Question about Pride Jazzy Select 6 Indoor Power Wheelchair
How is the charger for a jazzy look when its charged
When its chared
2 Suggested Answers
SOURCE: I have a Jazzy 1113 powerchair and the on board
my chair jazzy 1113 ats won't move.all the lights are flashing and the batteries are fully charged why are they flasng
Posted on Apr 28, 2011
Power light is on the charger but no movement from the jazzy select chair
You have to disconnect the charger in order for the chair to move. It automatically removes power from the controller while the batteries charge.
Jan 08, 2014 | Pride Jazzy Select 6 Indoor Power...
On the Jazzy select what color for charging indicates fully charged, red, green?
scraig Lights on the joystick all lit up to the far right and the green light lit on the charger. Red indicates charging or blinking red indicates error in charger. Hope this helps
Nov 20, 2010 | Pride Mobility Products Jazzy Select
When charging my jazzy, do I unplug any plugs that controls my jazzy, or leave all plugged in? the reaon ask, green light will not come on the charger, which is onboard charger, unless I unplug controller...
No JJR all the plugs need to remain plugged in. On the Pride chairs the light on the charger will only come on green when the batteries are fully charged. When you unplug the controller the charger thinks the batteries are fully charged and the light comes on. Now the problem is the batteries. If they are old or you have a bad battery then the charger never senses a full charge so no green light. Hope this helps
Aug 26, 2010 | Pride Jazzy Select 6 Indoor Power...
Pride jazzy ultra will not hold charge for more than 15 minutes
This is an indication that one of the batteries may have a dead cell. A standard load test can clearify that. It could also be caused by the batteries not being charged properly. For instance, they should be charged a minimum of 8 hours to fully charge, or the charger is not working properly. If this is equiped with an on board charger make sure the charger is working by observing the charging amp meter.
Jun 04, 2010 | Pride Jazzy 1103 Ultra Standard Power...
How do you reset the dc charger on a jazzy 14xl the batteries have been replaced? thanks
Chargers generally do not need to be reset. But in some cases if you may want it to start a Bulk charge.
If the charger is plugged in to the mains and ON, Then switch OFF and leave unplugged for 2 - 5mins.
Meanwhile Switch Jazzy ON and try and put some load on the batteries by taking it for a short but power consuming trip usually by going up hill.
Then plug charger in and switch on and the charger should initiate a full charge sequence.
Aug 06, 2009 | Pride Jazzy 1103 Ultra Standard Power...
Pride Jazzy Select batteries not charging
If you use an automotive charger you have to charge each battery individually as they should be 12vdc hooked in series.
Clean contacts and assure yourself that each lead is charging properly. Jazzy has many different models so it impossible to know which you have. But there should be some info on the charger to tell you if your output is 24v or 2-12volt DC leads.
Jazzy has a web site and there is a member section where you can ask questions.
May 16, 2009 | Pride Mobility Products Jazzy Select
Pride Jazzy Select 6 Indoor Power Wheelchair Logo
99 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
