Question about Garmin nuvi 200W GPS Receiver
Mapsource doesn't open.
When I open Mapsource, it says, "Mapsource could not find any installed Mapsource products." How do I fix that?
    Brigadier General:
  • 4,090 Answers
Usually by installing the maps!
Posted on Jun 23, 2009
Trying to update my garmin nuvi maps. I have a new computer and the favourites button is gone so I used to just click and it would upgrade.
install the software that came with the garmin , when you plug the garmin into your new computer you should have a new hard drive appearing open it and install the mapsource program, if it doesnt already autorun. Once you have mapsource installed you will be able to then update
May 15, 2011 | Garmin GPS
I have lost my Mapsource Setup cd for my Garmin GPS
  1. Download MapSource software updater from Garmin. The version as of December 4, 2007 is 6.13.6, and the trick also works on Map Source version 6.13.5.
  2. Unpack or extract the content of MapSource_6136.exe
    downloaded using WinRAR.
  3. From the extracted files, run MAIN.msi.
  4. Then, run Setup.exe. Note: The sequence to execute Main.msi and then Setup.exe is important to avoid “Previous MapSource not found!” error.
  5. Garmin MapSource now installed.
Feb 02, 2008 | Garmin eTrex Vista GPS Receiver
How do I update the maps?
TO GET 2009 MAP IS NOT EASY! Software update is, from the site you can update software easily BUT THE MAP... you must purchase fro $69.99 OR if you're a technical person who knows the following instruction you can save some $$$
search
CNNANT2009-1 MapID 396
under torrent sites, you know what you're doing.
Use these instructions if you have downloaded it.
Download these first:
cgpsmapper.exe
gmaptool.exe
MapSetToolKit.exe
and MapSource where u can directly get from Garmin site
http://www8.garmin.com/support/download_details.jsp?id=209
Create these folders on the root drive: (I will choose one to make things easier, you can change)
C:/grmtmp
C:/grmtmp/extract
Connect your GPS to USB, and BACKUP then remove
X:/Garmin/gmapprom.img and gmapprom.sum (may be gmapsupp.[img+sum]) approx. 1GB
1) Copy gmapsupp.img from this torrent to C:/grmtmp;
2) Extract gmaptool.exe, cgpsmapper.exe and mapsettoolkit.exe to C:/grmtmp/extract
3) Open a command prompt, and navigate to the extract folder ("cd/grmtmp/extract")
4) Run "gmaptool -S ../gmapsupp.img" Note that is -(CAPITAL S), lower case s is for different option
5) The above will extract files, you will get some warnings about 10 degrees. Ignore them.
6) Run "cgpsmapper mapset00.mp"
7) Run "MapSetToolKit"
8) In MapSetToolKit, press "Install A Existing Mapset"
8a) TDB File: "mapset00.tdb
8b) Overview map: "mapset00.img"
8c) Registry name: "WhateverYouWant" (I did "Grm2009.1Update")
8d) Leave TYP files blank, and hit "Install"
9) Close MapSetToolKit and run MapSource
10) Ignore any requests to unlock map, not ready yet.
11) Go to "Utilities-Get Unit ID" and Find Device with your GPS plugged in USB. Write down Unit ID.
12) Run Garmin Unlock Utility, Enter that Unit ID at the top.
13) Select under "Select Map Product"
14) Ender 396 for the FID/MapID, use the Generate button to get 25char code.
15) In MapSource go to "Utilities-Manage Map Products"
16) Go to "Unlock Regions" Tab, and hit "Add...", enter 25char code, comment optional
17) Now on the main MapSource screen, type 'm' to enable map tool.
18) You should see a large white rectangle, with rectangle outlines (these represent NA maps)
19) Click and drag to select them all, you can click "Map Set Name" if wanted.
20) Click the "Send to Device" button. Wait an hour. Enjoy.
Mar 19, 2009 | Garmin StreetPilot C330 GPS Receiver
Mapsource not recognizing Garmin type files
.img files do not open directly in Mapsource. You will need one of the many freewares available on the net. I use MapSetToolKit. The file is available at http://cypherman1.googlepages.com/. You can find out how to use this software from http://cypherman1.googlepages.com/intruction_en.
Jan 19, 2009 | Garmin GPSMAP 60CSx GPS Receiver
Backup Streetpilot C330
HOW TO INSTALL CN NA 2009NT ON A STREETPILOT C330
The CN NA 2009 NT mapset is too large to be installed in the C330 without putting part of it onto an SD card. My recommendation is to use MapSource to build an image file containing the lower 49 states, PR & the USVI and upload it into the internal memory as a new 'gmapprom.img' file, and then build a new 'gmapsupp.img' file for an SD card containing Alaska & Canada.
