Question about LG Heating & Cooling
Where is the shop of this sensor - LG Heating & Cooling
2010 Nissan Altima, my ICY alert is now on and will not go off?
You can Disable that warning. The body shop probably unhooked the battery and this reset the warning. In any collision, the body shop is supposed to have a mechanic check the rest of the vehicle. Take it back to the shop. The temp sensor could be having issues on the air flow sensors.
Dec 11, 2014 | 2010 Nissan Altima
How to reset sensor
Steering angle sensor can only be reset with a special diagnostic tool. Sorry.
Mar 19, 2014 | 2008 BMW Z4 2.0i
2000 dodge intrepid revs exsessive
you apparently have a throttle position sensor that is bad refer to electronic sensor book or nearest shop for electronic diagnostic kit available at local auto shops it will read out your trouble code from there then replace faulty sensor.
Mar 08, 2014 | 2000 Dodge Intrepid
2001 Lincoln LS V8 Advance Trac sensors replaced, but amber light on dashboard will not quit flashing. Shop cleared the codes when they replaced the sensor. The
The repair shop did not make the repair necessary
There are no advance trac sensors
Advance Trac is an add on option when new,
to the ABS Braking system
Even if the mil lamp is cleared, there will be codes
there when you access with a professional scanner,
since you have the amber lamp on
The only sensors are wheel speed sensors
Oct 01, 2012 | 2001 Lincoln LS
Is Bank One Sensor One code P2195 legitimate?
the 02 sensor on the top of the exhaust manifold is faulty, you can check and see if there are any cut wires to it, that is only way i can think of it being tampered with.
when you replace the sensor make sure you use a denso and not a bosh or it will not work properly.
Sep 27, 2012 | Toyota Highlander Cars & Trucks
Abs light flashg on and off on dash pannel yellow
One of your anti lock brake sensors trigger fault with computer. With Benzs can be an assortment of issues; Sensor loose, sensor shorted or corroded not making good connection and as sensitive as Benz sensors are, low brake pads causing harmonic squeal can trigger sensor. I'd have a specialty shop look at it for you (or the dealer) it can get REALLY expensive just throwing parts at it. Another tip, only specialty shops, body shops and dealer has reset tool to reset lights (safety related)
Feb 28, 2011 | Mercedes-Benz Sprinter Cars & Trucks
My renault megane 1997 1.6 rt manual cars speedo is erractick . i think it might be the sensor but where is it located and how easy is it to remove?
mcdevito75 her, If you mean the engine idle speed, it could be the air idle sensor, Best Bet have your local auto repair shop run a scan. You yourself would really only be guessing which sensor and the sensor parts themselves are expensive a scan by a shop can pin point which sensor.
Jan 31, 2010 | 2000 Renault 181
2000 Maxima Automatic Transmission Hang Up
hi if the shop worked on your transmission and you specified about this code then they are reliable they should fix with no cost being that you paid for this service already good luck
Sep 10, 2009 | 2000 Nissan Maxima
1995 olds alero; how to repair a brake sensor....car shop
YOU HAVE TO REPLACE WHEEL SENSOR.IF THE BOLT HOLES BROKE.THAT HOLDS IT IN PLACE.NOW IF YOUR WHEEL SENSOR SCREWS MISSING YOU NEED TO BUY THEM AT DEALERSHIP OR SALVAGE YARD.BESURE TO GET SCREWS BEFORE PUTTING A NEW ONE ON.WITH OUT THIS SENSOR IN PLACE IT WILL CAUSE ABS BRAKE PROBLEMS.
Aug 04, 2009 | 1999 Oldsmobile Alero
Heating & Cooling Logo
10 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
