Question about Makita RF1101 Electric Routers, Fixed & Plunge Routers
What hp router is best to make cabinet raised doors
  • 4 Answers
I used to use a Ryobi 2.5 hp and it worked fine but if you are concerned go higher hp. It's probably more important that the router is a variable speed model. The bigger the size of cutter required for raised panel doors the more torque and revs are produced. You need to ensure starting on slowest speed and adjust up to speed required. Speed should be based on size of cutter and to me is set by sound( a nice hum, not screaming) and vibration( NO VIBRATION)! The cut needs to be done in several passes, maintaining constant feed speed,( don't burn your expensive cutter) allowing cutter and machine to do work maintaining the hum and no vibration. And of course set your guards etc!! If this is on going work for you perhaps look into a spindle moulder with attachment to take router cutters
Cheers Capt Mark
Posted on Jun 15, 2014
My name is Lawrence K. I bought a skil rail
She just needs a tool that could work for making door frames or else she cant build a door frame. The answer is she can do it if she buys a tool.
Jan 04, 2015 | Crafts & Hobbies
I know this seems like a minor problem, but the fact that the freezer door on my Superba side-by-side is about 1/4 inch higher than the fridge door means that it constantly bumps on the cabinet door above....
Welcome to FixYa.
The fact of the matter of the doors being at different heights is typically an indication the unit isn't level and can be simply corrected by way of screwing the legs/wheels up or down.
If you remove the grill below the doors you should see the wheels and the adjustment screws/bolts. #2 is the wheel, # 3 & 5 are the adjustment screws to raise or lower the unit.
i.e.
They are typically a 5/16" or 3/8" hex head/slotted combination. Try adjusting one or the other with small adjustments until you notice the two doors starting to level to each other.
Let me know how you manage and I'll try to help you in any manner i can going forward. Good luck.
Thank you for choosing FixYa today.
Regards,
Macmarkus :)
Jan 10, 2011 | KitchenAid Superba KSRS27CN Side by Side...
Freezer door has dropped, how do you raise it?
As there is no adjustment possible to raise the door, the likely culprit is a bent lower door hinge, or a damaged cam riser. Also, I've had calls where the freezer was in the basement, and due to an eneven floor, usually for the purposes of water drainage, this can sometimes cause the freezer cabinet to get out of whack.
Oct 01, 2010 | Whirlpool Upright Freezer EV161NZRQ
Cp 2025 cartridge tray is jammed into printer.
If the tray is visibly damaged there is not much to do and service is required, you can try to remove the carriage but this would void your standard warranty, your best bet here is taking the printer to an authorized support provider near you, you can find the closest one to you on the hp website or call hp's tech support.
1800-334-5144
Al
eliteprintersolutions@gmail.com
Jan 27, 2010 | HP Laserjet Cp2025n Printer
Adjustment of the fresh food door.
Normal for freezer door to be slightly higher, The upper hinges can be adjusted to make minor changes and raising the front roller under the rlower door will(or lower the higher side) help align them. It is a trial and error adjustment that takes time to get the best compromise of door alignment to cabinet setting.
Eric
Oct 16, 2009 | Refrigerators
Kenmore 70 series washer 20702 wont rinse or spin.
The part is easy to find but a bit complicated to get to. You need to raise the console then unclip the cabinet. Please pay attention to how the cabinet fits you,ll have to remove it and reattach it to the back support plate. Good luck.
Aug 23, 2009 | Kenmore Washing Machines
One door lower than other, how to adjust door
The door can be adjusted with shims on the hinge post or by adjusting the cabinet by raising the front corner opposite the higher door. Keep in mind the doors are not designed to be perfectly even.If the difference is the depth of a quarter or less it is good. The seals making good contact all the way around is more important. Eric
Aug 08, 2009 | Viking DDBB363 Bottom Freezer Refrigerator
Will the Jenn-Air JFI2089ATS accept 3/4" thick raised panels?
Hi: Raised panels, beveled are used all the time. Just check clearance of the thicker doors. Walls etc. Hope this helps, Jeff
May 30, 2009 | Jenn-Air JCD2295HES Side by Side...
Need to inspect tumbler, belt etc. Hoe do I get
Unplug the dryer.
Open the door.
Remove the 4 visible screws.
Raise the hinge side of the door and remove the door,
The front panel will pull out.
Remove 2 screws on the top right and left of the cabinet just under the top panel.
Raise the top.
You will also have to remove the front drum support. 2 screws right and 2 screws left.
Mar 01, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Freezer door needs to be raised
just put some washers (plastic washers are best) on the hinge pin to raise the door
Nov 16, 2008 | Whirlpool ET0WSRXML Top Freezer...
Makita RF1101 Electric Routers, Fixed & Plunge Routers Logo
83 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
