass and wipe any residue off the rollers.
Aug 14, 2014 | Fujitsu ScanSnap iX500 - document scanner
I have a solid line appearing top to bottom down one side on documents after I scan them, how can I remove it
Aug 04, 2011 | Fujitsu ScanSnap S1500 Instant PDF...
A thick black vertical line appears whenever i
you have a problem in your scanner assembly, clean or replace it
Apr 03, 2010 | HP Officejet 4355 All-In-One InkJet...
The scanner makes unwanted vertical lines down the document
Clean Optical path to camera lenses back and front, then Calibrate through the Kodak SVTool.
Oct 06, 2009 | Kodak i260 Duplex Color Scanner
Xerox WorkCentre 4150, 3 vertical white lines in all feeder scans
the problem is in the scanner, open it up and see if you can find any smudges, and clean any obstruction, any ink, liquid eraser residuals, can cause this part to appear as lines on your copied faxed image.
dont concentrate on the printer this is a scanner problem
Jul 28, 2009 | Xerox WorkCentre 4150/X Laser Printer
Vertical black line when copy with Koda ESP 3
Some dust particle or something might have been stuck on the scanner. Try cleaning the scanning glass
May 19, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Red vertical lines, scanning to computer
I had one red line appear when i used the duplex. I happened to notice that the thinner glass window on the scanner was dirty. I cleaned it and now no line appears.
Nov 24, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Print Problem - vertical lines
If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
Feb 23, 2007 | Brother MFC-7820N Laser Printer
Scanner inserts vertical line on some documents
Clean the glass with IsoPropyl Alcohol. Dont use any other solvent. A speck of dust stuck to the glass can give a continuous line in the output
S. Mohan
Sep 29, 2006 | Canon DR-1210C Scanner
Fujitsu ScanSnap  S500 Pass-Through Scanner Logo
51 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Tony
Jax Planet
Jax Planet
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
