Question about Whirlpool Refrigerator Water Filter
How do I get water pressure back after I replace a Whirlpool water filter?
Just replaced my Whirlpool side by sides water filter. Its located at the bottom and is push button pop out. Since replacing the filter, we get a trickle of water out of the dispenser then nothing. The water dispenser works without a filter. How do I correct the loss of pressure or lack of water flow?
  • 55 Answers
SOURCE: whirlpool side by side water dispenser not working
propably the pump is failed
Posted on Nov 18, 2007
Master_Tech
  • 770 Answers
SOURCE: cold water dispenser on new whirlpool side by side dispenses lukewarm water...ice maker works a charm
there is a tank in the refrigerator section that hlds about 1.5 gal of water as you dispense it refills and pushes out the cold water. if your unit is new it will need a day to cool down the tank of water before you will get cold cold water at the dispenser
Hope this help explain how it works
Posted on Aug 01, 2008
mastatech
  • 478 Answers
SOURCE: freezer does not make ice
You need to check and see if ice maker has any water init. if not check the fill tube that goes thru the back wall for stoppage while you have it out rin the maker thru a harvest mode and listen for the sounds of the solonoid opening. If tube is full you'll need to replace the slow leaking valve a common problem. for parts call 704-819-6557
Posted on Mar 14, 2009
  • 531 Answers
SOURCE: Refrigerator Water Dispenser doesn't dispense water!
water valve
Posted on Apr 07, 2009
aborcass
  • 2651 Answers
SOURCE: I need to replace the water line tubing in the
the front dispensor panel can be removed by lookin under the panel you see too little spaces in which ti insert a screw driver,by pushing down on the top, you cantwist the screwdriver in the opening eleasing the tabs, and simply lifting off the top tabs, dependingon model you may need to un plug a wire or 2.. the tubing should be able to be removed be releasing the connector undeer the door and simply refeeding the new hose back into unit
Posted on Jan 27, 2010
What type/model/ brand of water filter do I need for the Whirlpool Roper side-by-side refrigerator with the model number: RS25AGXNQ00
There is a generic type of water filter that fits all Whirlpool and KitchenAid refrigerators with a water filter located in the base grill below the door.
it looks a bit like this: http://www.partselect.ca/11722132-2-M-Whirlpool-EDR5RXD1-Water-Filter.jpg
Here is one on amazon: Amazon com Replacement Roper RS25AGXNQ00 Refrigerator Water Filter...
Sep 05, 2016 | Whirlpool Refrigerators
I have a side by side whirlpool, water was coming out fine then replaced with new filter and a month went by the water started to come out very slowly I thought the filter may be plugged so put anothe
Cut water supply off to frig disconnect water supply line to frig water inlet valve turn water back on to make sure you are getting good water supplied to water inlet valve some times water cut off gets stopped up. If you are getting good water flow to water inlet valve then check to make water valve is opening up all the way. if not then replace valve.
Oct 27, 2014 | Whirlpool Refrigerators
How do I get water flow back after replacing a Whirlpool water filter?
The replacement filter may have been installed backwards with the flow direction arrow point toward the source.
May 11, 2014 | Whirlpool Refrigerator Water Filter
Where is the filter for the ice maker on whirlpool refer model number ED2CHOXK005
Removing and replacing a water filter - base grill location
Filters situated in the base grill (below the freezer compartment) of Whirlpool-built side-by-side refrigerators are relatively simple to replace. Follow these two steps:
  1. Grasp the filter's end and make a one-quarter turn to the left.
  2. Pull the filter straight out.
To replace with a new filter, repeat these two steps in the opposite order, making sure to first remove the red cap from the filter. Proceed by pushing the filter straight into the slot, and then giving it a one quarter turn to the right.
Note: Replacing this type of filter is quick - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Dec 18, 2010 | Whirlpool 21.8 cu. ft. Side-By-Side...
Putting in the new water filter to the Whirlpool gold fridge that goes in at the bottom.
Removing a water filter from the base grill of your Whirlpool brand refrigerator:
Dec 06, 2010 | Whirlpool GD5DHAXVY Stainless Steel Side...
Whirlpool side by side refrigerator model # ED5VHGXMQ stopped making ice and despensing water. could this be caused by the filter?
Yes, this is a symptom of the water filter in need of replacement, I would recommend starting with filter replacement, if that doesn't solve the problem, then I recommend checking the water supply at the back of the refrigerator. Shut the water valve off that is inline to the refrigerator, disconnect the tubing from the refrigerator at the water valve or the water tube couppler on the back of the refrigerator, have a container available so that you can run about 1 or 2 gallons of water out of the water supply tube in to the container to be able to see if the water pressure seems to be strong and if there is sediment or other foreign matter that needed to be flushed from the system. If water supply seems good then reverse the process to supply water back to the refrigerator. If water supply is not good you need to have a technician or plumber check into the water supply further.
GOOD LUCK !
Aug 04, 2010 | Whirlpool ED5VHGXM Side by Side...
I just changed the easy (pop-out) water filter on my Whirlpool refigerator (located at the bottom of the grille) and when I went to use the water it would not stop running, I had to disconnected the main...
Some of the early models had a sphion ball at the dispenser water tube. When this design worked. it was supposed to sphion water back into the supply line after you stopped calling for water.It's recommended that after you replace the filter and or anytime the water lines are accessed, purge the system. Pull at least 1 gal of water from the dispenser to purge the air. Air in the lines will produce back pressure. This pressure not the same as the regulated line pressure, will continue to push water through to the dispenser and or icemaker. Depending on the model design of the unit, the ice maker may be tricky to purge. Ther are several styles, with the ice bin in the door as trickyest.
Ric
Feb 20, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water Filter
most whirlpools have the filter located in the bottom kickplate, right below the freezer door. turn counter-clockwise and toward you to remove. if it has never been removed before, they are hard to get out the first time.
Jul 24, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
My ice maker is not working. I think I need to
Turn off the water supply going to back of refrigerator. Relieve pressure by trying to get water from dispenser. The filter is located on front and bottom inside the kick plate. The replacement filter is part number 4396508 and you can see illastrartion by putting model ED2FHEXNL01 in search feature in link below and scrolling the photo down. You will see the filter as number 29. But the part number is 4396508 Click on link below, we also offer free help. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Apr 27, 2009 | Whirlpool ED2FHEXN Side by Side...
Whirlpool ED5VHGXMB10 side by side
I had the same problem, and had to replace the temp regulator. It is located on the refrigerator side, by the water filter. It took me 15 to 20 minutes to replace it.
Sep 09, 2007 | Maytag MSD2756G Side by Side Refrigerator
Whirlpool Refrigerator Water Filter Logo
89 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
