Question about Titan 700258 - Bypass Prime Valve
How do you know when its not working the bypass valve 440i titan sprayer
  • 2,428 Answers
Wouln't pick up piant improper cleaning
Posted on Mar 09, 2015
  • 1 more comment
  • JOHN LAPIER Mar 21, 2015
    THIS IS A SMALL MACHINE BUT CAN DO A LOT IF TAKEN CARE OF
    Most people have no use for a tool like this or the knowallage of what to use it for and just don't clean it correctly
    Then its a pile of junk with hardened paint filling the whole system and want tips on how to make it work,
5 Suggested Answers
  • 5 Answers
SOURCE: Titan 440i wont turn on....
Your Transducer is shot the 440i has had this problem since inception. Now they are getting part made elsewhere. Your 440i has a four year warranty. it is covered the part if you dont have warranty cost 85.00 US. It is not a hard thing to replace on your own about 12 min. and your set.
Sincerely Steve Winters
Posted on May 29, 2009
SOURCE: TITAN 440 PAINT SPRAYER: PUMP WILL NOT START,
how can i get the gun to spray it is just dribbling out
Posted on Mar 09, 2010
  • 885 Answers
SOURCE: 440i titan only pressure is between 0-200 psi no matter the setting
If an airless paint sprayer won't prime it's usually because one or both check balls are stuck. First try hitting the head where the pump is sharply with a hammer, hard enough to knock the balls loose but not so much that you do any damage to the pump. If that doesn't free them up you may have to take the pump apart and clean them and their seats.
If an airless paint sprayer won't develop pressure, it's usually because the packing rnigs are damaged or collapsed. The only way to check this is to totally disassemble the pump and check them. Also look for any damage to the piston and cylinder. They must be very smooth and shiney, if they are scored they will eat up any new packing rings you put in.
Posted on Jul 19, 2012
  • 885 Answers
SOURCE: i have titan 440i and it has very low pressure when i swich it from prim to spray keeps running
When you switch it from prime to paint and it's still running:
- If paint/water continues to come out of the prime tube, your prime valve isn't seating properly and needs to be replaced.
- If you get a little pressure at the paint gun but it is surging, your packings, most likely the lower set, are damaged and letting most of the paint leak back past them. Packing/seal kits are available for your machine. Use all parts in the kit and grease/lubricate all of the parts well. Inspect the piston and cylinder for scoring or pitting that can damage new seals. They should be mirror smooth for proper operation and life of the seals.
Posted on Oct 31, 2012
My titan 440i primes but wont stop in priming when in spray position
I am not very familiar with airless sprayers but try this link to a youtube video...
https://www.youtube.com/watch?v=5DGUHwBmdaM
May 12, 2017 | Air Tools & Compressors
Is there a fuse in th 440i, keeps popping th breaker?
Check the brushes these motors for ever
You could also disconnect the pistion from the motor shaft the connecting rod to make sure the pistion is not the thing that is not moveing and binding the motor .
Most of the time problems come when people don't clean them correctly after use then store then for a few years .
Now I need my pump again except the old paint is now rock hard and nothing moves anymore the lines are cloged filters guns tips check valves .
All I know is my 660 titan witch is the same as the 440 except mine has flat valves instead if balls for check valves has been working great for the last 35 years but I clean it .
Jun 13, 2014 | Titan Air Tools & Compressors
My 640 titan run but will not prime it does not spray product
It is hard to follow your question....however; if the sprayer turns on and the paint fails to enter the nozzle, you may have a blockage. Take the spray nozzle apart and run hot water over it to clean it out. You may need a small brush or cu-tip to clean the inside of the barrel. Blow though it and see if air passes easily. reassemble and run as you normally do. Be certain the top is attached to the paint reserve tightly and securely. Any air leaks will prevent the sprayer from building up pressure within and thus no spay will be emitted.
Dec 19, 2013 | Titan 440 Impact Airless Paint Sprayer...
Piston seal
Hi Agustin,
Sorry that I have not replied before; only just seen your enquiry.
The problem is either the piston seals are worn, in which case paint is likely to come out into the oil cup, or you have a valve problem, either something is stuck in a valve or the valve could be damaged (the seat or ball) Call me at Lion Industries if you need to discuss 01543 251 560
Dec 16, 2013 | Titan 440 Impact Airless Paint Sprayer...
Titan 640i wont prime
If you still have a problem with a Titan 640i please give us a call. We introduced this sprayer to the UK back in 1985. Lion Industries UK Ltd 01543 251 560
Dec 31, 2012 | Titan 440 Impact Airless Paint Sprayer...
How do I clean the filter?
If you are still having filter problems please call us Lion Industries on 01543 251 560
Nov 29, 2012 | Titan 440 Impact Airless Paint Sprayer...
I have titan 440i and it has very low pressure when i swich it from prim to spray keeps running
Oct 28, 2012 | Titan Impact 440 Skid Airless Paint...
Jul 19, 2012 | Titan 440 Impact Airless Paint Sprayer...
Mar 13, 2009 | Titan Air Tools & Compressors
Titan 700258 - Bypass Prime Valve Logo
272 people viewed this question
Top Titan Air Tools & Compressors Experts
JOHN LAPIER
Steve Pack
Steve Pack
Vernon Taylor
Are you a Titan Air Tool and Compressor Expert? Answer questions, earn points and help others
