Question about Kenmore 73952 Gas Dryer
My dryer runs ok but no heat - Kenmore 73952 Gas Dryer
  • 351 Answers
Model number? gas or electric? www.whirlpoolpartssurplus.com free tech advice parts ship the same day
Posted on Jun 23, 2009
Awz 9813 whirlpool
Check your thermal fuse, if that is ok make sure that your heating element has continuity. Also check your cord you need 240vdc at machine to operate, it will run with 120vdc but needs 240vdc to also heat.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gary_58e9c3508cafe590
Jul 31, 2013 | Dryers
Kenmore Dryer 300 Series No heat , I check continuity to all parts , it ok , but still no heat on dryer What's wrong?
What is the model number?
Exactly which parts did you check?
Also, check the breakers. The breakers are 220 and one of them may have thrown not allowing it to heat but the dryer will run.
Oct 17, 2012 | Kenmore 400 6942 Dryer
Dryer runs but won't heat
You will need a professional to diagnose the thermal limiter, small version of a fuse, heating element and the dryer/blower assembly.
Aug 17, 2012 | Frigidaire Electric Dryer
Whirlpool electric dryer LER5620KQ1. won't heat up timer does not advance
Same problem with my Whirlpool Dryer: Model LER4634EZ2 which stopped heating. I checked the coils that was "OK" then I checked the fuse that was "OK" I replaced the Thermal Fuse and High Limit Thermostat then after starting the dryer the heat came on ... problem solved NO.... the dryer just kept running and running until I opened the dryer door. Not going to put 70 or so $$$ into this 10 year old dryer which up until 12/15/2011 worked fine.
Dec 08, 2011 | Whirlpool LER5636P Electric Dryer
Dryer will not run...checked fuses ok.....240v ok....what else could it be?
if it won't turn or anything its probably the neutral wire on the terminal block in the rear of the unit,they carry a high amount of current and can get brittle and break off or burn off in time check the incoming power connections first,if it turns but doesn't heat,then it may be your thermal fuse located in the vent duct housing inside the dryer if this opens you will not get any heat from either a gas or electrically heated dryer
May 18, 2010 | Dryers
Dryer has no heat to it, but runs
Running is good. That means lots of stuff is working. On the motor is a switch that turns the heat on once the motor gets up to speed. The other wires on the motor are start and power for run. Check your heater elements for continuity. Running usually means the door switch is ok, timer ok. Check around for fuses, burnt wires, loose wires. Check the heat sensors for continuity. They should conduct electricity untit they get hot.
Apr 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Motor runs fine, heat element will not heat, replaced heat element, no luck. Safety's checked out, timer ok.
Make sure where you dryer plug cord hockes into the dryer has 220 with a voltage meter read from left one to the right one should get 220 from right one to middle you should get 110 and from left onetto middle you should also get 110 the dryer will run with 110 but will not heat
Mar 28, 2009 | GE DBSR453EBWW Electric Dryer
Dryer runs but does not dry my cloths.
Hello, If the dryer appears to be running ok but will not heat you probably have a bad heating element or switch. Usually the heating element.
I hope this helps
CYA Gator241
Feb 09, 2009 | Maytag PYE2300AY Electric Dryer
No Heat - Electric LQC Test OK
Try and re-set your 220V breaker one time ,because your dryer will run 120V for the motor to run,and the other 120Vsupplies the electricity to heat the coil.Small chance it could be half the breaker is off.Second, if the advise above doesnt correct it than odds are its a bad igniter.Some dryers have a amall re-set on the high limit thermostsat
Apr 26, 2008 | GE Profile Harmony DPGT750EC Electric...
Kenmore 73952 Gas Dryer Logo
145 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
