Question about Microsoft Xbox 360 Console
Hard drives i belive my hard drive is rooted! when i first bought halo3 an error msg came up that it was unable to read disk i then tried to format my hard drive and it told me that there was a problem proforming that i had to try and try bout 6 times before it worked and even after that the problem persists with halo3 so i tried with a mates hard drive and it worked perfectly is there anything else i could try please help them xbox call centre **** are useless!
  • 4,402 Answers
same problem with my xbox 360 disc read error. tried reformatting hard drive did not work tried initaly set again did not work. the only thing that works is t physically remove the external hard drive but, having to do that is a bunch of bull you cant use your profile and you cant go online with out it. we spend so much money on something that is suppose to work and fails. it makes me want to go back to playstation 3 and forget that there ever was an xbox, because micro soft is not willing to do anything to correct the problem.
Posted on Dec 12, 2007
When computer boots up I get this error code A disk read error occured code 0F00:0666
A bad hard drive or the boot sector (the map of the hard drive contents) has an error.
You have two choices. If you run regular backups you can do a full restore including the boot sector, if not, you'd have to format the hard drive and lose your data. Then reinstall Windows and start from scratch.
The other option that loses your data, as well, is replacing the hard drive if it's defective.
Mar 09, 2014 | Seagate 500GB Barracuda 7200.12 SATA...
Hello-:~) i just wanna ask why is that my transcend is unable to format whe i use to click the format windows unable to complete format will appear?? how can i format my USB
You are plugging it in, going to windows, right clicking the drive - format - quick format and its not working?
Try right clicking the drive, going to properties, and run the error checking or disk checking for errors. Windows can attempt to clear the problem.
Jan 25, 2011 | SanDisk 1GB Cruzer Titanium USB Flash...
I have a 2GB scandisk pendrive, I unable to format it, Whenever i tried to format it in command. Msg appered IOCTL call error. how can I format it. Pl help me
Try formatting the flash drive using this method.
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Oct 22, 2009 | Transcend (589307) Media
Unable to format the cruser pendrive
Far too often these little things have an almost invisible read/write protect button on them. Look carefully, over the entire surface of the USB Flash Drive. You might have this switch turned to Write Protect, which means there is nothing you can do, until you turn it the other way, and allow the device to be written to.
May 22, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Windows was unable to complete the format
u dont need to buy a new one. You can download file shredder from here . do following things :
  1. download and install file shredder
  2. shred all the files which are in pendrive(after shredding u will not be able to recover them)
  3. then try to format it .,
thankyou for using fixya
dont forget to rate the solution
have a nice day
Mar 12, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Setup was unable to verify drive C:.
hi ;
this sems to be a memory problem;
in bios , try to decrease the memory for your card to resrve a memory space for the installation program,
if this does not work , it might be your VGA card.
Mar 11, 2009 | Computers & Internet
Hard disk failure
Hi, assuming the hdd won't finish a format, it is possible that some sectors are damaged. If you still want to try and use the hdd even with these defects, you can try and partition the hdd. Guesstimate at what point the hdd stops responding and really guess where the defects end. With this info, partition the hdd into 3 with the middle containing the defective sectors. Format only the first and third partitions. For simplicity, Win98 might be easier to work with rather than XP. Hope this be of some help. Do post again and let us know how things turn up.
May 05, 2007 | Seagate Barracuda ATA IV (ST340016A) 40 GB...
Microsoft Xbox 360 Console Logo
67 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
