Question about Pentair White/Gray Legend Platinum Automatic Pool Cleaner - Ll105pm
Pentair letro legend platinum - will not work
Back wheels will not sit on the bottom of the pool, moves very slowly and just won't work.
  • 83 Answers
Sounds like there is a restriction somewhere. Places to look are the Wall Fitting Screen, make sure that is clean. The Debris bag, and the black cone shape valve, should also be checked for blockage.
Check for leaks in the hose also. You shold check the Float also, if it has water in it, that needs to be replaced. Wear on the tires can cause this also, check them, too. Those are the EASY fixes.
If none of those, then the blockage may be INSIDE the unit. If you have a manual, look at the Product Breakdown and Parts page. If you do not have a manual, this link will take you to one online:
http://www.pentairpool.com/pdfs/LegendPlatinumOM.pdf
The page you will need to look at is page 15, on the online manual, Exploded View. Any of the internal small hoses, like #10 and #11, can be blocked. Any of the small elbow turns, like the one part #10 connects to, can be blocked. Also, on the tube that the Ballast Float connects to there are small elbows that can cause this issue. LOTS of little parts and places to look for a piece of debris that is cause the cleaner to not work properly.
Posted on Jul 01, 2009
Platinum Legend keeps moving to the left
take cover off make sure both sides of the drive wheels are evenly tightened also notice the inside of the wheel is a gear if defective you can switch fronts with backs
May 09, 2014 | Pentair White/Gray Legend Platinum...
Tail on pool sweep is not moving
screw on bottom open up it will let water in and tail will wag
Jan 27, 2013 | Pentair White/Gray Legend Platinum...
Letro legend front wheel drive wheels no moving
take top off and adjust front wheels closer to gear but not too tight
Jan 17, 2013 | Pentair White/Gray Legend Platinum...
I need a manual on how to install and repair letro pool cleaner
pool distributor or amazon pool section remove bottom 4 screws see if hoses came off or belts if tires worn switch with backs front only drive if not moving adjust wheels to touch gears
Aug 17, 2012 | Pentair White/Gray Legend Platinum...
It flips on it's side, then goes around in circles and will not stand back up on the wheels. It's a Letro Lengend about 7 years old.
replace the float. It looks like a 3"x5" white or grey thing on the back just below the bag. Remove by unscrewing motion as you pull out.
Jul 20, 2011 | Pentair White/Gray Legend Platinum...
Cleaner lacks power won't climb sides
Hey Walt, Check the hose swivels. Alot of the time the hose swivels leak water which defreases the flow to the cleaner. Also, depening on the model Letro cleaner you have, it could be the gear teeth in the wheels. epoolshop.com
Nov 03, 2009 | Pentair White/Gray Legend Platinum...
Legend pool cleaner wheels not moving
You might want to pull the drive wheels and see if their might be a small pebel stuck in the drive gears on the wheel.
Oct 04, 2009 | Pentair White/Gray Legend Platinum...
Pentair White/Gray Legend Platinum Automatic Pool Cleaner - Ll105pm Logo
1,382 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
