Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Intex pump flashing code 77 pump will not come back on
My Intex spa turns on heat light comes on ,only for about 2 minutes and then goes out then flashes e96 and is beeping, How do I fix ?
If alarm code E90 is displayed on the control panel, it means no water is flowing through the system. Check the attached troubleshooting guide.
Mar 14, 2016 | Intex Pool & Spa
How long should code 93 flash on the intex salt water system
It means that your pool has finished the chlorination process and everything is perfect! any other questions google will help you
Jul 15, 2014 | Intex Automatic Salt Water System for ...
Intex pump has code 01
What model of Intex pump do you have? Have you been back flushing and rinsing regularly?
Jun 14, 2014 | INTEX Sand Filter Pump
E96 on intex spa pump
I do not know what that error code is however I can tell you most of those kinds of spa take around 24 hours to heat up.
What model name of Intex Spa do you have?
Rod
US Parts Center
Apr 12, 2014 | Intex Pool & Spa
Intex portable spa error code 98 flashing
Bonjour
Je viens de monter mon SPA Intex et mis en route
Apr?s avoir r?chauff? l'eau jusqu'? 17 il a bugu? et met une erreur E98
J'ai appuy? sur reset mais rien n'y fait
As tu une id?e pour me sauver
Merci
Bises
Aug 16, 2013 | Pool & Spa
On my intex salt generator I am getting a flashing code 93, can you tell me what that means? I lost my book.
Code 93 means "Stand-By Mode (Operating processed Finished).. Here's the link for Intex manual search and download... Find your model and click on the American/British flag to download.. Be patient, takes a little while to download...
Good luck and please take the time to write a comment or rate...
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?hid_windowname=null&lst_docsea=2011&source=intexstore&gid=2&lid=14313&hid_windowname=null
Aug 24, 2011 | Intex '10 Saltwater System Pool Chlorine...
Problem with system
There is no code 77 Call intex and give them your information. They will have a new unit shipped to you in days
They are really good with warranties as long as you have a valid receipt
Jun 17, 2010 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
47 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
