Question about Raypak Digital ASME 337A 332,500 BTU for NG Low NOx
My above ground Raypak 337A heater won't ignite.
Gas is on. Heater hasn't been turned on in 6 months. I hear ignitor sparking. SPK digital reading on. After 1 minute, I turn off.
    Top Expert:
  • Raypak Master
  • 5,779 Answers
Try a couple more times flame sensor might be damp or take it out and clean it sometimes rusty
Posted on May 14, 2016
  • 246 Answers
SOURCE: When I turn on my gas heater it keeps sparking and
check the gas valve for and on possition after that if still doing the same check if the wire if is touching metal (ground)
Posted on Aug 19, 2009
  • 990 Answers
SOURCE: Back flare on Raypak pool heater
You will need to pull the burner tray out and clean and blow out the burners. Then you will need to pull the orfaces from the gas manifold and clean each one and blow out the gas line. Then with a mirror you will need to check the fire brick inside the burner box. Then you will need to replace anything that is damaged. Good luck.
Posted on May 15, 2010
Testimonial: "thanks for the insight. I assume that I will have to disconnect the gas line and then reconnect afterward. Appreciate your information."
  • 767 Answers
SOURCE: I have a Raypac digital
Hello my name is Heath it will be my pleasure to assist you. Find the rollout switch and on the back there is a small red button if you push the button in it will reset the switch. The rollout is usually located near the burner section of the heater.I will attach a picture of a rollout switch which shows the small red button.11c0d2e.jpg
Posted on Oct 25, 2010
  • 2187 Answers
SOURCE: Hi, The pilot won't light
I am thinking it could be the relay. The relay directs the power to the device. In most devices it is the one that makes the 'clicking' sound.
Posted on Apr 10, 2011
Therinnaiguy
  • 1420 Answers
SOURCE: gas ignitor bypass for raypak heater?
to test the pilot, you can use a torch to keep the sensor hot. if it still won't stay on, you have a bad flame sensor sometimes called either a thermopile or thermocouple. very easy to replace.
Posted on Mar 13, 2012
Heater is cycling on and off, less then one minute cycle time between cycles. Sometimes SPK code comes on and stays on without firing. Have shorted water press switch with no effect. Pretty sure gas...
The SPK Code, indicates that there is power to Igniter and should be producing a Spark to ignite fuel! If this is actually the case, then it is NOT a safety sensor issue, The igniter serves a dual purpose: produce a spark, and then CONFIRM a flame is consuming the fuel. If it does not get a proper Milivolt reading, then gas valve will shut off, hence a cycle occurs. Not enough reading is the same to the heater as no reading! Safety issue. If gas valve stays open, and no flame to consume raw fuel, it will build up and accumulate then when ignition takes place, it go...BOOM! Not Good.
Either insufficient fuel supply/pressure or faulty igniter. It's also not a Gas Valve. It's a simple switching valve, either open or closed.
Mar 16, 2015 | Raypak Digital Low-NOx R.337A Heater...
Raypak 2100 fault
It sounds like your ignitor may be out. Everything else is good in the safety loop and the heater wants to fire. The last step in the process is the ignition of the main burner. Are you hearing a ticking sound? If not the spark is not being produced.
Apr 12, 2014 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak 2100 just get SPK then LO codes. won't ignite
if wired 120 volt check wiring and check gas pressure see if lines have cobwebs
Jan 02, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
When we tried to light the heater the CFH shows, then I get a SPK which stays on for aroound 1 minute, then I get a LO. The heater never lites.
The CFH is a Call For Heat.
The SPK tells you that it is creating a spark for ignition.
The LO tells me that you are on propane.
The fact that it doesnt light tells me that either the ignitor is not sparking, or that there is no gas, or an incorrect gas supply.
If this unit is installed with flexible gas line, replace this with rigid black pipe or a larger flex line.
Oct 11, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak Pool Heater
check to see if ignitor is lighting if so check gas line to ignitor if no ignitor replace and check safety circuit
Nov 05, 2008 | Raypak DOOR ASSEMBLY
Raypak Digital ASME 337A 332,500 BTU for NG Low NOx Logo
51 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
