Question about Mitsubishi WD-65833 65" HDTV
How long do the bulbs usually last? - Mitsubishi WD-65833 65" HDTV
Change a bulb in a Lamona electric oven & grill
usually just unscrew it as any normal light bulb and put in a new OVEN proof bulb . standards will not last in excessive heat .
Mar 09, 2015 | In Microwave Ovens
Replace bulb holders on 2000 ford explorer upper console
Take take the bulb holder into most major auto parts stores and they usually have a help section with commonly replaced items on a car, they might just carry the bulb holders. I believe the bulbs are 194 bulbs. Buy the 194LL (Long Life) and they should last longer.
Jul 03, 2012 | 2000 Ford Explorer
Can you just replace the headlamp or do you have to do the whole headlight assembly?
Those are sealed unit headlamps, you need to replace the entire headlamp, not the bulb.
There are 4 screws on the trim ring, don't confuse the aiming adjusters. Remove the 2 bottom screws, then one of the top screws. While holding the headlamp in place, remove the last screw. Hold the headlamp out far enough to be able to unplug it carefully. Then just reverse this to put the new one in. There is a top and bottom on the headlamp, (make sure you can read the name on the headlamp lens) and on the trim ring (make sure the holes line up.
It would also help to buy some silicone bulb grease for the connector, this'll keep it from corroding. Just smear some grease on the prongs before you connect the new headlamp.
Dec 04, 2010 | 1995 Nissan Pickup
Amber light with light bulb icon lights constantly. I assume this means the bulb is about to go. How many light bulbs does this unit have? How long before the bulb goes?
Yeah, time to replace the lamp. There is only one lamp.
The lamp usually last from 5000 hours to 10000 hours depending on manufacturer.
Apr 08, 2010 | Zenith E44W46LCD 44" Rear Projection...
How long do the bulbs last
Hello Dingbo the bulb usually last anywhere from 3-5 years on rear projection tv sets, every bulb is different in specs, but they usually have like 5,000 hours or so of working time. Now Ding from my experience i have seen rear projection tv sets last up to 15 years, Thank You hope this helps.
Sep 07, 2009 | Hitachi 57F500 57" Rear Projection...
I just bought a new bulb for my rear project tv (phillips), but this time it's just a bulb no case like last time can you help me put new bulb in old case
You have to take the cartridge apart; usually a few screws. Be careful not to touch the glass face of the new lamp with your hand. You will find usually two connections on the lamp: one at the end that usually has a nut and lock washer--do not over tighten when you reattach. the other is on the side of the lamp and usually is a machine screw with a lock washer---I usually use a needle nose pliers to tighten the nut and a philips type screwdriver to tighten the side screw----note which of the two wires is which and usually one is longer than the other. As you take the cartridge apart note where the screws that close it go and how it slides apart. You should know generic bulbs usually do not last as long as original lamps--they cost less but you are always taking a chance----The reason you do not want to touch the face of the bulb is it is like a halogen unit---oil from your hand will cause it to fail---if you attempt to clean it use a lens cloth for a camera--best way is to avoid touching it at all----Last: you also need to be careful about the 2 wire plug when you take it apart and put it back together-If you do not assemble it correctly it may not plug back into the set--take your time---this kind of job usually only takes about 10 minutes. Let me know if this was helpful with a vote---if you need direct help my email is:
etower.766@netzero.net
Aug 12, 2009 | Hitachi Televison & Video
Samsung DLP model hln617w won't turn on (not bad bulb)
Samsung is notorious for having bad color wheels in their DLPs. Well lets just say they are like toasters, they only last a certain amount of time. If the color wheel isn't spinning or is broken, the set will power down almost immediately after you hit the button, you may not even hear the entire fire up jingle. Check the wheel, if you can see the bulb light up for that split second. Actually, check it whether the bulb lights up or not.
Jun 28, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Projection bulb replacement
the bulb is usually between 4 to 600 and they are not hard to replace if you take your time with it
Nov 03, 2008 | Zenith Televison & Video
Light bulb replacementR
A fridge light bulb is usually a 40 watt appliance bulb with a screw base. It is heavy duty to last in the temperature. If it is not easily accesible to unscrew and replace, there may be plastic cover to unsnap.
Dec 27, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Mitsubishi WD-65833 65" HDTV Logo
27 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
