Question about VillaWare Kitchen Appliances - Others
I need a manual for Villaware Model 3400 heart shaped waffle maker
Need a manual
    Habit-Forming:
  • 23 Answers
Try NelsonEZY.com they have a bunch of vintage manuals. http://nelsonezy.com/Instruction-Manual-Downloads_c21.htm
Posted on Aug 18, 2016
SOURCE: Nordic ware Belgiam Waffler maker
This is how I use the nordic ware...
1.Heat pan on medium heat on one side until temp gauge is in the middle. Dont turn pan at all when pre-heating
2. Open pan and coat bottom with a little butter.
3. Flip pan over and add butter to bottom side that has no butter.
4. Add batter quickly so butter doent burn. Add semi-thick batter in pan and only let batter run so there is about 1 inch of space left on the edge.(This space will fill with batter when you close the cover)
5. Temperature gauge should stay near the middle at all times.
6. Do not open the pan to check the batter waffle color or your crispy waffle will turn soft
7. Let waffle cook on first side until the steam that comes out from the side slows down to about half of the amount of steam that came out when battle was first put in. (Should be about 2 minutes)
8. Turn waffle pan over and DON’T open the pan.(you haven’t opened the pan once to look)
9. Let cook until steam reduces (Takes about 2 minutes)
10. Keep an eye on the temp gauge
11.Remember the first waffle always takes longer to cook than the second and third waffle.
12. If you have the urge to open the pan. Open the cover slowly. If it doesn’t open up easily then it is still rare and wait one minute to open. If you need to look, you should only open the pan after you turned it over. Once you open the pan, leave it open. If you close it the cripy top will turn soft.
13. Remember trial and error
Posted on Aug 25, 2008
  • 83 Answers
SOURCE: waffle mix spilled over entire waffle maker, inside and out
If it is a non-stick surface brushing cold water on with a pastry brush while it is still ver hot and immediately after removing the food will clean the surface easily. As for the outside, if it is a painted surface a non- abrasive cloth with warm water could possible clean it. I would not recommend pulling it apart.
Posted on Sep 25, 2008
SOURCE: removing top of waffle maker to clean it
The other night my wife had the same issue. My thought had always been to wipe it down using a wet cloth with simply hot water and rely on the extreme heat of using it to sterilize it.  My wife decided instead to disassemble it.  The problem is that it is not made to disassemble and she bent some parts and broke others and stripped out screw heads.  It is clean now, but can not be reassembled without extracting stripped screws and replacing some parts. My advice to you is - don't try to disassemble it. The factory went to great lengths to ensure that you don't.  Instead use a soft cloth dampened (not dripping wet) with the hottest water you can.
Posted on Dec 29, 2008
SOURCE: Need PDF manual for Toastess Waffle Maker # MOL576
I have the manual for you waffle baker. It appears to be the same as the Toastmaster waffle baker, TMRWB. If you need the manual let me know I will upload it or send a copy to you, if you like.
Posted on May 28, 2009
SOURCE: I need a manual for a salton waffle maker wm4
There is a site that posts PDF files of manuals for all manner of things..manualsonline.com.
Here's the link for the Salton Waffle maker, they have several versions:
http://kitchen.manualsonline.com/search.html?q=+salton+salton+waffle+maker
Posted on Aug 05, 2009
Find a leg for toastmaster waffle maker model 270 or 290
http://www.searspartsdirect.com/partsdirect/part-model/Toastmaster-Parts/Waffle-maker-Parts/Model-270/1097/0213700/00039364/00001?blt=06&prst=&shdMod=
Jun 18, 2014 | VillaWare 3600 Prego Pizzelle Baker
Need manual for villaware uno 2003 uno heart round waffle maker
http://kitchen.manualsonline.com/manuals/mfg/villaware/villaware_waffle_iron_product_list.html
Dec 05, 2013 | VillaWare Kitchen Appliances - Others
Need manual for villaware belgian waffle iorn model 2001
Free Villaware Waffle Iron User Manuals ManualsOnline com
Higher model numbers are often the same as older lower numbers.
Compare your to one of these.
Nov 18, 2013 | VillaWare Kitchen Appliances - Others
I have a kalorik heart shaped waffle maker and on the first use, after the first waffle, the waffle iron stopped working. i was wondering if there was something i could do to reset it or if i should just...
Check the outlet that it was plugged into. If you used it in a kitchen it may have been plugged into a GFI outlet (Ground Fault Interrupter). If the safety device in the outlet failed, or there was more than one heating type appliance used on the outlet or a standard wall outlet. Then you may have simply triggered the circuit breaker that addresses this device. For example, If you had the coffee maker on, or the toaster, or the microwave oven on. Using an additional appliance would pop the breaker.
Here are the possible solutions. TRY your waffle maker in another outlet. If it was plugged into a GFI wall outlet, then find the "reset button" on the outlet and push it. If it clicks, it means that it had tripped. NOW HERE IS AN IMPORTANT POINT TO FOLLOW. If you reset the GFI and plug in the Waffle Maker, then turn it on and the outlet pops off. there is a wiring defect in the waffle Iron.
If you don't have a GFI and you plug the waffle iron into a standard outlet and turn it on and it trips the breaker, then same thing. A defect in the Waffle Iron. Now if you plug the waffle iron into a good circuit and it works again. Then it was a matter of the outlet being overloaded by too many small appliances.
Very common problem. Not serious. Just reset the breaker. Or if it's a fuse, replace it.
Hope this helps,
Best, Mark
Dec 30, 2010 | Maverick WM-01 Round Heart-Shaped Waffle...
I ahve a wonderful conditon villaware waffle and panni sandwich maker. It has a knob with numbers 1, 2, 3 and 4. I have no idea how to cook a waffle on it. I am guessing you heat it on maybe 3 until the...
You can download the manual from this site:
http://www.retrevo.com/samples/VillaWare-manuals.html
Recipes:
http://www.mrbreakfast.com/article.asp?articleid=29
Bon appetit!
Jun 04, 2010 | VillaWare 6150 Mulit Baker Waffle Maker
Waffles sticking and separating
try washing the inside of the waffle maker with a damp rag then dry..
Jan 05, 2009 | VillaWare 5800 Classic 4 At-A-Time Waffler
Waffle iron top not heating
I don't know for your model type, but in many of these the heating element can be replaced. Check with an ohm meter to know if the element is actually defective, or if it is the thermo safety cutoff fuse that is blown.
If you were to do this yourself, and you know about appliance servicing, have instruments to check for proper temperature and current draw, and you will need the proper crimp-fittings (stake-ons), and crimp tool to do any of the wiring inside.
Jerry G.
May 09, 2008 | VillaWare 2005 Uno Petite Waffle Maker
Kitchen Appliances - Others Logo
401 people viewed this question
Top VillaWare Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
Michael Vincent Cruz
Angel Joseph Jr.
Angel Joseph Jr.
Are you a VillaWare Kitchen Appliances - Other Expert? Answer questions, earn points and help others
