Question about 1992 Mazda B2600 Truck Manual Window Regulator Pair
I have a 1993 Mazda 4 wheel drive and the brakes are hanging up do you think it is the master?
I have taken the wheels off and all 4 seem to be hanging up with pressure
  • 1A Auto Parts Master
  • 2,210 Answers
My guess is the servo is not functioning properly, hence its holding the brake pressure after you release the pedal. Look in this area by exhausting the servo with the engine off, several pedals should do it. Then see if its not just the pedal seizing up on its pivot. There is a valve in the servo to release the line pressure but most are not accessible or repairable. Easiest thing might be to get another from a yard and swap it. Try and swap it without breaking into the hydraulics to reduce time and hassle.
Posted on Jul 30, 2014
1993 4wd. Why aren't brakes working?
Does the brake pedal go to the floor? Or does it stay up, and is hard to push...? Did you bleed the master cylinder? Also, you will need to bleed all 4 wheels connection to the brake wheel cylinders...you must start with the rear, farthest from the master cylinder, then other rear, then front farthest from the master cylinder, then other front...the bleeding of each line is a must, since you switched the master cylinder.
Sep 14, 2015 | GMC Sierra 1500 Cars & Trucks
I recently had new brakes installed on my 2004 Toyota Tacoma. No problems for a couple weeks. But now, frequently the brakes seem to stick, and after driving you can smell burning from the front brake...
This is probably not a master cylinder problem, but a mechanical issue with the front brake calipers. I would return to the shop that did the brakes and have it inspected. Possibly the pads were not installed correctly or the slide pins were not repaired/rebuilt during the brake change.
Feb 02, 2015 | Toyota Cars & Trucks
Adjusting brakes 1988 mazda capella
You are adjusting brakes, or need to know how to adjust brakes. In general, in between the two shoes on the back there is a screw with a star wheel on it that gets turned with brake pedal is pressed. Sometimes this screw hangs up from lack of turning and needs to be taken apart and lightly lubed. There is usually a plug that can be knocked out in the backing plate behind the shoes so this star wheel can be turned from under the car. Most cars if this screw is turning free can be adjusted tighter by simply backing up and pressing the brake pedal several times. That will keep pushing the star wheel and adjust the brake shoes out. I am talking about rear brakes in general and am thinking that the Mazda has some simularities.
Dec 25, 2011 | 1988 Mazda 626 Turbo
The rear brakes seem unable to bleed. i think the proportioning valve bad.
You are correct in assuming the proportioning valve,but it may not be bad,if it detects,loss of fluid pressure,it will shut down those brake lines.Try bleeding the master cylinder,then the wheels,and you may have to do it a couple of times,this will allow the proportioning valve allow the wheels with fluid pressure,if this was at all helpful,please rate,thank you,
Jun 27, 2010 | 1992 Mazda MPV
How do I replace the front brake pads on my 2009 Mazda 6 2 litre? Can I do it myself?
Step 1 Park the Mazda 6 on a flat surface. Put the emergency brake on and put wedges behind the wheels to prevent the vehicle from rolling. Disconnect the negative battery cable. Using a syringe, turkey baster or similar tool, drain two thirds of the brake fluid from the master cylinder. Remove the wheel.
  • Step 2 Remove the bolts attached to the brake pipe. Remove the bolt cap attached to the caliper top. Swing the caliper, pivoting it downwards. Suspend the caliper from the frame using mechanics wire. Remove the M-springs, the pads and the shims.
  • Step 3 Press the caliper pistons back into the cylinders. Install the brake pads. Lubricate the exterior of the pads using anti-squeal. Install the shims. Install the M-Springs. Reinstall the caliper. Using a torque wrench torque the bolt to 36 to 39-ft. lbs. Install the cap.
  • Step 4 Reinstall the wheels. Add brake fluid to the master cylinder. Bleed the brakes. Reconnect the negative battery cable to the battery. Start the engine and pump the brakes 3 to 4 times to seat the brake pads. Test drive the Mazda 6 at slow to moderate speeds to ensure that the maintenance was performed correctly.I hope this helps you and please have a merry xmas
  • Dec 18, 2009 | 2009 Mazda MAZDA6
    Bleed brakes
    To bleed the brake system open all the bleeders and let the system gravity bleed for @ 1/2 hour ensuring the master stays full. Then close all bleeders and starting furthest from the master (r/r) have someone pump the brakes 2-3 times,hold the pedal down, then open the bleeder,close the bleeder,and repeat untill there are no air bubbles and the brake fluid is running clear .Repeat for all wheels in this order R/R L/R R/F L/F ensuring master cykinder does not run empty. You cannot pump the pedal with a bleeder open you will be sucking air back into the system. Once you finish all wheels repeat to ensure there is no air remaining in system
    Apr 17, 2009 | 1993 Mazda 626
    May be CV joint?? When making tight turns, wheel problem.
    i think youre on the right track with an outer axle joint
    Nov 18, 2008 | 2002 Jeep Grand Cherokee
    No brake pedal
    The fluid could be leaking into the power brake booster.
    Nov 12, 2008 | 1993 Mazda Protege
    1992 Mazda B2600 Truck Manual Window Regulator Pair Logo
    52 people viewed this question
    Top 1A Auto Parts Vehicle Parts & Accessories Experts
    Tom
    Mike Stager
    Mike Stager
    Are you a 1A Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
