Question about Poulan Pro 14" Gas Chainsaw 33CC P3314
Need a fuel diagram for a poulon p3314 - Poulan Pro 14" Gas Chainsaw 33CC P3314
2 Suggested Answers
  • 2239 Answers
SOURCE: need a diagram of fuel line routing
Right you have three hoses, there are two holes in the tank unit, the smaller of the two holes ( too the left hand side as you look down on top) this is the main fuel hose which has the fuel filter on the end in the tank, this then fits to the right hand connection on the carb, there is then a short hose which connects to the carb on the left hand side, and then goes to the shorter of the two connections on the back of the primer ( suction side ) there is then a hose from the longer connection on the primer( pressure side ) back to the hole to the right hand side of the tank , so to recap the primer pulss fuel from the carb, into the primer bulb, and dumps back to the tank.
Posted on Sep 10, 2012
Testimonial: "This description of the line routing seem very complete and should be extremely helpful to my being able to repair the saw. I will try this solution tomorrow. THANK YOU very much. F Sandry "
One more try before I trash it. I have a poulan p3314 chainsaw. It is 2 years old. Installed new carb,fuel lines,air filter, and spark plug. Fuel is routed properly. Can't get unit to fire. Any ideas.
Check the gap between the magneto and the magnet on the flywheel, if it is too much of a gap you wont get spark. We are talking .007 inches or less. You need a feeler gauge to set this
Apr 22, 2016 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Fuel line diagram
Here is the way to hook up the fuel lines
fuel-line-diagram-0snlkc2idhfslary3a2ev3kp-4-0.jpg Note: I put it together outside of the saw so you could see how it is hooked up. Fuel filter/pickup >>to>> Inlet on carb >>to>> Outlet of carb >>to>> to inlet on Primer bulb(shorter post) >>to>> Outlet of primer(longer post) >>to>>Fuel tank (usually has a retainer in tank to prevent fuel line from coming out.)
Jan 11, 2016 | Poulan P3314 14-Inch 33cc 2-Cycle...
Fuel lines have deteriorated and need to replace
I just took mine to a local Poulon Repair shop about 16 miles away and they replaced the lines and the grommet and only charged $6. You can find someone in your area through the Poulon website:
http://www.poulan.com/service-locator/
Aug 23, 2013 | Poulan 25cc 2-Cycle Gas Powered String...
Need a diagram of fuel line routing
Sep 09, 2012 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Need diagram of fuel lines from tank to primer bulb and carburator on a Poland chainsaw model 1950 wood shark
There are 7 different types of the 1950 model (types 1 - 7) and it came with one of these 2 carbs Walbro or Zama. The carbs are different as are the fuel line connections for each one.
Although this video is for the promer bulb you can see the routing of the fuel lines.
http://www.ereplacementparts.com/article/4262/How_to_Replace_a_Primer_Bulb.html
You will have one line from the fuel tank connecting to primer bulb the 2nd line going to the carb. If you connect it backward it does not pump fuel into the carb.
Kelly
(FYI Types 1 - 5 all have the same fuel line routing.)
Apr 12, 2011 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Need a gas line diagram for a poulon pro ppb250E
i need a gas line diagram for a yamaha vmax it leaks gas all over
Sep 18, 2010 | Poulan Garden
My Poulan P3314 primer won't take in fuel or push it out.
the vinyl primer button on your carb shoots fuel into the crankshaft space. when you pull the rewind air and fuel in the crankshaft area is sucked into the combustion chamber. when the magneto reaches almost top dead center, the high voltage fires the spark plug. if there is an air leak in the gasket that surrounds the crankshaft, the air/fuel mixture will be way off. flooding will occur and the plug will get saturated. remove the whole back of your engine and clean the mating surfaces. now use high temp permatex and run a bead all around the gasket surface. tighten all the bolts - screws. push the primer button twice and try starting the engine.
Oct 24, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Poulan Pro 14" Gas Chainsaw 33CC P3314 Logo
75 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
