Question about Vehicle Parts & Accessories
Montan transport plug on the fule pump - Vehicle Parts & Accessories
  • 24 Answers
What do you need to know? Its located on the gas tank; its got to be plugged in to work; Red is power; what specifically do you have a problem with?
Posted on Dec 10, 2014
I have a 225 that has spark and good comp but wont start the man said it could be fule pump ?
Compression, fuel, timing and spark and a sufficient cranking speed are all required for an engine to start. Each should be checked through systematically but check the immobiliser first.
Dec 28, 2016 | Cars & Trucks
No fule at fule pump ford ranger 2.5 td 2004
Check inside the fuel tank for a plug or restriction .
Dec 12, 2015 | Ford Cars & Trucks
P0410 pontiac montan 2001
The fault has to do with your secondary air injection system. They most likely cause is a bad air pump
Mar 05, 2013 | 2001 Pontiac Montana
Engine wont start when cold but after starting with starting fluid runs fine
The heat might have melted or damaged your main relay. Does it turn over or try to start, or does the lights simply come on and it does nothing?
if you need a diagnostic tool click here
great diagnostic tool
Oct 19, 2012 | 1997 Chevrolet K1500
My car was running great, i killed the car ran inside and back out about 10min later and it would not start! Replased the fule pump, still will not start. 2008 mustang gt
Is the fuel pump getting voltage and ground ?
Are you getting spark at the plugs ?
Could be a crank sensor or relay among other things.
Jul 28, 2012 | 2008 Ford Mustang
Car doesnt get fuel to spark plugs
replace the fule injecters or the full pump or check the fule pump fuse
Mar 05, 2011 | 1993 Honda Civic 4 Door
CHANGED THE FUEL PUMP,THE FUEL FILTER,THE O2 SENSOR,THE SPARK PLUGS,THE ECT SENSOR, THE IAT SENSOR, NEW FUEL PUMP FUSE, BUT IT DOES NOT WANT TO CRANK
IS THERE POWER TO THE FULE PUMP DID YOU CHECK THE FULE PUMP RELAY YOU CAN CLICK OFF AND ON WHEN TURN THE KEY OFF AN ON ITS UNDER THE HOOD DO YOU HEAR IT CYCLE WHEN TURN THE KEY TO ON POSITION HAVE SOME ONE TAKE THE GAS CAP OFF AND LISTEN FOR THE FULE PUMP TO RUN FOR FIVE SECONDS IF THEY HEAR IT THEN PUMP IS RUNNING AND OK WHEN YOU TURN THE KEY BACK OFF WAIT 10 SECONDS FOR IT TO RESET AND IT WILL CYCLE AGAIN WHEN YOU TURN THE KEY ON .. IF THAT IS OK CHECK FOR SPARK AT A PLUG IF YOU HAVE SPARK AT THE PLUG THEN ONE SHOT EITHER IN THROTLE BODY AND TRY TO START IF IT FIRES THEN WE CAN TAKE FROM THERE LET ME KNOW HOW YOU DO HERE POHLCAT
Mar 04, 2011 | 1995 Isuzu Rodeo
I have a 1998 ford wind star new fule pump but still not geting fule , wont crank engine turns ove but won;t start
INSTALL PRESSURE GUAGE THEN CK, VOLTAGE TO PUMP PCM TURNS ON PUMP RELAY FOR 2 SECONDS WHEN KEY CYCLED ON ,, IF NO POWER CK INERTIA SWITCH ( MAY BE TRIPPED ) IF NO POWER TO INERTIA SWITCH CK FUEL PUMP RELAY IF NO VOLTAGE AT PUMP RELAY THEN CHECK FOR SPARK AT PLUGS IF NO SPARK CK PCM POWER RELAY IT SUPPLIES VOLTAGE TO PCM THAT INTURN POWERS FUEL PUMP RELAY
HOPE THIS HELPS
Aug 08, 2010 | 1998 Ford Windstar
1989 Corvett After running great, started missing and stopped will not start again
cheek youre plugs and plug wires four the miss firing depinding if the car spudder before it died could be fule problem cheek the fule pump fule injectors and fule filter if its carb make sher its set rite <is it still turn over or complety ded win you put the key in
Feb 28, 2010 | 1989 Chevrolet Corvette
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
