Question about Frigidaire 5.1 Cu.Ft. White Chest Freezer - FFFC05M4NW
Why will the freezer not come back once it reach coldest temperature?
3 Suggested Answers
  • 256 Answers
SOURCE: Freezer is on but no longer freezing. The freezer
You could have an issue with the temperature control, the compressor or refrigerant, or compressor attachments (e.g.: relay, overload or capacitor (if applicable). Contact an appliance service company.
Posted on Apr 14, 2010
Sea Breeze
  • 4654 Answers
SOURCE: FREEZER THERMOSTAT
Sounds like the thermostat is not working. Mechanical and electronic thermostats can go bad and cause the freezer to continue running no matter what setting is set on thermostat. When this happens the only setting that will work is turning the temperature setting to off. What is the model number on your freezer? Sea Breeze
Posted on Apr 04, 2013
Electrolux freezer will not turn on automatically when termperature warms in compartment, controls don't appear to turn compressor on, any help would be appreciated?
Sounds like your thermostat is bad. You probably have to replace it and the sending unit also. Big job! Look for a manual at : http://www.servicemanuals.net
Apr 28, 2014 | Electrolux Freezers
Which way do I turn the temperature dial on a true 3-door reach-in stainless steel cooler?
Numbered 1-9 - one is the warmest setting, nine is the coldest. For a cooler it should be good on 5 for a freezer 7. If it doesnt work well on those settings the thermostat is usually bad.
Aug 03, 2013 | True Freezer GDM-49RF
How to set fridge temp
    1. The first thing you must know is that your refrigerator should be set at 37-38 degrees. Anything at 40 or higher and you are risking food born illness (food poisoning) or spoiling your food. Place your magnetic thermometer in the refrigerator.
    2. Set your dial on your refrigerator to the second lowest setting. (If your refrigerator is already equipped with a digital thermostat, simply set it for 37 or 38 degrees and do not move on to the next step)
    3. After 2 hours, check your thermometer reading. If your reading is 38 degrees, there is no need to go higher and you are ready to put your groceries in. Be sure not to open and close your refrigerator during these two hours or your temperature reading will be incorrect.
    4. If your reading is higher than 38 degrees, move your dial up to the next coldest setting and repeat the steps every two hours until you reach the correct temperature for your refrigerator.
    5. Once you have reached the correct refrigeration temperature for your refrigerator, place the magnetic thermometer in the refrigerator permanently and watch for changes.
    Typically, your refrigerator temperature will need to be adjusted with the seasons, a higher setting in the summer and a lower setting in the winter.
Dec 19, 2010 | Freezers
How do I adjust the freezer temperature on a Kenmore upright freezer?? Brand new, model number 461.27432, didn't come with a manual.. can't tell whether 7 or 1 is considered the coldest temperature?
Sorry there is no manual on-line for the freezer. But I can tell you this 7 is the coldest and 1 is the warmest.
Good Luck and Please rate 4 thumbs up for the free answer.
Jul 04, 2010 | Kenmore Freezers
Hi,Ihave had my electrolux fridge freezer for two years now and it is sited in my garage.When it gets really cold the freezer turns off defrosting everything,just found out if it drops below 10 degrees it...
Good day,
Not really. Domestic refrigerators are designed to operate in an environment where people live.
Most all manufacturers recommend that they not be placed in an area that goes below 55 degrees.
At any temperature below that it starts to degrade.
Cold enough and it will not work at all.
The reason is once the fresh food compartment reaches it's normal temperature of 33-37 degrees, it shuts the whole machine off.
That is by design, on any refrigerator like yours that has only one compressor and cooling fan motor.
As well, there are other issues. In that situation, the machine could well stay off 12 to even 24 hours.
The compressor has an oil sump in it, and the oil becomes very thick. When it finally tries to start, it creates a very stressful situation for the compressor, and could substantialy reduce it's life.
Jan 17, 2010 | Freezers
I need to know what the numbers mean on the temperature setting (1-7) for my Gibson Upright Freezer? What is best recommended temperature?
The highest number is the coldest setting.When you fill it up with food to freeze , set the freezer to the coldest and after everything is frozen .set the control to the middle.
Oct 05, 2009 | Freezers
Food in freezer not frozen; food in refrigerator not cold
1.check the coils on the back or under side.
2.check if compressor is running
3.check if copressor is hot
4.let me know the answers
Jan 14, 2009 | Freezers
Frigidaire side by side model# PLHS269ZCBO
How cold is the freezer? Check the condenser coils for cleanliness and clean if necessary. Condenser may be located in the back behind a fiber panel. Ice maker is dependent on temperature and if the freezer is not reaching a low enough temperature it will affect your ice production.
May 06, 2008 | Freezers
Frigidaire 5.1 Cu.Ft. White Chest Freezer - FFFC05M4NW Logo
62 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
