Question about Westinghouse SK-26H520S 26 in. LCD HDTV
How to fix westinghouse sk-26h520s hdmi from computer to tv get a no signal message?
TV actually recognizes when cable is plugged in as does computer, but that turns into a no signal message on tv.
baccardo
  • 150 Answers
SOURCE: Westinghouse 26" tv SK-26H730S HDMI screen blinks with Dell Comp.
try using the 27 pin monitor input instead the hdmi possibly has a frequency variance
Posted on Apr 16, 2009
SOURCE: TV won't recognize signal from a DVI to HDMI input adapter
I had a similar problem with a Mac Mini.  The problem was caused by a mix-matched resolution (the Mac tries to use 75Hz refresh rate, TV expects 60Hz).  The best solution I found was to remote into the Mac (I used LogMeIn.com) and change the resolution on the Mac from a remote computer until the image appears on screen.
Process: 1) Connect Mac to a normal monitor and install the LogMeIn server (or other VNC type application) 2) Connect the Mac to the TV 3) Connect to LogMeIn from another computer (preferrably one where you can see the TV) 4) Go to Applications / System Preferences / Display 5) Change the resolution to your TVs native resolution, and change the refresh rate to 60Hz
Posted on Apr 29, 2009
roety
  • 585 Answers
SOURCE: Westinghouse TV no stereo
Hi my name is Roety,
I can help you with your issue ,
Why don't you simply run the cable box and DVD stereo outputs direct to the receiver. Thats what most people do. TVs do not passthrough stereo signal very well do to DHCP compliance requirements .
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Posted on Nov 11, 2009
Testimonial: "A very good solution, right under my nose. Thanks!!!"
  • 3 Answers
SOURCE: Westinghouse SK 32H540S when i Turn on TV, get
The problem is cause by the transformer on LIPS inverter (Power supply + Inverter board). You could see an obvious burn on the 1 of these transformers ( There are total 3 black transformer on this board). The part number is 4302H. It is available online at http://www.lcdparts.net/TransformerDetail3D.aspx?ProductID=2775
Posted on Jun 12, 2010
SOURCE: I have a westinghouse tv model number SK-32H240S no picture
its a inverter transformer, part no. sk32h2405 b070401
replace this and the picture will come back on
Posted on Apr 16, 2013
Westinghouse SK-26H520S no picture sound
The input signal is missing and the blue screen background comes on the screen. Change the input to some other device which you are sure works and see.
Jul 25, 2012 | Westinghouse SK-26H520S 26 in. LCD HDTV
The picture and audio keeps going in and out and HDMI keeps popping up on my screen. Is this the tv or the cable box or maybe the cord?
it could be a combination of things but here is a simple fix
unplug power from both the TV and Cable Box for at least 5 minutes
flip the HDMI cord wait 1 minute plug power cords back in
ENJOY
Dec 03, 2010 | Westinghouse SK-26H520S 26 in. LCD HDTV
Westinghouse SK-26H520S LCD TV has blue screen on the side
Vertical color scan has an open or short..............it could also be a ground problem with in the V-color scan circuits...
If you tap the tv and the color bar is gone then its a ground problem with in those circuits above. Needs a solder re-flow and check the condition of ribbon cables.
CWR
Oct 29, 2009 | Westinghouse Televison & Video
Screen black - power to tv is good.
The power to the TV may be perfect but the supply in the Tv that provides power to different areas may be bad and need to be replaced. there could be a bad capictor in the power supply that is cause.
Jul 10, 2009 | Westinghouse SK-26H520S 26 in. LCD HDTV
HDMI Port not WORKING.
Try unplugging the TV for about a minute and then plugging back in.
Mar 21, 2009 | Westinghouse SK-19H210S Television
Mar 01, 2009 | Westinghouse 26" LCD Flat-Panel HDTV
Home theater hook up
Make sure u have plugged in the audio cable to the tv.
thanks..
Feb 01, 2009 | Westinghouse SK-32H240S Television
Westinghouse SK-26H520S 26 in. LCD HDTV Logo
87 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
