Question about Garden
Troy bilt LTX 1842, 188392, 13AP609G063
Wheel bearing part number 7410990 and 7410516 will not fit to large
3 Suggested Answers
  • 376 Answers
SOURCE: require an operator's manual for a bolen troy bilt ltx 14 hydro
Go to... http://www.buymtdonline.com/webapp/wcs/stores/servlet/FindingYourPart_10101_19502_-1 Scroll down to bottom left and click on Owner Manuals. You will have to have the model and serial numbers from under the seat of your mower.
Posted on Jun 19, 2009
  • 407 Answers
SOURCE: how to replace the top
Unfortunately there is no easy way to do that.I find that removing the seat and rear fenders is the best way to get at the engine pulley.I remove the deck and the deck belt then drop the belt from the engine to the front.Make sure to get the belt inside the tension pulley before you put it on the front pulley.You will need a small pry bar or large screw driver to get the belt on the last pulley.Before you use one of those wrap it in an old rag or some leather(old belts work)to keep from damaging the belt.I would suggest replacing the deck belt while you are down there,I always change both as it is not much fun to change the belts.
Thanks for using Fix Ya.
Posted on Jun 11, 2011
How do I replace Blower Bearing?
Strip down, remove shaft, push out seals and then bearings. Take bearing and seals to a bearing supplier and they will replace by the part number on the bearing. Refit will plenty of lubricant.
Mar 04, 2016 | Troy-Bilt Troy Bilt Storm 3090XP Snow...
Troy Bilt Lawn Mower how to fit carburettor cable
Troy Bilt has a great website but you need to find your model number to use it.
Lawn Care Products Lawn Care Equipment from Troy Bilt
Sep 14, 2014 | Garden
How do you install a split hex flange bearing?
The split hex flange bearing fits on the front axel assembly of the Troy-Bilt self propelled mower. To install it, remove the front wheel to see if you can access the old bearing and pop it out of its position on the assembly. If you cannot reach it, you'll may to detach the axel assembly from the mower itself. You'll find the old bearing behind the plate that attaches to the mower frame. You may have to remove a nut that holds it in place, then remove the flange bearing itself. Put in the new one and reverse the procedure.
All that being said, it's hard understand how you would know that the split hex flange bearing needs replacing if you haven't already disassembled the axel assembly to check its condition. If the bearing, itself, just fell out and someone told you what it was, he should know how to replace it.
This bearing should rarely need replacing. If it does or if it just fell out then you likely have much bigger problems than just replacing it.
Jul 26, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Need to put a new belt on the rear of the Troy-Bilt LTX 1842
First buy proper belt... Next note how old belt is warped around the pulleys, take a picture or draw a diagram... Remove all covers off deck pulleys, and guards to expose belt completely... Pull and stretch belt off one of the idler pulleys, once one is off the rest will slide off... Reverse procedure for installation... Note: grease all nipple fittings, bearing and shafts to avoid seizing of bearings or bushings.
Nov 17, 2013 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
Variable speed doesn't work troy bilt self propelled lawnmower
Cable could be stretched belt could be worn or old, if it has a gear box maybe it slipped a gear or lost some teeth. Do some investigation, Good Luck
Jul 26, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Old Troy Built with model #HH60-105106F. What is
That's the engine number. It's a 6Hp Tecumseh. Go on ebay and buy the Troy Bilt parts manuals on CD for Horse Roto Tillers (if that's what it's on). I paid $8. Definitely worth it.
Mar 08, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Require an operator's manual for a bolen troy bilt ltx 14 hydro
Jun 19, 2009 | Garden
Oil seal for rear tine shaft
The serial number is located on a flat spot just above the right wheel shaft where the gear housing and the top gear cover meet. It will be a six digit number stamped in the metal.
Frank
Mar 11, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
