Question about Nintendo Cyberbike Wii Bike & Game
It keeps hitting wall even I turn sterling wheel
It can't go straight and keeps going to the right side and hit wall
Unable to remove tire to change it even after removing all lug nuts ... is there some type of locking mechanism?
GIVE SIDE WALLS QUICK SWIFT KICK.DONT BREAK YOUR FOOT OR USE A LARGE RUBBER BLOW HAMMER HIT SIDE WALL SHOULD COME OFF.MAKE SURE VECHICLE IS OFF THE GROUND ENOUGH WHERE BOTTOM PART OF TIRE STILL DONT HAVE SOME VECHICLE WEIGHT STILL ON IT.
Oct 20, 2010 | 1995 Dodge Intrepid
Chevy caviler 1998 hit curb wit left tire
Something is bent... have a front end shop check it out, replace any bent parts and re align the front end.
Mar 13, 2010 | 1998 Chevrolet Cavalier
Loud noise when i hit bumps and turn the sterling
chances are that noise is the ball joints telling you they are dry and have no grease and they should be replaces fairly soon
Nov 04, 2009 | 1999 Ford Explorer
Craftsman riding lawn mower wheel toe needs adjustment.
put it in reverse ton the wheel to the right and hit the wall again....or ir you were backing up when u hit the wall runn into foward
May 19, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Green mushroom house world 7
This is hard, but not impossible. lol if you are a good "wall jumper" than it's a piece of cake. You will need to be miniature Mario for this. the easiest way to be miniature mario is to go back to world 1 and level four. In that particular level there's a question mark square that has the little blue mushroom, just finish that level in miniature "mode" and go back to world 7. Why little Marion? Because little mario can jump a lot higher than any other mario can. Now, in the ghost house, right after level 1, is where you'll get the pathway to the mushroom. hit the first (and only the first, no need to worry about making mistakes and having to start over) solid brick and an orange button will appear, as you may already know. step on it (watch out for the little ghost thing) and five golden doors will appear. Enter the bottom right golden door and you'll enter a room with a bunch of white hands pointing to the location of an invisible square, but who cares?! ignore the hands and square and go straight to the jumping jack looking thing. Jump towards the right wall and "wall jump" your way to the golden door on the top. When you enter this part of the level there will be a bunch of golden coins and a blue button. Now this gets a bit tricky. hit the blue button and run immediately to the LEFT (you are short on time, so READ the entire thing first, so that you don't get lost) (not the right where you would usually go to) the bricks will form two "L"s the first one is facing the wrong way,(after passing it) an opening will be there where you will jump up and access them, stick to the LEFT "L" structure (or the L facing the correct way). Now, since you are running, you are going to have to jump up towards the wall (that's now there) "wall jump" to the RIGHT and you will SEE the golden door that you need, HOWEVER, one wall jump will not be enough and you are going to "wall jump" to the LEFT using the single square "platform" where the door is at. and when you get to the wall, you are going to have to "wall jump" to the RIGHT once more. (NOTE: if you run straight towards the wall and try to wall jump from all the way from the left, you will NOT make it, you need momentum that you can only get by running and jumping towards the wall) you will most likely over do it, but don't worry!!! slide down the wall that's above the door and just keep holding the right arrow on your controlling pad, mario will simply land on the platform without any effort. I understand that what I just said may not make a lot of sense, but once you see it, you'll know what i'm talking about. Don't get frustrated for this may take several tries. good luck.
PS if you don't know how to "wall jump" this will be very hard for you.... so get some time "wall jumping." you may already know this, but just in case....
HOW TO WALL JUMP: how do you wall jump...? well you hit jump as you hit the wall. If you can slide down a wall, you can "wall jump," all you do is basically hit the jump button and then point the arrow pad (left or right) to which ever side the wall is at. ex if the wall is on your left, you jump close to the wall and hit left on the arrow pad and jump. MArio, then. will jump to the other side off the spot you hit the controls off. you could even jump straight up slide down the wall and just hit jump.
Apr 12, 2009 | Nintendo New Super Mario Bros. for DS
New Super Mario Bros:Stuck on world 6
wow, I don't know how you guys got this far in the game if you can't wall jump... all you have to do is get on the red blocks and "wall jump" to the other side. how do you wall jump...? well you hit jump as you hit the wall. If you can slide down a wall, you can "wall jump" all you do is basically hit the jump button and the point the arrow pad (left or right) to which ever side the wall is at. ex if the wall is on your left (which is the case on this level) you jump close to the wall and hit left on the arrow pad and jump. MArio, then. will jump to the other side off the spot you hit the controls off. you could even jump straight up slide down the wall and just hit jump. Try practicing wall jumping, it'll make your life a lot simpler and the game much more fun :D good luck. you could twitter me if you have any questions, but twitter is kind of short with letters.
good luck to you all.
http://twitter.com/ilikeapples
Jan 27, 2009 | Nintendo New Super Mario Bros. for DS
Nintendo Cyberbike Wii Bike & Game Logo
63 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
