Question about Dishwashers
Asko d3350 blocked outflow - Dishwashers
SOURCE: Asko D3350
Code F7 means "The drain is blocked"
I refer to the troubleshooting section : http://www.askousa.com/pub/manuals/dishwashers/current/English-D3350_UCG.pdf
Posted on Jan 19, 2008
  • 24 Answers
SOURCE: ASKO D3350 Dishwasher won't work.
possible failure of electronic board expensive to fix. May even be suprresion capacitor. A lot of brands used suppression caps on the ac input to filter out unwanted noise. When these blow they stink and some even arc but one thing is sure they cut the power to the rest of the dwasher may even throw out your power.Make sure it is switched off and unplugged before dismantling it.
Posted on Oct 08, 2008
SOURCE: Faulty Asko dishwasher
We were told by an ASKO technician that it has something to do with a balance issue. You could try tilting the machine forward (make sure you've removed side screws into walls first though otherwise you could damage the cupboards).
Posted on Apr 11, 2009
  • 118 Answers
SOURCE: asko D3350 displaying F2
possible water in the base tilt the machine slightly forward and empty the water in the base onto a couple of old towels.... then start the machine and dont use tablets just use finish powder and rinseaid
Posted on Feb 10, 2011
  • 196 Answers
SOURCE: asko d3350 has the f2
sounds like you have a water leak. The machine is fitted with a leak detection device that runs the drain pump constantly as a safety mechanism. If you want to look your self you will need to pull the machine out and tilt it back and if possible remove the bottom panel, should be 4 screws, this gives you access to the components. If it doesn't come off then you will need to remove either 1 or both of the side panel, its just a number of screws holding them. Then see if you can see where the leak is coming from, you may need to order a new part. Hope this helps.
Posted on Mar 03, 2011
Hi I have an Asko D3350, and have an 'F7' problem, can anyone help. Starts all wash programs then stops half way through with f7 showing. but the pump and discharge hose is clear. If it means anything it...
At the bottom of the dish washer where the water drains from there is a rectangular hole at the back (you will need to remove all the baskets and the screen). Grease can accumulate here and block the tube that feeds a pressure switch, causing this malfunction. This grease will not be visible as it sits under a lip on the other side of the rectangular hole and above it. This would need to be removed carefully as one doesn't want to push the grease into this tube
Feb 02, 2011 | Asko 24 in. D3350 Dishwasher
We have an Asko D3350 Dishwasher and the upper blade does not appear to be spinning and the dishes are not coming clean. Bottom appears to be working fine and dishes on bottom are clean. What could be the...
On my d3350 it is possible to choose which tray (bottom, top or both) is cleaning.
The button is the bottom left, and above it there are two lights. As you push this button, the lghts cycle through lower tray, upper tray and the both trays. You want both lights on.
Also try this - take the spray arm out (it just snaps free) and rinse it out in case there are some blocking materials in the arm which are stopping it from spraying
Dec 30, 2010 | Asko 24 in. D3350 Dishwasher
I have Asko D3350 dishwasher and the Detergent dispenser does not open. We were told to remove the whole dispenser and soak it in water but how do i remove it?
to remove the dispenser is not a 30 second job. You have to remove the door front with a T20 (torx) screwdriver (don't forget the 2 screws in the middle of the door at the bottom) Then you can get to the screws that hold the dispenser in place. Make sure you remove the solenoid from the dispenser BEFORE soaking in water. A more likely issue is either the solenoid on the dispenser has failed and will show signs of burning and/or damage or one of the transistors on the control board may have blown.
Oct 25, 2010 | Asko 24 in. D3350 Dishwasher
Hi,\r\n
yes you need to reset dishwasher to time fill.turn off the power button wait 10 sec,push and hold the programme and start buttons then turn power back on.hold buttons down until display lights up then release them.press programe button until 4 shows in display,then press start.test dishwasher. F4 is an inlet fault.
Jun 07, 2010 | Asko 24 in. D3350 Dishwasher
F7 code
yes remove filter and water from under filter theres a small chamber at the back of the sump,it may be full of fat clean it with your finger then try running some heavy wash cycles to clean it.
May 02, 2010 | Asko 24 in. D3350 Dishwasher
Asko 3350 F2 fault meassage keeps flashing
you have a blockage try the drain spigot under the sink or the pump may be blocked.
Apr 23, 2010 | Asko 24 in. D3350 Dishwasher
Apr 04, 2008 | Asko Dishwashers
Asko D3350 code F7
Service manual says:
LED L1+L2/Fault code F7, Pumping out fault
(machines with pressure sensor)
Water not evacuated after 120 seconds’ pumping
out. Programme interrupted.
Check: Drain pump, hoses, installation of drain
hose, control unit and wiring.
Jan 19, 2008 | Asko 24 in. D3350 Dishwasher
Asko D3350
Steve, according to the codes listed on http://www.repairclinic.com/0078.asp apparently F7 is a bad door latch. It could be just not shutting fully or maybe one of the springs/rods needs looking at.
Is there anything recently that may have happened to the door? Slamming, jarring, etc.
Dec 21, 2007 | Asko 24 in. D3350 Dishwasher
Dishwashers Logo
16 people viewed this question
Top Dishwashers Experts
