Question about JVC AV-27950 27" TV
Sanyo st-21sy1z power is not triggering the voltage
Sanyo tv st-21ms22b cant turn on with remote red light blink once and nothings happen.
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
May 14, 2016 | Sanyo Televison & Video
How to fix sanyo ST-21SY1Z won't turn on,the power run up to the transformer but no video and sound
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window, to get gathered some pages which has the details of practical experiences to the author of that site.
Sep 07, 2015 | Sanyo Televison & Video
Sanyo st-21vf1 power supply
What do you want to know about this power supply? Provide more details, please.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 30, 2014 | Sanyo Televison & Video
Sanyo tv model # st-21ys2 defective system ic
sir may ginagawa akong tv ang trouble nya. pag on mo ng tv after mga 2 to 3 .minutes nawawala na ang sound tpos pag pinatay mo at pag plug mayron uli sounds tpos nawawala uli sound buo ang i.c sanyo st 21ys2
Apr 15, 2013 | Televison & Video
Sanyo st-21cf1 auto increase and decrease volume
bro my probleme ako may b+ pero wlang tao tapos maliit lang hindi naman sira ang vertical IC
Jun 13, 2009 | Sanyo DS25390 TV
My Sanyo DS32225 worked fine for about 20 hrs.,then NO Picture at all. The sound works fine and it will change channels but not even the menu will come up on screen. Whats up?
they are two things to check, the power supply has a voltage of 90-110volts which triggers a line transformer to oscillate,
firstly check that voltage if that voltage is there then check the line transistor.
Apr 22, 2009 | Sanyo DS32224 TV
Model: CM21AF8A
the picture is produced by the following,
check the power supply, making sure that a high voltage is produced of about 90-110 volts, which later triggers a line transformer to oscilate.
a power supply is suppose to be checked expecialy semi conductors and diodes, also fusible resistors be checked make sure that the switch is okay power is passing through it.
Apr 12, 2009 | Sanyo DS32224 TV
Repair st-21sy1z
Please check zener diode D661. I f this is short, your power can not initiate. Hope this one can help.
Jan 30, 2008 | Televison & Video
Problem with Sanyo ST-21KX2 it shuts off automatically
I HAVE A PROBLEM WITH SANYO ST-21KX2. WHERE CAN I DOWNLOAD A DIAGRAM?
Oct 08, 2007 | Televison & Video
JVC AV-27950 27" TV Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
