Question about Kicker KX600.1 Car Audio Amplifier
What is the rem termial on a crunch amp - Kicker KX600.1 Car Audio Amplifier
    President:
  • Kicker Master
  • 1,114 Answers
That's what turns the amp on and off with the radio. On your radio you will have either a blue or blue with a white stripe or even pink. Check your decks manual. This wire connects to the amp remote terminal. It keeps your amp from always being on and generating unnessary drain on your battery and heat to the amp. Hope this helps
Posted on Jun 23, 2009
    Problem Solver:
  • 5 Answers
The terminal marked "rem" on most amplifiers (if not all) is for the remote signal.
The remote signal is a low current signal that tells the amp that the carstereo is "ON", this "activates" the Amplifier and turns it off again when the carstereo is turned off, if the amplifier stayed on all the time it would drain your battery while the car is off
so, anyway if your carstereo is enabled to work with an amplifier it should have one wire marked "remote" some brands use a blue wire for such purpose.
If you cant find wich one is the remote wire or you are using an original euipement manufacturer (OEM) carstereo, you need a test licght to check wich wire puts out current when the carstereo is on and switches it off when you turn off the unit, that should be the remote wire.
it is advisable to use that signal to operate a relay instead of directly using the remote wire on the amp, but its more of a security/professional install kind of motive.. so if you understand relays go for it, if not, go ahead and connect the remote to the amp... NOTE: THIS WAY IF YOU SHORT THE REMOTE WIRE YOU RISK DAMAGING THE CONNECTION OF THE REMOTE INSIDE THE HEAD UNIT...
PS: i use carstereo, unit and Head unit as synonyms because english isnt my native language and here we just call them "stereos" but thats just wrong
Not getting power when ignition is on and what is the rem imput for
the rem input (probably a blue wire) is what tells your amp to come on. the power supply is the red wire, that means that the amp is powered. it is not 'on' until the remote (rem) wire is powered. It acts like a power button or switch that is controlled by your unit. there are ways around conventional wiring if you have trouble getting your unit out.
Jan 29, 2011 | Fusion FEW12PK Car Subwoofer
The fallowing script says VBScript runtime error: Path not found if the directory dose not exsists. However the point of the script is to check if the directory exists and if not create it. Option...
I have the solution.
You must create each subfolder in every folder.
Check this script that is working and you must just to adjust for your needs:
Option Explicit
Dim LocalDir
Dim ServerDir
Dim LocalDisk
Dim oShell
Dim strUserName
Dim strHomeDrive
Dim objNetwork
Dim objFSO
Set objNetwork = WScript.CreateObject("WScript.Network")
strUserName = objNetwork.UserName
Set oShell = CreateObject("WScript.Shell")
strUserName = oShell.ExpandEnvironmentStrings("%USERNAME%")
strHomeDrive = oShell.ExpandEnvironmentStrings("%HOMEDRIVE%")
LocalDir = strHomeDrive&"\E810\PD810\Export"
REM msgbox(strUserName)
REM msgbox(strHomeDrive)
REM msgbox(LocalDir)
ServerDir = "\\epcdhe.com\public\profiles\"&(strUserName)&"\E810\PD810\Export"
Set objFSO = CreateObject("Scripting.FileSystemObject")
If objFSO.FolderExists(LocalDir)=false Then
objFSO.CreateFolder(strHomeDrive&"\E810")
objFSO.CreateFolder(strHomeDrive&"\E810\PD810")
objFSO.CreateFolder(strHomeDrive&"\E810\PD810\Export")
End If
If objFSO.FolderExists(ServerDir)=false Then
objFSO.CreateFolder("\\epcdhe.com\public\profiles\"&(strUserName)&"\E810")
objFSO.CreateFolder("\\epcdhe.com\public\profiles\"&(strUserName)&"\E810\PD810")
objFSO.CreateFolder("\\epcdhe.com\public\profiles\"&(strUserName)&"\E810\PD810\Export")
End If
May 26, 2010 | Computers & Internet
What is rem
rem means remote on the amplifier which means your amp will turn on when ur radio turns on the remote wire goes from the back of the stereo usually always a blue wire to the rem on the input to the amp
May 23, 2010 | Rockford Fosgate Punch P5002 Car Audio...
Where do I plug in my REM wire from my amp to my
on the back of your head unit is the remote arial wire. this is the one you connect to the rem on your amp
Apr 05, 2010 | Pioneer DEH-P80MP CD Player
Stock red light protection in my crunch amp
it is most likely a blown mosfet inside the amp
Aug 28, 2009 | Kicker SX400.2 Car Audio Amplifier
MG100HDFX Amp - crunch setting seems too loud
There are 2 channels, Which means there are 2 sets of knobs ... One for clean and one for crunch. Start out with a low master volume and set up the crunch, Then the clen and switch between the 2 and make adjustments until they match volume wise ... Then turn the master up.
May 12, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
No power to amp
you need to hook up the rem wire, that runs from head unit to amp its usaully a blue wire on the head unit and there should be a rem input near where the power leads are on the amp
Mar 21, 2009 | Kicker ZX400.1 Car Audio Amplifier
CD player looks like its working but no sound. Quit during Play.
HI...CHECK TO SEE IF THE AMP IS GETTING POWER (REM) POWER-----(AMP)POWER--GROUND,, CHECK FUSES BOTH OF THEM--....YOU MAY HAVE DONE THIS ALREADY--CHECK TO SEE IF THE RADIO FUSE IS OK (POWER)..THE DISPLAY CAN STILL WORK FINE BECAUSE THE RADIO HAS 2 FUSES 1 FOR (POWER) AND ONE FOR MEMORY(DISPLAY) HARD TO SAY WITH OUT LOOKING AT IT.... GOOD LUCK
Feb 12, 2009 | Crunch BLX5520 Car Audio Amplifier
Powers isnt turning on but everythings hooked up?
Check the fuses. If the fuse is bad the amp's power supply is burnt. If the red light stays red and never goes green then your amp is in protect mode and the output section is burnt.To test for rem. problem just use a jumper wire (paper clip... or whatever)to jump from +12v power to rem. If rem. wire has no voltage when your radio is turned on that will make your amp come on. then look for the fuse in the rem. line. Good luck !
barneyluc
Oct 03, 2008 | Car Audio & Video
Kicker KX600.1 Car Audio Amplifier Logo
182 people viewed this question
Top Kicker Car Audio & Video Experts
Morne Olivier
hoyzee1
Marvin
Marvin
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
