Question about Poulan Pro 14" Gas Chainsaw 33CC P3314
Need fuel diagram for poulon p3314 chin saw
Walbro card
4 Suggested Answers
  • 4088 Answers
SOURCE: fuel line replacement on Poulon 2050 14 inch Gas Chain Saw
First rule is to replace only one line at a time. Needle nose pliers is the only tool you should need. Replace the fuel line from the filter in the tank to the carburetor by removing the filter from the line, extract the line out of the tank, and remove the other end from the carburetor. Use the old line to measure for the replacement. Measure the point where the old line passed through the tank wall down to the filter connection. Mark this point on the new line, and push the line into the tank far enough to attach the filter (which you have checked for plugging), then pull the line back out to the mark. Make sure that you use the proper line for this connection as the filter must flop around to the lowest tank level so that the saw doesn't run dry of fuel when operated on it's side. The other connections are straight forward--just replace one at a time. Don't be stingy in making looping turns as you don't want future kinks. Hope this helps!
Posted on May 02, 2010
Testimonial: "I'll give the needle nose pliers another go at it! Problem is, the pliers aren't able to pass into the neck of the fuel tank from my last attempt."
  • 2239 Answers
SOURCE: How do I connect the fuel filter and tube to the fitting inside the fuel reservoir on a Poulon 2150 Chain Saw?
The fuek hose is a push fit into the fuel tak, trim the end of the pipe to a point and push down through the top of the tank, grab the end of the hose through the fuel filler hole with a pair of long nose pliers and pull the hose into the tank, the other end goes onto the carb inlet on the right hand side of the carb body,
Posted on May 14, 2012
  • 2239 Answers
SOURCE: need a diagram of fuel line routing
Right you have three hoses, there are two holes in the tank unit, the smaller of the two holes ( too the left hand side as you look down on top) this is the main fuel hose which has the fuel filter on the end in the tank, this then fits to the right hand connection on the carb, there is then a short hose which connects to the carb on the left hand side, and then goes to the shorter of the two connections on the back of the primer ( suction side ) there is then a hose from the longer connection on the primer( pressure side ) back to the hole to the right hand side of the tank , so to recap the primer pulss fuel from the carb, into the primer bulb, and dumps back to the tank.
Posted on Sep 10, 2012
Testimonial: "This description of the line routing seem very complete and should be extremely helpful to my being able to repair the saw. I will try this solution tomorrow. THANK YOU very much. F Sandry "
Fuel line diagram
Here is the way to hook up the fuel lines
fuel-line-diagram-0snlkc2idhfslary3a2ev3kp-4-0.jpg Note: I put it together outside of the saw so you could see how it is hooked up. Fuel filter/pickup >>to>> Inlet on carb >>to>> Outlet of carb >>to>> to inlet on Primer bulb(shorter post) >>to>> Outlet of primer(longer post) >>to>>Fuel tank (usually has a retainer in tank to prevent fuel line from coming out.)
Jan 11, 2016 | Poulan P3314 14-Inch 33cc 2-Cycle...
Need a diagram of fuel line routing
Sep 09, 2012 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Need diagram of fuel lines from tank to primer bulb and carburator on a Poland chainsaw model 1950 wood shark
There are 7 different types of the 1950 model (types 1 - 7) and it came with one of these 2 carbs Walbro or Zama. The carbs are different as are the fuel line connections for each one.
Although this video is for the promer bulb you can see the routing of the fuel lines.
http://www.ereplacementparts.com/article/4262/How_to_Replace_a_Primer_Bulb.html
You will have one line from the fuel tank connecting to primer bulb the 2nd line going to the carb. If you connect it backward it does not pump fuel into the carb.
Kelly
(FYI Types 1 - 5 all have the same fuel line routing.)
Apr 12, 2011 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Fuel lines rotted off of my McCulloch 4600 chain saw
Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetor theory and troubleshooting. Hope this helps!
May 18, 2010 | McCulloch Garden
Poulin p3314 gas runs out carb
Set the H and L jet screws CW to stops (lightly), then CCW 1-3/4 turns each. This is a basic setting and both need to be turned CW somewhat when the engine runs. Recheck the lower chamber in the carburetor for correct installation of the needle, seat, spring, fulcrum, and diaphragm. Go to: www.drystacked.com for a detailed look at Walbro brand carburetors. Even if you do not have a Walbro carburetor, the principles are much the same. Make sure the fuel tank vent is open.
Mar 27, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
My Poulan P3314 primer won't take in fuel or push it out.
the vinyl primer button on your carb shoots fuel into the crankshaft space. when you pull the rewind air and fuel in the crankshaft area is sucked into the combustion chamber. when the magneto reaches almost top dead center, the high voltage fires the spark plug. if there is an air leak in the gasket that surrounds the crankshaft, the air/fuel mixture will be way off. flooding will occur and the plug will get saturated. remove the whole back of your engine and clean the mating surfaces. now use high temp permatex and run a bead all around the gasket surface. tighten all the bolts - screws. push the primer button twice and try starting the engine.
Oct 24, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Poulan Pro 14" Gas Chainsaw 33CC P3314 Logo
82 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