Start the process by using MapSource to create a new 'gmapsupp.img' file, choosing the lower 49 states plus PR/USVI. Make sure that the total mapset size is no more than 975MB (930MiB) MAXIMUM. Anything that's very much larger will cause the installation to fail, due to insufficient internal memory. Note: Even though MapSource lists the mapset size in "MB", it actually measures it in "MiB". DO NOT EXCEED 930.0 MAPSET SIZE AS LISTED IN MAPSOURCE! (Can you get away with "just a little bit more"? Yes, you can, but why push it when you can simply put the rest on an SD card? Otherwise, you'll spend 40 minutes uploading it to your C330, only to have it fail at 99%. No fun... )
After selecting these maps tiles, choose 'Transfer > Send to Device...', but do NOT select your C330 as the destination for your new 'gmapsupp.img' file; instead, choose to send it to a blank 1GB (or larger) SD card plugged into one of your USB ports by way of an appropriate adapter (or to the 'C:\Garmin\' folder on your primary hard drive if you're running a specially-modified MapSource executable). MapSource will automatically create a 'Garmin' folder on your SD card and create your new 'gmapsupp.img' file within it.
Once you've successfully accomplished this task, copy the new 'gmapsupp.img' file to your hard drive's 'C:\Garmin\' folder (unless that's where you sent it in the first place, as noted above), then re-name it 'gmapprom.img'.
Next, repeat the process, selecting Alaska plus all Canadian provinces instead. Do NOT select any of the U.S. map tiles you selected the first time around. Capiche? This time, however, after creating the new 'gmapsupp.img' file on your SD card, do NOT copy it to your hard drive and do NOT re-name it. Just plug your SD card into your C330.
Finally, we're almost ready to upload the first file you created -- now called 'gmapprom.img' -- into your C330. First, we have to make sure you have a copy of Garmin's WebUpdater package installed. Open your 'C:\Garmin\' folder. Is there a 'WebUpdater' folder there? Yes? Great! Look inside and you should see a file named 'WebUpdater.exe'. If you've got it, you're almost there.
You don't have WebUpdater installed? Go get it and install it; it's a free download from Garmin. I'm using Windows XP; be sure to get the Windows version that's right for you. (To the best of my knowledge, this procedure does not work on a Mac. Sorry... ) http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Now that you've got it installed, do the following:
- Right-click on an unoccupied area of your Windows Desktop; when the menu pops up, choose 'New', then 'Text Document'.
- Double-click this document; this will open up a brand new blank document in NotePad (or whichever text editor you've chosen).
- Copy and paste the following line of text into it...
C:\Garmin\WebUpdater\WebUpdater.exe /upload_file rgn=49 path=C:\Garmin\gmapprom.img -autorun usb /i
- Select 'File > Save' then 'File > Exit'.
- Re-name the file to 'C330_Map_Update.BAT'
- With the C330 connected to the PC by USB (your drivers have already been installed previously, yes???), double-click on your new 'C330_Map_Update.BAT' file.
- Sit and watch as the WebUpdater application opens up a command-line window and copies your new 'gmapprom.img' mapset into your C330!
- It will take approximately 35-40 minutes if all goes well.
-Don't forget, you'll need to have previously entered your 25-character unlock code into MapSource. That unlock code must be specific to your C330; just because your Nuvi's unlock code allows you to create mapsets in MapSource doesn't mean that those mapsets will work in your C330!
Jan 15, 2009 | Garmin StreetPilot C330 GPS Receiver
I cant download mapsource to install my australian map cd
If the CD is from Garmin, it will already have Mapsource on it, and it will install when it is installing your maps onto PC. If you ever install any other maps, the CD will check to see if Mapsource is already installed and will skip this procedure.
Jul 18, 2008 | Garmin Nuvi 660 GPS Receiver
Can't get maps to unlock
Call Garmin support @ 1-800-800-1020
Feb 09, 2008 | Garmin Quest GPS Receiver
Blue chart pacific v8.5- mapsource
Try skipping the installation wizard and use your coupon code to unlock the maps/GPS online at Garmin's website.
Also if you downloaded the mapsource software online, the download may have been corrupted.  You may have to contact garmin tech support to try another download.
Oct 18, 2007 | Garmin GPSMAP 76 GPS Receiver
Garmin Windows Vista Issue
I now this issue, and it's quite easy to work around, right mouse click on the executable and select run as administrator.
Aug 28, 2007 | Garmin zumo 550 GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
253 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
