Question about Onkyo Audio Players & Recorders
Factory reset Onkyo
HP-r690
Im Need Help Resetting My ONKYO TX-SR6O3X RECIEVER Its By Itself Or The Owners Manual to Help me reset it
Resetting the AV receiver to its factory defaults To reset the AV receiver to its factory defaults, turn it on and, while holding down the [VIDEO 1] button, press the [STANDBY/ON] button. "CLEAR" will appear on the display and the AV receiver will enter Standby mode
Apr 26, 2017 | Onkyo Audio Players & Recorders
I Have The ONKYO TX-SR603X receiver ALL BY ITSELF I NEED HELP RESETTING IT
Hello, please see the procedure below to reset the receiver
How to reset RC-569M remote controller to factory defaults.
Not sure if it's the same, but for the Onkyo RC-799M controller the reset sequence is:
To reset the remote controller to its factory defaults,
while holding down RECEIVER, press and hold down
HOME until the remote indicator lights (about 3
seconds). Within 30 seconds, press RECEIVER
again.
Jan 05, 2015 | Onkyo Audio Players & Recorders
Onkyo tx-ds 474
press and hold the video 1 button and then press the speaker A button - you should see 'clear' on the display. This will reset everything
Jul 14, 2014 | Onkyo TX-DS474 Receiver
How to reset factory settings for onkyo tx-sv303pro without the remote
To reset the AV receiver to factory default ,turn it on and, while holding down the (VIDEO 1/VCR) button, press the (STANDBY/ON) button "Clear" will appear on the display and the AV receiver will enter Standby mode. :)
Jan 14, 2014 | Onkyo Audio Players & Recorders
No sound from receiver onkyo ht -r690
It's often a problem with some of the soldering joints underneath the Digital Sound Processor (DSP). Need to be fixed at a service center.
Nov 28, 2013 | Onkyo TX-SR605 Receiver
My ht-r690 receiver's video out stopped working. sound works, tv and cables work (tested on another system) but no video shows up on tv through the receiver. any ideas?
Well there are two possible reasons. 1st- make sure that to do a factory reset on the amp. while it is on Press DVR/VCRat the same time press the power button (Standby) clear will show on the screen.system is now back to defaults try the video.
2nd If the video still not working check the TV out settings. Press Setup - Input Out put assign - Monitor Out- Make sure it's set to HDMI. and the resolutions is set to Through. if this setting is ok and you problem is not solved. it could be an issue with the board or your hdmi device it self.
Let me know?marc
Nov 10, 2011 | Onkyo Audio Players & Recorders
Have ajustments all screwed up
If you can’t resolve the issue yourself, try resetting
the AV receiver before contacting your Onkyo dealer.
turn it on and, while holding down the [VCR/DVR]
button, press the [ON/STANDBY] button. “Clear”
enter Standby mode.
Note that resetting the AV receiver will delete your
radio presets and custom settings.
Feb 10, 2010 | Onkyo HT-S9100THX 7.1 Channel Receiver and...
Onkyo TX-SR701 Digital audio port stopped working
you may want to try a factory reset by pressing and holding vcr1 button while pressing the power button. do this with the unit on. It will reset back to factory default. so any saved setting will be lost and you will have to set again to your settings.
Jan 03, 2010 | Onkyo TX-SR701 Receiver
50 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
