Question about Tappan Kitchen Ranges
Stop beeping f10 code on my tappen range was told the code has to be on there for them to fix but I can't go to days with the beep. any way to stop the beep without clearing the f10 code
fridgetech
  • 473 Answers
SOURCE: Range won't stop beeping
This is something that should be checked by a technician. Could be something simple but when your dealing with 240 volts you need to know what you are doing.
Posted on Oct 06, 2007
fridgetech
  • 473 Answers
SOURCE: F1 error code, continual beeping all other oven functions work properly
Here are the error codes for Dacor:
DACOR
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 Clock pushbutton is stuck in a depressed position Check clock buttons F1 Element relay circuit failure Control board may be bad F2 Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only) Call for service F3 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F4 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F6 Failure in the EEPROM check comparison (only time of day and timer will operate) Call for service, electronic clock control is usually the cause of the problem F7 Failure of the self- clean automatic door latch system Check door latch and switch(es) F8 Failure of the door latch motor. Occurs when the motor runs for two minutes without the door locking in self-clean mode Check door lock motor and door latch
Posted on Nov 09, 2007
jyackle5
  • 8197 Answers
SOURCE: Display shows error code "F1"
F1 Failed Thermistor Control Replace Electronic Range Control (ERC)
Good Luck and Please Rate Fixya!
Posted on Jan 07, 2009
jackiaria
  • 350 Answers
SOURCE: Error Code F2E1
Did you try unplugging it for a couple of minutes and replugging it?
This might reset the computer control.
Posted on Jan 17, 2009
localwonder
  • 6784 Answers
SOURCE: Magic Chef Electric Range F1 code won't stop
Hi. this is referring to a Defective touch pad or clock (ERC). This will need to be corrected. Normally, you will need to, simply, replace the main control Board(ERC).
Follow this testing procedure to confirm the damage.
This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Posted on Nov 25, 2009
Frigidaire beeping with F10 signal
sounds like you need to get all food out and switch it off and leave the doors open and leave it for two days with the doors open ok then afther you have left it swich back on with doors closed do not open doors for 24 hours swicth on ok then it should be ok if not then its lack of gas
Oct 15, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
F10 err resulting in beeping
The F10 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F10 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
GENE
Oct 02, 2011 | Frigidaire FES367 Electric Kitchen Range
The front panel keeps showing F10 Err message ?? And it won't stop beeping, any idea what it could be??
The F10 error code means that was a runaway over heating that occured in the oven. The things that could cause the over to overheat to the exterme of the F10 error code reqirements is during self clean normal cleaning temp. IF it wasn't cleaned just before the F10 error code,first the oven temtature sensor needs to be replaced then if F10 comes back after the sensor is replaced the computer control board needs to be replaced.
Gene
Aug 16, 2011 | Kenmore 46713 Stainless Steel Electric...
Range started beeping and display "F10" code.
Hello & Welcome to FixYa
Error code F10 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Sorry for the bad news but hope you understand... Please get back to me if you have any other questions.
Kevin
Mar 28, 2011 | Kenmore 91112 / 91114 / 91117 Electric...
My Kenmore oven, model 790, displays and beeps the F10 Fault
June 8, 2010
Same thing happened to mine this morning....cut the circuit breaker for a hour....open oven and let it cool....
mine stopped, finally. Dont know if its a long term fix yet.. but at least it stopped the beeping.
May 06, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
What id f10 code??
let it beep for a minute, and turn off. it has stopped
Jan 27, 2009 | Tappan MEF500 Electric Kitchen Range
What is error code F10 on model #790 electric range?
Tiger.......I have a Kenmore Model 790 as well, and am getting the F10 Error code. It says in the manual that it is either the RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control), but I am trying to find troubleshooting tips myself, as I do not want to pay $130 for a tech to come to my house. I know you can press the oven (off) button to stop the beeping momentarily, but the manual also says that the oven may need to be reprogrammed.....which is what I'm trying to find how to do. Sorry I couldn't give you a quick fix solution, but I'm am still searching.
Jul 07, 2008 | Kenmore Kitchen Ranges
Tappen gas 4 burner about 10 years old with about 10 hrs total use time(basement stove)
Hi Carlsr,
The F1 error code description is an electronic oven control failure. To fix this error, you need to replace electronic oven control (also called EOC or clock).
Hope it helps.
Thank you for using FixYa.
Apr 13, 2008 | Tappan TGF320 Gas Kitchen Range
Kitchen Ranges Logo
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
