Question about SewShop.com Singer Parts - Serger Blade -14U12A, 14U13, 14U32, 14U34A, 14U44, 14U4
How to oil 14u34b
Need to know how to oil this serger
Where do you put oil in the overlocking machine
what does the manual say to OIL .many do not require oil as in the OLD DAYS
Feb 11, 2015 | Singer 14T968DC Serger/Overlock Machine
Where are oiling points for janome 8002d serger
Find the Owners Manual, either in a drawer or online. It should give you all the oiling points, type of oil recommended, frequency. If not, look for small holes near the bearing journals and slides. Gotta have a little mechanical aptitude here. Sometimes you will have to purchase, bribe, blackmail, trade, or barter for this skill/expertise, but usually one eye and half sense will suffice. It ain't that hard. Open the covers, turn it over, rotate the hand wheel, look for moving parts that "touch" other non-moving parts. ALL of them. When in doubt: oil. Just a drop or two will do. Excess will get slung off, or drip on your knees.
First try on Google: http://content.janome.com/userfiles/file/Inst%20book%208002D(Eng).pdf
You might notice that it runs much quieter with a little oil!!
Jun 25, 2014 | SewShop.com Janome 8002D Serger
Singer profinish serger
This sounds like a timing issue. You need a professional.
Jan 18, 2014 | Singer Vacuums
What is the difference between a sewing machine and a serger?
Well..... A serger (or overlock) sews a different, and usually more complex stitch. Where a sewing machine usually only uses two threads to make the stitch, a serger can use two, three, four or even five threads and will sew around the edges of the work piece, as well as trimming the edge of the work just ahead of the sewing area, or as you feed the work in, the trimming takes place first. Sergers also make a stronger seam, attributable to more thread / stitching in the seam. Sergers are versatile and quick, but one drawback is the fact that sergers make a chain stitch instead of a lock stitch, like a machine with a bobbin, and lock stitches can be pulled out, like the stitching that used to close dog food bags and bags of charcoal. A lock stitch is just what it sounds like, it can't be pulled out. You only get a lock stitch with a machine that uses a bobbin, and sergers don't use bobbins. That fact makes serging desirable for the speed of production. Changing bobbins takes up a lot of time, even if you are using pre-wounds. Hope this helps!
Sep 10, 2011 | Vacuums
My overlocker is jammed with the needles in the down position - I have not used it for a while and hve just oiled and cleaned it.
Oh man.
Not sure how to get it unjammed but I know that if overlockers/sergers aren't threaded properly they can jam up like that. The last time that happened to me... broken looper.
Open up the front and start clipping threads... Gently rock the hand wheel to see if it loosens as you get thread released.
Honestly I suspect that your machine has locked up because it's been knocked out of time. If you still have problems take it in and have it serviced.
Mar 12, 2011 | Vacuums
Pro 5 dc elna lock serger manual
I need instruction how to do roll hem on my pro 5 thread Elna serger 9000.
Feb 20, 2011 | Vacuums
SewShop.com Singer Parts - Serger Blade -14U12A, 14U13, 14U32, 14U34A, 14U44, 14U4 Logo
11 people viewed this question
Top SewShop.com Vacuums Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a SewShop.com Vacuum Expert? Answer questions, earn points and help others
