Question about Sony Bravia BX330 32-inch KDL32BX330 720p LCD HDTV
How do I stop it from scanning channels
When I turned it on it won't stop scanning channels. I tried unplugging it, then plugging it back in, changing the batteries, unhooking the cable connection and the light keeps flashing instead of staying steady. The TV is running through the channels and when I push "home" on the remote it scans the home menu really fast. I have changed the input pushed all of the buttons on the remote and TV to see if anything is stuck and it does not seem to be. Any suggestions?
techman
  • 3130 Answers
SOURCE: Remote/tv buttons not working & start-up menu flashing
You can get an original replacement remote that will work all functions from Here: http://www.remotes.com/remotes/servlet/rs?o=c&a=Search&m=KV-27FS200&uid=11829594841080 Good Luck
Posted on Jun 27, 2007
SOURCE: remote control not responding
Perhaps you can try what I do when my KV24FV300 runs through channels and will not stop.  Hard to watch and remote will not work.  Nothing works but on and off from set.
Sony Says:  Take all batteries out of ALL remotes that you use in any way for that set, VCR, etc.  ALL batteries out.  Turn TV off at set.  Unplug TV.  Wait at least 15 minutes then replace all batteries in ALL remotes.  Plug TV back in and turn TV on from set.
Maybe, just maybe it will work.  If it does not work why not call Sony, they always say that cannot happen but they have a solution for it.
niteowl@dejazzd.com
Posted on Oct 26, 2007
ctf1800
  • 4402 Answers
SOURCE: Favorites Keep Coming On
Check to see if the lower buttons are stuck. You should feel a 'click' when you depress them. If one of them is stuck... you found the problem. Now you need to fix it. All you need to do is pull on the plastic button just a little to give some spring back to it. Or try a needle with a bit of a hook on it. Side it in the right side of the button and pull the button forward. Just be careful not to pull it to far. Just enough to correct to position.
Do you spray windex on the face of the tube??
Read this artical
http://www.fixyourowntv.com/wifekilledtv.html
Posted on Jan 28, 2008
  • 3 Answers
SOURCE: Volume Problem with my TV and Home Theater system
I had the same problem with mine.The solution I found was to use an optical audio cable rather than the red and white RCA audio jacks. Hope this helped.
Posted on Jan 03, 2009
welcomejee
  • 10594 Answers
SOURCE: why does push power protector keeps flashing in
This is an error massage and comes when home theater got some internal problem specially in amplifier output section that can have defective output IC etc.
It is not user level repair and requires qualified tech for fix.
Thanks.
Posted on Sep 14, 2009
Why is my remote control not working despite changing the batteries.
Not sure if this will help but, I recently put an antenna on the roof of my house. I don't watch TV much but wanted to enjoy some TV, but my remote locked up and the side buttons on the TV wouldn't work either. I tried changing the battery, but no luck. There's a broadcast station 64.2 that is locking up TV's & remotes. Here's the fix that a TV repair co. gave me which did break the lock of the station 64.2.
1) unplug antenna (not roof but connection from TV to wall)
2) unplug and plug back in TV
3) find a way via remote or side buttons to scan channels
4) Go to Menu
5) EZ Setup
6) Channel Set Up-Scan Channels
7) Channel Memory
8) Digital Set Up
9) Turn Skip On for 64.2 (Delete this Channel)
10) Turn off TB
11) Hook Antenna back
You may have to play with the order to acheive the end result or figure out a way to delete 64.2, but during the process you will at least unlock from being stuck on 64.2.
Good Luck if this was the same issue!
Jul 14, 2014 | Audio Players & Recorders
Tv will not turn on
This sounds like it might be a main board issue. Depending on the television brand there are different replacements you can get at different prices. I would try unplugging the tv from the wall first then try plugging it back in while holding channel up/volume up on the tv as you are plugging it back into the wall. If this doesn't change anything it is most likely a problem with your main board.
Jul 23, 2012 | Vizio VO47L 47 in. LCD TV
Never had an issue until yesterday... When I turn the tv on,it immediately begins scrolling through all the channels and won't stop. It will not respond to the
I will assume you tried to unplug the set and plug it back in.
If you are using a sat or cable box connected to the cable fitting on the set try connection from the AV jacks to one of the video inputs on the set.
If set does it via the rear jacks it is likely the box and not the set.
Mar 15, 2012 | Samsung HL-T6187S Television
I have a 37LG505H-UB LG LCD TV and when I watch it, it all of a sudden starts scanning for channels on the RF input even though I have it hooked to HDMI on the STB. It won't stop and when I turn it of
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Jun 03, 2017 | LG Televison & Video
Have problem with Philips On digital terrestrial receiver (DV3). Since the digital switchover in Bolton, where I live, it wont let me do an update. Can't get any channels now. Stewart
Try unplugging the unit from the wall, unplug the Aerial cable from the box. Plug the mains back in and switch on. Do a channel scan (with the aerial still unplugged). Reconnect aerial and do another scan. With luck it will have flushed the old settings and pick up the channel changes.
Regards
Zahc
Jun 17, 2010 | Televison & Video
The digital tuner on my Olevia LT37HVS LCD TV freezes sometimes. When it does, you can't change channels, adjust the volume or even shut it off short of unplugging it. All of the other A/V inputs work just...
Tune the tv to a channel that is just blue screen. Then turn the tv off and unplug for at least 30 sec. Then plug the tv back in and turn it on. Then leave the tv on the blank screen channel go into the menu and do auto cable channel search. After the search is complete try all channels. This worked for me. My tv will not scan if the tv is on a channel that comes in. GOOD LUCK these tv's are junk .
Sep 21, 2009 | Televison & Video
RS Pro 2020 Scanner won't come out of scan mode, pad ineffective
If you mean a Bearcat 2020 radio, then that unit is ancient, and I'm amazed that it still works. If you're only monitoring one frequency, you can get a really cheap scanner to do that and replace the 2020.
Aug 01, 2009 | Radio Shack Pro-2018 Scanner
Radio Shack (Realistic) PRO-2020 Scanner stuck in Scan Mode
Sounds like old age - the 2020 is nearly 30 years old! Have you tried just using the LOCKOUT feature on all channels except the you want? How about just programming the same frequency into all 20 channels?
Jul 25, 2009 | Aiwa AV-S17 Receiver
Scanning channels stops at 20%
the exact same thing happened to my dta800. i unplugged the ant. input at 20 percent and then plugged it back in when it resumed. i dont know why this worked, but i now get my 25 channels instead of the 4. this digital garbage is annoying all around. hope this helps. senor punko
Jun 19, 2009 | Televison & Video
RCA P52929 changes channel non stop
try unplugging it from the electric wall outlet for an hour then plug back in, this should reset your tv back to factory default, you will have to adjust your setings if you changed them
Jan 25, 2009 | RCA P52929 52" Rear Projection Television
Sony Bravia BX330 32-inch KDL32BX330 720p LCD HDTV Logo
21 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
