Question about DeLonghi EAM3200 Espresso & Coffee Maker
How to remove infuser, 3200 - DeLonghi EAM3200 Espresso & Coffee Maker
'less coffee' error message
The infuser assembly can only be removed with the machine turned off. The infuser needs to be removed and cleaned at least monthly; more often if you use your DeLonghi at lot.
Jun 14, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Can't remove infuser to clean it
Turning off the power with the button is not enough. Instead, to remove the infuser: unplug the machine, wait a few seconds, plug it in again and turn the machine on. Even though you are technically turning it on, the machine will sense it was not turned off in an ok way, so it will "properly" shut off (and unlock the infuser).
May 06, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Infuser stuck up my delongi magnifica
I have a problem. I removed the infuser and the internal bracket is now in a "down" position and I cannot get the infuser back in. I need to know how to raise the internal bracket to its proper place. Any ideas?
Apr 06, 2010 | DeLonghi Coffee Makers & Espresso Machines
Insert infuser assembly alarm on De longhi coffeemachine
Did you try tightening the 2 hex screws behind the infuser?
Be gentle though. Mine felt tightend but thenIput just a bit more pessue on them and got an eigth to a quarter more turn out of them. Found this solution on this site
Jan 15, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Delonghi magnifica coffee machine...infuser jammed in machine. Needs to come out for cleaning. Can depress red buttons but it wont come out..looks a but squint
Remove base plate and turn pulley clockwise (probably for several minutes) until infuser arm returns to vertical position and the infuser itself drops to the low position. You should here a click when it reaches this point. The infuser can then be removed as normal.
Nov 02, 2009 | DeLonghi DCM485 Coffee Maker
Impossible to remove infuser, appears to be jammed
Plug in Machine. Turn on for 10 seconds or so. Turn off. Let Machine turn itself off completely. Once it is quiet, do not unplug, try to remove the infuser. It worked for me (procedure recommended by customer service for Delonghi in Switzerland).
Oct 23, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
DeLonghi Magnifica always asks "Insert Infuser Assembly"
on my machine, the two screws that attach the infuser receptacle to the insides of the machine came loose. You can see those two stainless hex socket screws when you remove the infuser by grabbing its two red tabs and pulling it out. Just use a hex shaft
screwdriver (size 3mm or thereabout) to tighten them.
Apr 01, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
Magnifica gives Generic Alarm Message - Infuser stuck
My infuser was stuck in the down position, When I called customer support the told me some easy steps to fix this problem..try calling them
Nov 28, 2008 | DeLonghi Esclusivo Magnifica ESAM3300...
DeLonghi EAM3200 Espresso & Coffee Maker Logo
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
