Question about Mr. Coffee TFTX85 Coffee Maker
My coffee maker won't brew the coffee. Mr.Coffee GBX25
The timer is on the coffee maker is heated you can hear boiling but the water won't get sucked in to drip in the coffee basket to drip in to the pot.
    Sergeant:
  • 199 Answers
You tube is clogged pour in 2 cups of vinagar an brew this will eat away the calcium deposits. in your coffee maker if you water is hard where you live you may want to by distilled water or use some type of filter or water softener
Posted on Jun 23, 2009
Coffee stopped brewing well, coffee now brews weak. Even with increased coffee grounds. Clean button won't turn off. Even after 2 clean cycles.
Chances are there are built up scales inside the brewer. Are you using regular water? If so, you may have to descale it. Look for a food safe descaling chemical which you may have to flush with clean water in several cycles. Another solution is to take it apart and clean it. Problem is, you have to be skilled to do this.
Jun 19, 2016 | Mr. Coffee BVMC-PSTX91 10 Cup Programmable...
Cuisinart brew on demand coffee maker
what about on/off switch, does it seem ok.
regards,
dont rate it untill fully satisfied
Aug 23, 2008 | Cuisinart DCC-1200 Coffee Maker
Set the timer to start brewing, i have always done this with no problem till now
Could be the brewing mechanism or the timer. However, if you get the action you describe on BREW NOW, I am inclined to think the brewer has failed.
Nov 10, 2013 | Mr. Coffee 072179228578 12 Cup Coffee...
My Mr Coffee ADX20 coffee maker does not boil the water through any more. I would assume the main heating unit is bad. How do I replace the main heating unit?
You might have scale that formed on the heating element. This happens to all heating elements due to impurities in the water. I would try cleaning it a couple times to see if it helps first! Clean the mineral deposits from your coffeemaker every 80 brew cycles if you have soft water and every 40 cycles if yours is hard water. About once a month is good for a coffee maker. Pour four cups of undiluted white vinegar in the water reservoir. Place a paper filter into the removable filter basket, close the lid. Go through a brew cycle with decanter in place. Turn the coffeemaker OFF after THREE cups of vinegar have entered the decanter. Let set 30 minutes. Turn machine on and let rest of vinegard run through. Discard filter and vinegar solution, rinse. If this doesn't help the element is probably bad and from everything I have heard Mr. Coffee doesn't have't replacement parts for consumers. They only sell to "Authorized" repair shops. With that being said I have heard if you call the Service number 1-800-672-6833, and talk to an human operator, not the machine, they have sent out new units because of this problem. If that doesn't help Coffee makers are usually throw away items, I have recently purchased a pretty nice Mr. Coffee one from Costco for $30. Kohl's had one the looked a little different but all the same features for $55. So for like $30 you can get a new one, where if you could find an heating element it would be probably around $20. Just saying!
Mar 10, 2011 | Mr. Coffee ADX23 / ADX20 Coffee Maker
I forgot to put water into my Mr. Coffee for a minute. When I realized it, I shut it off and poured in the water. When I restarted, it did not heat or brew.
All coffee makers use a thermal fuse which opens (interrupts) at a specific temperature, generally somewhere above boiling point and do not reset when cool.
They are designed to prevent fires if the thermal switch which cycles the heater fails and the heating element heats beyond its normal operating temperature.
These Chinese devices are poorly made and unpredictable in performance.
They are not user-replaceable since they are spot-welded on both ends; the only possibility is the replacement of the pre-assembled heating element/thermal switch/thermal fuse which will likely cost close or equal to the price of a new machine if at all available.
Sep 29, 2010 | Coffee Makers & Espresso Machines
The water is boiling, but wont flow into the filter??
Remove sprayhead and pour water into tank until it flows from the brew tube, then replace sprayhead and brew coffee.
Mar 14, 2010 | Bunn VPS Coffee Maker
When I put 12 cups of water in the container, only 8 cups brew. Also, it takes 30-40 min. I ran vinegar through it twice and am getting the same results.
the coils are super heating, and condensation of your water is vanishing faster than it's brewing. It sounds like your coffee pot is ready to go to mr coffee heaven
Aug 08, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Coffee not brewing
This machine depends on heat to move the water to the top. The heating element, or thermal fuse, or burned contacts are the usual suspects. The warmer under the coffee pot is not part of the coffee making process. It is repairable.
May 05, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
We have a Sunbeam coffee maker almost 3 months old and has been a problem after 1 month use. We bought a Mr. coffee and it,s around 6 weeks old and both are a big problem while trying to brew coffee,they...
my suggestion is spend some good money on a coffee pot or get a french press and a hot pot. those mr. coffee and sunbeams are nothing but trouble from my experience.
Sep 20, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Coffee maker not working
I fixed it! I returned the thing back to store.
Mar 09, 2008 | Mr. Coffee GBX25 Coffee Maker
Mr. Coffee TFTX85 Coffee Maker Logo
1,068 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Henry  Thomas
Henry Thomas
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
