Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Water supply tube keeps freezing off water supply.
Side by side frodge with side mount ice maker. Ice maker works on first rray but water supply tube keeps freezing off the water supply to the ice maker.
Is the ice maker broken or is the water supply valve broken? Any ideas?
  • 351 Answers
Its hard to tell but most likely the valve is not closing all the way. but it could be the ice maker calling for too much.... www.whirlpoolpartssurplus.com
Posted on Jun 23, 2009
Maytag model MZD2766GEW. The water tube supplying
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Jun 28, 2011 | Maytag MZD2667HE Side by Side Refrigerator
Water not comeing in ice maker
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Aug 10, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water going to ice maker
Apr 20, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maKer is not getting water but the water side works.
Your refrig water valve , has 2 coils on one valve . One is for the water dispensor , and one is for the ice maker . So even if you get water thru the dispensor , the other coil ( for the ice maker ) could be bad . The fill tube from inside the freezer to the ice maker , could be frozen solid , keeping the water from entering the ice maker . This frozen tube , would be caused be the water valve " seeping " , which means , it isn't closing completely , and drips freezing inside the tube . indicating a bad water valve . Pour about 2/3 cup of water into the ice maker . If it dumps , but doesn't refill with water , replace the water valve but also check this tube . If the ice maker does not dump the frozen cubes , replace the ice maker , but also check the coils under the refrig , for dust , lint , etc , needing to be cleaned off . The ice maker needs to be 5 degrees to operate , and dirty coils can keep the freezer at 6 degrees or above .
Sep 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frigidaire refrigerator, ice maker
If the ice maker is doing the normal cycle and when calls for water doesn't get any,probably the fill tube to the ice maker is clogh with ice because the dual valve (solenoid) is leaking and this water freezes up clogging the fill tube , or the solenoid doesn't work ,in both cases it has to be replaced(it's located in the back of the refrigerator attached to the water supply line).
Aug 28, 2009 | Frigidaire FRS3R5EMB Side by Side...
ICE MAKER NOT GETTING WATER FOR ICE BUT THE DOOR UNIT WORKS
I had this problem and eventually traced it to the water freezing in the fill tube in the freezer.  I defrosted the tube and no more problem
Jan 18, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Ice maker is not working
Likely that the water supply tube to the icemaker is frozen. It will be a white rubber tube on the right side of the icemaker. Warm it with a hair dryer, remove it from its aluminum tubing, and make sure there is no ice all the way back to where the supply tube comes from the water valve. After thawing, your icemaker should start working again.
Now..... why did it freeze? Most likely, there is a restricted airflow to the back of the unit, which is need to keep that aluminum supply tube just warm enough to assure all the water flow OUT of it into the icemaker, and doesn't freeze up on contact. Make sure your coils and the airspace under the fridge are completely clean (vacuuum them well) and it should cure the problem.
Jul 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker isn't filling with water. Water is on and ice maker is on. It's been humid.
Jul 16, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice Maker
Jul 16, 2008 | Refrigerators
Ice maker
IS YOUR FREEZER COOLING TO O.F
Jun 15, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
365 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
