The cover right in front of the TV that helps with color resolution
    President:
  • 1,383 Answers
Please explain in brief.
Posted on Jun 23, 2009
I was given an ilive dvd player boom box, model IBPD882B and the display screen doesn't work. Can I get another screen for player?
yes, but check connections
7inch TFT LCD Display HSD070I651 480×234 Resolution 7"Analog ...
https://www.ebay.com > ... > LEDs, LCDs & Display Modules > LCD Display Modules
7" HSD070I651 480X234 LCD Screen Signal Interface 26 pins TFT Specific Analog RGB, FPC. Resolution 480 ( RGB)×234. Viewing Angle 60/60/40/60 (Typ.). (CR?10) [Left / Right / Up / Down]. Display Mode TN, Normally White, Transmissive. ' eBay!
7 Inch TFT LCD Color 480 x 234 Resolution Stand/Mount Rear Button ...
https://www.amazon.co.uk/234-Resolution-Button-Monitor-420-TV.../B013FVEJP2 7 Inch TFT LCD Color 480 x 234 Resolution Stand/Mount Rear Button Leg Monitor with 420 TV Lines Night Vision Camera: Amazon.co.uk: Car & Motorbike.
7-inch TFT LCD Module with 480 x 234 (RGB) Resolution, Available in ...
www.globalsources.com > All Categories > Electronic Components Number of the colors: 65KModule dimensions: 164.9 x 100.0 x 5.5mmVA size: 7 inchesAA size: 154.08 x 86.58mmResolution: 480 x 234 (RGB)LCD type: TFT and transmissiveViewing direction: 12:00IC: HX8227-A01 and HX8655-ABacklight: CCFL backlightOperating temperature: -10 to 60 degrees CStorage temperature: ...
Feb 06, 2018 | iLive Televison & Video
Using Powerpoint ande showing on 47 inch tv screen - it does not cover entire screen what do I need to do to get it to do so?
I dont think it is a problem with your tv but more towards your video card. The video card can only handle a certain resolution to be projected on a screen. However, you max resolution your card puts out may not be compatible with the resolution that your tv can display. Try going into your video card settings and change the display resolution till your tv detects a compatible one. This can be found most of the time in the lower right hand corner of the screen where running programs are found.
May 12, 2011 | Computers & Internet
OK, following your advice of March 9th I got a new lamp from Mitsubishi and replaced it tonigh in my Mitsubishi rear projection model WD-62725 TV. The old lamp was clearly broken. However I have...
hi,
That sound may from the color wheel. Open the angine, open block front of lamp.
open cover of color wheel and grap it.
mas_baz_23.jpg Rotate color wheel manualy , listen it. If hear fristing sound, means color wheel is bad. Replace it too.
mas_baz_24.jpg Good luck.
Mar 24, 2011 | Televison & Video
I have a Hitachi projection color tv and I cannot get the color adjusted good especially the red. Can you help me?
U know how to solders?Ur convergence it dead,need it replaced parts,by buy convergence kit.Tries Tv repair World.com,Tvrepairkits.com.
Dec 20, 2009 | Hitachi 43UWX10B 43" Rear Projection...
My color is off on my whole tv i have a 52''projection toshiba cinema series the old big style and was wondering how to adjust the colors so they match up
Sounds like what was wrong with mine! Take the remote and hit menu, then scroll to the Video Adjust button, then adjust the "convergence" or the color tone, brightness, contrast etc. My repair man did this and it helped get the picture much more life-like. He said over time they get out of line and just need a few adjustments. He just charged the $50 house call. Good luck, hope you can fix it.
Dec 11, 2009 | Toshiba 50H81 50" Rear Projection...
I have a philips HD rear projection TV 60 in. inside there are six adjustment knobs. Three are color the other three are for brightness contrast and hue. Which is which Left to right
If yours is a rear projection TV the adjustment knobs on the focus block inside are screen (red, green, blue) and focus (red, green, blue). The ones you are referring to as color are the screen controls and they adjust the intensity of the color from each tube. The other set adjust the focus of each color. They are also not intended to be adjusted by the user. Unless major components have been changed these controls should not need adjustment. That is why they are inside the TV.
Dec 05, 2009 | Philips 60PP9352 60" Rear Projection...
Sony Videoscope XBR TV
just need to balance the three colors red,green and blue that may help remove the front covers and look for black module that have sccree and focus controls just move a little bet left or right be carefull because you can loos the picture e-mail me for more info
Apr 07, 2008 | Sony KP-53XBR45 53" Rear Projection...
Sony kp-65wv700
I followed GuestUser/ Slinteriors advice and I fixed it. Open the front of the TV and there are 6 little nobs in the front. The botton 3 are what you need to adjust. from left to right the color controls are BLUE, RED GREEN. For the blue lines, slightly (I really mean very slightly) turn the botton left nob clockwise (right).
Mar 21, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Help me
You need the drivers here or here to connect the camera via USB to your computer.
Dec 16, 2007 | Kobian Mercury 3.1 Deluxe Classic Digital...
How to use buttons on front of Monitor for vertical Horizontal settings
Oldie, The first thing to do is set the monitor resolution, color depth and monitor refresh rate to what you want then adjust the monitor accordingly. Adjust resolution, color depth and refresh rate for Windows 2000/XP: -Right click any clear spot on your desktop and select properties from the menu that appears. -From the Display Properties box that appears click on the Settings tab. -In the screen resolution section (lower left corner) experiment with the resolutions and see what you like. -The color quality box should be set to the highest (most colors) color setting listed. -Click on the advanced button in the lower right corner. -In the next window click on the monitor tab. -Typically you would want to set it at 70 Hertz or better. The higher the setting the less flicker you will notice, however, there is always a trade off. I would start with 70 Hertz and gradually move up; at some point your monitor will reach a setting it can?t support. If the screen blanks out Windows will reset back to the previous settings as long as you don?t hit any keys. -click the OK button twice. More to follow?.
Mar 14, 2007 | ViewSonic E790 Monitor
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
