Question about Panasonic Viera TH-46PZ85U Plasma TV
TH-46PZ85U reset codes - Panasonic Viera TH-46PZ85U Plasma TV
I have a Panasonic th-46pz85u. It's been working fine, but now all the hdmi ports have quit working, but the component inputs work fine.
Contact the authorized service center for Panasonic. Please do not make any experiments. The fault is simple now; do not make it irreparable. Surely you can't repair this fault.
Gopakumar Gopalan Google
Jun 29, 2015 | Panasonic Viera TH-46PZ85U Plasma TV
10 blinks code
I don't know what to do with 10 blinking of my Panasonic TH-46PZ85U.
I bought It in summer 2008...is it already kaput ? I'm not sure any more to want to make repair my tv set. I wonder how much could it cost ? Bye-bye plazma.
Aug 18, 2012 | Panasonic Viera TH-46PZ85U Plasma TV
Panasonic plasma th42pz85u blinking light 10 times
This is the error code, indicating a failure inside the board. Might need attention by a qualified service technician.
Jul 30, 2012 | Panasonic Viera TH-46PZ85U Plasma TV
TV won't turn on
at plug in only is there a light blinking and if so how many Blinks? and if not hit the power button and do the same. look for the number of blinks. there are many things that could be wrong for the same code.
Nov 16, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
Panasonic - TH-46PZ85U - Will not power up, either from the remote or from the TV on-off power button. With the TV plugged in, a light on the bottom left corner flashes 10 times, pauses and then the...
Could be a cooling fan failure, there are five fans across the back of this tv ( i think) if even 1 fails the power supply shuts down. If so fan needs replacing,
pete
Nov 11, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
I have a Panasonic TH-46PZ85U Plasma TV with a two blinking light code, no picture. How do I fix. I Have removed the back panel and looked for damaged caps but I do not see any.
hi; the blinking light code means that you have a fault in the power supply unit, unplug the tv from the power source, check all transistors you will find some of there shorted, just replace them; if you need a help about repairing i'll help you
Nov 06, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
My panasonic th-46pz85u has 2 blinking lights and wont turn on
The power supply board it dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 21, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
I have a Th-46pz85u panasonic plasma tv that is blinking the power light 10 times. I was curious to see what the replacement part is to fix that problem. I have the Panasonic error codes and that error...
Yes,this codes is a 100% correct is ur power supply board.U searches all around the power supply board and it supporting boards for those leakages gases capacitors?These capacitors alway have bulges on it top or puff on it top.Replaced these bad capacitors,u will get ur power voltages stable and ur power supply board will work.Not,than one or more of ur power transformers have a shorted power pins legs.The power transformers,coil is dead.The transformer must be replaced.
May 03, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
My panasonic 50" viera link tv just shut off and will not turn on. I have power to the outlet and it is plugged in. The remote will not turn it on either.
See if leaving it unplugged overnight would reset it and solve the issue. If it does not you may have leaking capacitors on its power supply circuit or burnt parts or solders that may have gone loose.
Oct 27, 2009 | Panasonic Viera TH-46PZ85U Plasma TV
Viera TH-46PZ85U. gray box where picture should be
If it was a setting on the television, then the cable info would also be affected. Try a reset on your cable box, as the cable info is generated within the box from the data stream, whereas the picture is streamed from the provider.
If the reset doesn't work, it's time to call the cable company - it's not a fault with your telly.
Mar 05, 2009 | Panasonic Viera TH-46PZ85U Plasma TV
Panasonic Viera TH-46PZ85U Plasma TV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
