Question about Husqvarna 326LS
Weed eater fuel line routing - Husqvarna 326LS
bbreton
  • 437 Answers
SOURCE: want to remove huscavana weed eater head
You should find a hole in the piece just above the trimmer head, this should line up with another hole deeper in the area. You stick a piece of rod in there to keep the head from turning. Use some pb blaster penetrating oil to help loosen up the head.
Posted on Feb 25, 2010
MOTORWIZJ
  • 1363 Answers
SOURCE: Husqavarna 125L E TEC weed eater won't stay running
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
Posted on May 26, 2010
  • 4088 Answers
SOURCE: pulling string on weed eater does not want to turn
It's possible that the engine has seized if the pull cord won't turn the engine over. Remove the starter mechanism from the engine and try to turn the flywheel by hand. One or more of the mounting screws may be hidden under a decal or other label. If the engine won't turn at all, remove the muffler and check the piston skirt for bad scoring--which usually means either dirt inhalation (bad air cleaner) or running the unit on straight gasoline. Either of these conditions require replacement of the cylinder, piston and ring(s) plus labor if you farm out the repair. Weigh the approximate cost of up to $150 against a new trimmer. Hope this helps!
Posted on Jul 11, 2010
  • 123 Answers
SOURCE: what is the fuel mix for a 128cd model weed eater
A good fuel mixture ratio for any 2 stroke weedeater or chainsaw is 50:1. That equals out to 2.6 oz of oil per gallon of gasoline. Most 2 stroke oils can be bought in pre-measured containers at hardware stores or small engine dealers. It is best to not mix more than 2.5 gallons at a time. Hope this helps, Daniel.
Posted on Sep 14, 2011
plink_plonk
  • 1807 Answers
SOURCE: weed eater bogs out at full throttle
Make sure fuel is mixed correctly, make sure the choke isnt stuck on aswel, ive had it happen to me before when the little blue leaver sticks and it wont rev out properly.
Posted on Apr 03, 2013
Show fuel line routing on weed eater by troy built.
Many Parts manuals don't show the actual fuel line routing.. The pipes have to go from the tank to the carb or primer bulb, generally a direct route without being trapped or rubbing. If you're referring to what pipes go to which part, then that's another question I could answer if asked. Thank you
May 15, 2016 | Troy Garden
Is there a diagram showing how carburetor gets fuel on echo 210 weed eater?
I found that the fuel line kit sold at "Home Depot" has a diagram showing how the fuel lines are routed. The kit includes a wire tool so that you can pull the new fuel lines thru those little holes in the fuel tank. Hope this helps.
Nov 06, 2014 | Garden
Weed Eater GTI 19T
If it's the one that comes 'out' of the primer bulb it is the return line that goes in the fuel tank.
Aug 07, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
ON OF THE GAS LINE BROKEN INSIDE TANK.. IT **** AIR.. HOW DO I KNOW WHERE IT GOES..
Try the SEARCH feature on this site. MANY posts have been made about fuel line routing for this and other models (tey are basically all the same). Search for : Weed Eater Fuel Line or Weed Eater Fuel Line Routing. It is there because I have been there and seen it.
Aug 10, 2010 | Poulan Pro Pp125 25cc Gas Straight Shaft...
Powerpro 17" McCollich weed eater
hey harry the float inside the carb is stuck i would suggest rebuilding the carb
Jun 27, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Fuel line routing on poulan 2051
This is Poulan.com
Select "POULAN-WEED-EATER" then enter your model number.
You may have to experiment a little but your IPL is there. It will aid in determining how your fuel lines run.
http://www.ordertree.com/cms/illustrated-parts-list/9788.html
HTH Lou
Jul 29, 2009 | Garden
Fuel hoses routed wrong on weed eater fuel tank
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358795190&productCategoryId=1503820&brandId=0247&modelName=TRIMMER&diagramPageId=00002&componentDescription=CYLINDER/FAN%20HOUSING/CRANKCASE&documentId=P0303202&backToLink=Return%20to%20Sub%20Components%20list
Apr 04, 2009 | Garden
Go to sears.com then parts store then type in model no. You should find a parts breakdown hopefully that will help.
Mar 16, 2009 | Craftsman 25cc Gas Line Trimmer
Husqvarna 326LS Logo
42 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
