Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Pop cooler freezes pop, runs at about 10 degrees F
I own several Antares Vending machines, They are built into a special refridgerators by Fridgedaire. One of them ices up in the coils and freezes the pop and they burst. I have adjusted the thermostat, which is unlabeled so I don't know whether to go clockwise or counter closck wise. This worked for six months, now the problem is back.
  • 183 Answers
SOURCE: Kenmore Elite side-by-side (1999 model--don't have #)
Evaporator is probably overiced as a result od door not being completly closed at some time recently, turn off and defrost overnight with the doors open, turn on the next day and it should work ok within 24hrs. Regards Advisor
Posted on Aug 31, 2007
SOURCE: kenmore side by side
is it ice or frost , if its ice you may have a drain problem causing it to ice up and block the air flow
Posted on May 02, 2009
tomsat69
  • 219 Answers
SOURCE: It's a Kenmore alright
Do you have any frost buld up in freezer compartment?if so sounds like a freezing issue.If no frost build up is your fan running in freezer part if not you may need evap fan or a manual defrost.Your fan may have ice stoping it from turning.If your fan is running you may need to pull off your start switch located on your compressor.Shake it around if you here noise like burnt parts in it you will need a start switch.And remmember never turn your fridge up full blast normal is good or you will freeze it up. Good luck:)
Posted on May 10, 2009
heavyt15
  • 91 Answers
SOURCE: Kenmore Side by Side not getting cold enough to freeze food.
Evap fan...cond..fan ...do they turn.....seems like a comp...problem...does the evap ice up...?
Posted on Aug 18, 2009
  • 308 Answers
SOURCE: bad defrost timer/ thermostat???
It definitely sounds like you have a bad defrost timer, that is the reason the coils are icing up on you. The next issue, which may or may not be related is the freezing of items in the refrigerator. Usually the cold air is transferred, through a vent with a damper, from the freezer and into the refrigerated section. The "thermostat" for this section is actually usually just a lever to adjust the position of the damper. That being said, usually when you have a problem such as you are having, it is either a stuck or broken damper (or damper component). Hope this helps
Posted on Nov 16, 2009
Testimonial: "EXCELLENT!!!!!!!!!!!!!!"
What makes my RV refridgerator work on electricity and warm up 10 to 15 degrees on gas? Freezer warms up slightly, but only a couple of degrees.
look at the flame. Is it yellow on the tip of the flame? The air mixture might be off adjustment. RV refrigerators will always be cooler on electricity but not by 10-15 degrees.
Aug 20, 2014 | Refrigerators
Antares vending machine
Change the thermostat, that's what regulates the compressor.
Nov 28, 2013 | Refrigerators
Tfx24zr refrigerator running 20 degrees warm
It could be freezing up in the freezer part of the fridge, or you may need to add coolant or freeon.
Apr 11, 2013 | GE Refrigerators
I have an Antaris vending machine that has a frigidare cooling system. It was manufactured in 2006 and has been working fine. Recently the motor kicks on but the cooling system does not and it does not...
the antares is notorious for having evaporator problems. The evaporator is not galvanized and as such rusts after a period of time. Once rusted through the coolant is released. The machine will no longer get cold until the evaporator is replaced and the sytstem charged with coolant... gene
Aug 24, 2010 | Frigidaire Refrigerators
Viking Wine Cellar Temperature Near-Freezing
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
Jun 01, 2010 | Viking VUWC141 Wine Cooler
My Edina cold soda vending machine which was made by Frigidare is not getting cold. The previous owner (my neighbor who I trust) said it had always worked fine. It had been in his garage, unplugged, for...
I have some of those machines. What happens to them is that the evaporators, which are made out of steel, rust out in approx. 7 years. This allows the R134A to leak out. If you can peek back through to the back wall, you will see where the rust has run down. The solution is to order a new evaporator from Frigidaire at around $100.00 and get someone to change this out and recharge the unit. Before turning it over to the mechanic, you may want to remove the vending module which includes the inner doors and plastic shelves. This can be done in 15 minutes and makes the job easier for the mechanic which can save you money. You should end up with less than $300.00 for the total cost of the repair, but since these machines are rather popular, they can be had on ebay fairly cheap. Sometimes you can pick up new machines for five or six hundred dollars. These are the same as the Antares machines which are made by Edina. I hope this helps.
Jun 18, 2009 | Electrolux Refrigerators
GE Monogram Built-in Refrigerator Side keeps freezing
Sounds like a faulty thermostat. Try replacing it with a known good one and retest.
Apr 20, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
55 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
